Roll call - 8"+ wide wheels
Old May 31, 2018 | 06:42 AM
  #1001
JKo's Avatar
JKo
Rota Slipstream 16x8" ET34
205/50-16 Yokohama AD08R
Bilstein B14 dropped about 35mm
Camber -1.0 F, -1.0 R
Rubbed slightly at the rear at first when going over big bumps, but the plastic has "self adjusted"...
Old Jun 21, 2018 | 10:02 AM
  #1002
tallskinnymatt's Avatar
tallskinnymatt
Wheels: APEX ARC-8 17x8" ET25
Tires: 205/40-17 Federal Evoluzion ST-1
Suspension: MeisterR ZetaCRD+
Old Jul 1, 2018 | 02:38 PM
  #1003
copajoe's Avatar
copajoe
Hello all,
I have a 2014 MCS 2 door hardtop. Not dropped, no big brakes.
Just ordered some Enkei VR5 rims 18x8 with an et45.
What are the biggest tires I can fit that will not rub?
I believe I have seen 215 40 18 will go no problem but what about
225 40 18's? will they fit or will they rub?
thanks in advance....
Old Jul 1, 2018 | 07:20 PM
  #1004
shmandrew's Avatar
shmandrew
Originally Posted by shmandrew
Anyone know if it would be possible to run a 18x8.5 et42 with 225/40 on a F56 running the JCW pro coilover suspension? Not looking to make any major camber adjustments
Based on the lack of responses, I'm assuming no one cares, but the answer to this question is YES!
3SDM 0.66 18x8.5 ET42 with Michelin Pilot Sport 4S in 224/40/18. No spacers and no camber adjustments needed. These bolted straight on with JCW PRO coilovers with very little clearance for the front struts, but no rubbing. I am getting some rubbing on the inner lips of the fender arches on dips and bumps, but the fender is already wearing away so I figure this is a self-correcting problem.
Old Jul 6, 2018 | 09:30 AM
  #1005
Hayden Joy's Avatar
Hayden Joy
Would you recommend running 18inch wheels on clubman?
Hey i just bought a 2012 clubman, i am looking to buy a new set of wheels i am looking at enkei y5s or m52. I definitely want 17inch but now i have seen some 18inch rims on minis. I just want your input on if going to 18 would be a good idea?
Old Jul 12, 2018 | 10:19 PM
  #1006
Spinsy's Avatar
Spinsy
My R53 with 15x8 wheels
My 2004 R53 Mini
Enkei RPF1's. Wheel/Tire specs 15x8 offset +28 with 205/50/15 Dunlop Direzza Dz102's. No spacers used.
Wheels weigh 11 lb's and made a HUGE difference in performance; consider light weight wheels guys, you'll never want to go back.
Stock height with a small fender gap (before hight adjustment)
After height adjustment. Literally a fingers clearance on the front scrape guard. Not the easiest car to drive static.. but worth the performance!
Side profile shot to see the fitment, and this is prior to height drop. In my opinion +28 is close to perfect on the offset. Rear I think +25 or +20 is needed because when you drop the height, the natural camber kicks the wheel in a smidge thus losing the flush look as the front has. Mine ended up tucking a little as you could see in the pics.
Old Jul 20, 2018 | 11:21 AM
  #1007
non-s's Avatar
non-s
^ Bogus Basin road?
Old Jul 20, 2018 | 04:05 PM
  #1008
Spinsy's Avatar
Spinsy
Originally Posted by non-s
^ Bogus Basin road?
You got it! Idaho roads are boring unless you go to the mountains.
Old Jul 20, 2018 | 04:10 PM
  #1009
non-s's Avatar
non-s
I went to BSU, very familiar with the mountain roads, spent a lot of time on 55, 21 and 75. Wasn't as fun since I had a 1996 subaru outback wagon back then, though it was a 5speed and I pushed it to its limits! I should take a road trip out there in my R50 now!
By the way, you've got a clean ride! What suspension and brakes are you running?
Old Jul 20, 2018 | 04:25 PM
  #1010
Spinsy's Avatar
Spinsy
Im running BC Racing Coilovers with EBC Yellow Stuff Pads/slotted rotors, however the brakes are stock. For me they've got plenty of bite.
Old Jul 20, 2018 | 08:04 PM
  #1011
Bnourai's Avatar
Bnourai
And....
Attached Thumbnails Roll call - 8"+ wide wheels-20180416_192503.jpg   Roll call - 8"+ wide wheels-20180416_192536.jpg
Old Aug 16, 2018 | 10:02 AM
  #1012
MrPink1942's Avatar
MrPink1942
16x8 Advanti DST Storm S1 ET35 205/50/16 Firestone Firehawk Indy 500's.
Old Aug 20, 2018 | 05:33 PM
  #1013
CyGuy2328's Avatar
CyGuy2328
Andros Spec J. 18x8 with Continental DWS 235/40/18
No rubbing and rides much better than original 17 RF that came on it.
Old Aug 22, 2018 | 01:45 PM
  #1014
miniuy's Avatar
miniuy
CyGuy2328, nice look!
Congrats!
Old Sep 12, 2018 | 01:43 PM
  #1015
Our r56's Avatar
Our r56
I’m sure this has been asked. Just can’t find the answer I’m looking for.
Hi. I’m new to this and have been looking online for answers but never get the exact answer I’m looking for. I recently bought a 2012 Mini with 15x5.5” factory rims and my tires are about as wide as a bicycle. I would like to know will a 15x8” rim fit on my completely stock Mini (non S)? If so, what would b the best offset? Also, What would be the widest tire I could fit without doing any kind of modifications? Thanks in advance for any help.
Old Sep 12, 2018 | 04:12 PM
  #1016
mini coop's Avatar
mini coop
Yes they will fit but it's based on the manufacturer. If you go to Tirerack they will list all wheels and widths available that will fit your car. At that point then
the tires available. The other means is to call Tirerack and they too will help you via phone. Personally I have put a a 205/55/15 on a 15x5.5 inch rim. I believe a 225/45/15 will fit based on normal ride height and that you have not lowered your car.
Old Sep 12, 2018 | 05:02 PM
  #1017
Spinsy's Avatar
Spinsy
lowered on coilovers with 205-50-15 Falken Azenis
Hey! Unfortunately im not familiar with the new minis, however I can tell you that 15 is a pretty small size so you can get away with a lot more play than say a 16 or 17 inch wheel. For my r53 mini (2002-2006 gen) anywhere between +30 and +20 is ideal for an 8 inch wide wheel. BUT thats for my generation. Do some research and see what will work for your car. I personally just went off what other people did with their cars, and it helped me get an idea of what worked and what didnt. Sorry that Im not the biggest help, but hopefully you get a great fitment!
My r53 gen Mini cooper. 15x8 with +28 offset (no spacers) lowered on coilovers with 205-50-15 Falken Azenis tires.
Old Sep 13, 2018 | 09:50 PM
  #1018
Strubaj's Avatar
Strubaj
17x8 square offset 30 something
BBS Style 19 redrilled to 4 lug
195/45
aired down
Old Sep 29, 2018 | 03:07 PM
  #1019
DeathDream's Avatar
DeathDream
Wheel/Model: Enkei TS-10
Offset: 40
Wheel Size: 17x8
Tire Size: 215/40/17
Old Nov 5, 2018 | 08:32 PM
  #1020
BudMan's Avatar
BudMan
I was look looking at these. I can't tell. Are the they black/white or black/silver?
Old Nov 27, 2018 | 11:40 PM
  #1021
HAWASHNK's Avatar
HAWASHNK
Wheel/Model: Carline CM2 3-piece rims with custom inner barrel(change 7" to 6")
Offset: ET28 F, ET25 R
Wheel Size: 17x8.25, 17x8.75
Tire Size: 195/40/17 on all four (Falken ZE912/F & Nankang AS-1/R)
Suspension: KW Clubsport
Drop: 2.5"+
Camber Settings: -2.2 F, -3 R
Rubbing: None at all
Old Jan 15, 2019 | 12:56 PM
  #1022
maksimus's Avatar
maksimus
Wheel/Model: XXR527
Offset: +25
Wheel Size: 17x9.75, 17x9.75
Tire Size: 235/40/17
Suspension: Stock at the moment
Drop: Stock at the moment
Camber Settings: Factory
Rubbing: none in the front, rear rubbed on big bumps
with plastic trimmed-no rubbing
Old Jun 2, 2019 | 06:54 AM
  #1023
akitcher99's Avatar
akitcher99
Wheels: ebay specials
Offset: 31
Tyre size: 225/45/17
Suspension: fk shocks and 35mm lowering springs
Camber settings: stock rear, as far as you can stock on the front
Rubbing: a tad on the rear
Old Jun 11, 2019 | 11:17 AM
  #1024
Minislice86's Avatar
Minislice86
Wheel/Model: enkei
Offset: 30
Wheel Size: 17x8, 17x8
Tire Size: 215/40/17, 215/40/17
Suspension: Stock
Camber Settings: stock
Rubbing: No
Pic:
Old May 10, 2020 | 01:37 PM
  #1025
minniedryver's Avatar
minniedryver
15x8 +25 Circuit Performance CP26 with 205/50/15 Federal 595 RS Pro
