Roll call - 8"+ wide wheels
Old Apr 22, 2010 | 10:16 AM
  #426
Cudda_Kine's Avatar
Cudda_Kine
Originally Posted by JohnnyVillan
If your rear arches pop off, just pop em back on. Thats what I do lol.
Could i just super glue them so they don't pop off?
Old Apr 22, 2010 | 11:08 AM
  #427
smlzilla's Avatar
smlzilla
Lol gotta get the gorilla glue.. Suppose to be stronger then super glue..
Old Apr 22, 2010 | 11:31 AM
  #428
xxTHIR13ENxx's Avatar
xxTHIR13ENxx
That's what holds my passenger's side skirt in place. I wouldn't use it on the arches, though...
Old Apr 22, 2010 | 04:38 PM
  #429
call it spade's Avatar
call it spade
Originally Posted by Cudda_Kine
Does he ever drive it through the drive-thru for fast food? I've noticed some of the spots here have really narrow drive-ways.
It is straight track. Barely sees the open road...
Old Apr 22, 2010 | 07:00 PM
  #430
ashboomstick's Avatar
ashboomstick
Where's your car's picture? :-P
Dude, even if mine looked like a steaming pile it wouldn't affect the way yours looks.
Old Apr 22, 2010 | 10:34 PM
  #431
Un0RiGiNaL's Avatar
Un0RiGiNaL
hmm.
Cudda Kines car looks alot better than i thought it would.
If the car was white though
Old Apr 23, 2010 | 01:50 AM
  #432
Cudda_Kine's Avatar
Cudda_Kine
Are Megan Racing Coilovers very stiff? I really need new coilovers asap! It's hard to car pool when my arches keep popping off on speed bumps :-P When i'm by myself, the arches are fine.
Old Apr 23, 2010 | 04:44 AM
  #433
dark06mcs's Avatar
dark06mcs
you can get nearly any coils and swap the springs for whatever rate/length you want. with coils that use stock style springs you'll need different upper mounts. coils that use standard straight springs are ready to swap right out of the box
Old Apr 23, 2010 | 06:49 AM
  #434
JohnnyVillan's Avatar
JohnnyVillan
Dude carpooling is out of the question lol. I cant even put my dogs in the back without rubbing and I have a 1 passenger limit. If it rubs now it's gonna be even worse when its lower so just be prepared for that. And you really need to start AVOIDING speedbumps. They will mess up your car hardcore.
I dunno how stiff megans are but I hear they dont go that low anymore.
Old Apr 23, 2010 | 10:59 AM
  #435
M3This's Avatar
M3This
Your problem isnt what spring rates to run its your offsets are just wrong.
I dont mind poke but yours is overly aggressive and without a lot of suspension tuning (coilovers, upper and lower rear camber arms, ect) its going to take work.
Old Apr 23, 2010 | 01:22 PM
  #436
Cudda_Kine's Avatar
Cudda_Kine
I'm going to ask mzman. He seems to be the only one that i should talk to about coilovers since he's pretty much running the same setup lol. I hope he replies :-P
Old Apr 23, 2010 | 04:36 PM
  #437
Rally@StanceDesign's Avatar
Rally@StanceDesign
Again, his car is a RACE CAR. It sees almost ZERO road time. I don't think his setup is the one to mimic on your daily driver. Just putting that out there.
Old Apr 23, 2010 | 07:22 PM
  #438
call it spade
I know this for a fact.
Do you really wanna drop 10k on suspension?
Old Apr 24, 2010 | 04:09 AM
  #439
Cudda_Kine's Avatar
Cudda_Kine
Can someone please tell me why my car shakes when driving? bad rims, not balanced well, alignment's off, bad bushings, not hub-centric?
My older rims used to shake too, but not as much as these. And the other rims were balanced as well. LMK!
Old Apr 24, 2010 | 06:16 AM
  #440
sleeper1995's Avatar
sleeper1995
I am running 949 15x8 36mm offset with 15mm spacer and a built in 4mm spacer on my brakes
Old Apr 24, 2010 | 06:26 AM
  #441
NightFlyR's Avatar
NightFlyR
Well the KT1s have arrived, tires will be mounted on Monday and then we shall see if the 215 50 16s fit on the 16 X 7.5 and the 16 X 9 without any rubbing, if not then I guess we will need some spacers and a coilover kit.
Wheel buying is a very addicting and expensive habbit to break !!!
Old Apr 24, 2010 | 07:17 AM
  #442
Rally@StanceDesign
Sleeper- looks good
Old Apr 24, 2010 | 07:58 AM
  #443
sleeper1995
Thanks Rally it took me awhile to get some picture up to show you guys the set up I have more but for some reason they will not load that is the only one I could get to load. It really doesnt look like it but I am at full drop on my bc coilovers in the front and up a bit in the rear -3 camber in front and -2.5 in the rear
Old Apr 24, 2010 | 08:03 AM
  #444
Rally@StanceDesign
What tire size are you running on there?
Old Apr 24, 2010 | 08:18 AM
  #445
sleeper1995
I currently have my 205/50/15 rt 615 on the wheel I had ordered them for my old set up and figured I should use them before I put my 225/45/15/ nto1 on. I had to get the nto1 after I tested them on my car (freind let me use his before I got my wheels and tires) and they fit great, so I cant wait to get the 225 on the car. Dont mind the front bumper its off cause we are fitting somthing specail up front for somthing under the hood.
Old Apr 24, 2010 | 09:20 AM
  #446
JohnnyVillan
Hubcentric most likely
Old Apr 24, 2010 | 09:36 AM
  #447
Rally@StanceDesign
Shoulda still centered itself with the lugs if you tightened them in the correct pattern.
Old Apr 24, 2010 | 12:55 PM
  #448
Cudda_Kine's Avatar
Cudda_Kine
Is there an adapter i could use or such thing? Like Hub-Centric Adapter? The shop also told me that my bushing gone bad, since it's been about 67,000 miles already that's why.
Old Apr 24, 2010 | 01:20 PM
  #449
maxmini's Avatar
maxmini
Cudda I mean you no ill will and wish you all the best but this is the beginning of a huge train wreck. Please listen to Ralley and the guys that know whats up as you have created one huge money pit and I hope you have a thick wallet. Again good luck and listen to these guys like you should have in the beginning . I was young once and made my mistakes as we all have , its just frustrating to try and help others avoid theirs when it is human nature for them to do it their own way no matter what the consequences.
Randy
M7 Tuning
Old Apr 24, 2010 | 01:48 PM
  #450
Cudda_Kine's Avatar
Cudda_Kine
I'm not ready to just give up on these 10's. They're not Hub-Centric so i'm pretty sure i just need to get a Hub-Centric Adapter & change my bushings. I can live with the arches popping off lol.
