Spinning when shifting to second
Old Nov 29, 2009 | 02:38 AM
Driv3r's Avatar
Driv3r
So I used to get this loud wheel spinning noise when driving hard and shifting into second and looses sum traction (with ASC off) now i've changed my tires it doesnt make the sound anymore and looses minimum traction, as the tires are just biting to the road. I take the "snap" change (when the sound comes) is a indicator of bad tires? What is the story surronding "snap" changes?
thanks
Old Nov 29, 2009 | 06:06 AM
slinger688's Avatar
slinger688
thanks
Can you descibe what you mean by "snap" change.
Old Nov 29, 2009 | 06:19 AM
Driv3r's Avatar
Driv3r
exactly what it says.. making a tire screeching sound when changing into second
Old Nov 29, 2009 | 06:50 AM
Stig One's Avatar
Stig One
With rft's i get traction loss in 3rd gear
Old Nov 29, 2009 | 06:55 AM
Driv3r's Avatar
Driv3r
same here.. So whats the deal about it, if you dont get the tire screeching noise any longer does that mean its better ? or does it slow you down to some effect?
Old Nov 29, 2009 | 06:59 AM
Stig One's Avatar
Stig One
LOSS OF TRACTION SLOWS YOU DOWN
Old Nov 29, 2009 | 07:41 AM
Driv3r's Avatar
Driv3r
so the greater the loss of traction, it causes the screeching sound? but the less traction loss, it causes non or minimum screeching?
Old Nov 29, 2009 | 09:52 AM
IceManMCS's Avatar
IceManMCS
Driv3r, what is your age?
Old Nov 29, 2009 | 10:55 AM
ran-o-matic's Avatar
ran-o-matic
"Snap Change" isn't a generally used term where I live, but maybe it is to Driv3r. Seems like they are talking about shifting quickly to get maximum acceleration.
The sound you hear is not directly associated with worn tires. It is caused by applying excess force to one of the front tires and momentarily spinning it. Stickier tires allow you to add more force before they spin, but every tire has its limits.
Old Nov 29, 2009 | 01:31 PM
darmog's Avatar
darmog
Common way to say that would be "chirping" or "spinning" the tires.
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
MINI Stupor
Oct 1, 2015 11:36 AM
bahman
Sep 30, 2015 01:59 PM
EVMini
Sep 28, 2015 10:20 AM
