Rota RB's now available in 17"
Old Dec 7, 2009 | 08:29 PM
  #176
gokaht's Avatar
gokaht
Originally Posted by rlnewby
hmm...where did yyou get gold/bronze centered wheels???
Old Dec 7, 2009 | 08:36 PM
  #177
rlnewby's Avatar
rlnewby
Custom painted
Old Dec 27, 2009 | 09:06 AM
  #178
THEFISCH's Avatar
THEFISCH
Originally Posted by Mach V Dan
We got some of these in...
--Dan
Mach V
Dan I will be calling you Monday. I am down in the Hampton Roads area so I think I will just drive there if you have them in stock.
Old Dec 29, 2009 | 12:19 PM
  #179
Mach V Dan's Avatar
Mach V Dan
They are!
--Dan
Mach V
Old Dec 29, 2009 | 12:32 PM
  #180
fishey72's Avatar
fishey72
Just sold my s-lites (s-heavies), it looks like I have found my wheels! Gloss black w/polished lip on BRG-W.
Just not sure what size tires to put on it, stock oem sport suspension...
Old Dec 29, 2009 | 02:45 PM
  #181
THEFISCH's Avatar
THEFISCH
They are!
--Dan
Mach V
Not in a 17 Will just sent me a downer email.
They will be mine in 6-8 weeks though
Old Dec 30, 2009 | 08:54 AM
  #182
Mach V Dan's Avatar
Mach V Dan
Ah, yes, sorry. (For some reason I thought the 17's that were going out were for you!)
I've got tons of OTHER colors/fitments of RB still in stock, though!
Shown (top left to bottom right): Gunmetal 17", Gunmetal 16", Flat black 16" (two sets), Gloss black 16", Gloss black 17".
--Dan
Mach V
Old Jan 21, 2010 | 06:40 PM
  #183
ZippeeGear's Avatar
ZippeeGear
Here's a couple more:
--Dan
Mach V
FastMINI.net
Sorry, I couldn't find the post indicating if these are 16" or 17"? Did you also say in another post that these rims already come "hub centric" to fit the R53 Mini Cooper S model? Any issues with clearing the brake calipers?
Old Jan 22, 2010 | 08:13 AM
  #184
Mach V Dan's Avatar
Mach V Dan
Those are 17".
Usually, but not always. RBs come in 56.1, 57.1, and 67.1 hub bore. We try to get them in 56.1, but we don't always have a choice.
They will clear all MINI brakes except 2009+ JCW.
--Dan
Mach V
Old Jan 23, 2010 | 07:21 PM
  #185
DetroitWheels's Avatar
DetroitWheels
><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º>`·.¸¸.·´¯ `· .¸.·´¯`·...¸><((((º>
That's the wheel!
I've seen enough. The Rota RB 17" 7.5 (+45?) Royal lip Hyper Blacks are going on my Silver w/Black Cooper S for this summer. I can't wait. It sounds like the 215/45/17's and all will work out fine with my H&R spring kit set-up.
I have two questions though.
What is the stock offset for a 2004 Cooper S R53 and wouldn't it make sense to stay there as they flushed the tire/s-lites out pretty good to begin with?
and 56.1 hub centric is the way to go...? I don't understand the hub and hub spacer issue as I'm a bit of a rookie here. Is there a problem here? Any help would be greatly appreciated.
Old Jan 26, 2010 | 12:29 PM
  #186
Mach V Dan's Avatar
Mach V Dan
Factory offset is a little higher at something like 53 (depends on the wheel). But the +45 fits really well.
The actual MINI hub is 56.1mm, so a 56.1mm wheel will fit with no adapter ring. MOST -- but not all -- of the RBs we sell are 56.1mm hub bore.
Hubcentric rings are very common in the world of aftermarket wheels, so it would be no harm if the wheel was 67 or 73mm; we'd just supply a set of hubcentric rings that would adapt from the hub size to the wheel size. There's no reduction in precision, safety, comfort, or anything like that.
We just like 56.1mm wheels because then there are fewer parts to keep track of.
The only exception to what I said above is that sometimes we get wheels that are 57.1mm. There's no off-the-shelf hub ring that is 0.5mm thick, so we have to run those without a centering ring. I've done that on several sets on my car, and never had a problem.
--Dan
Mach V
Old Jan 26, 2010 | 05:43 PM
  #187
DetroitWheels
Thanks Mach V Dan for all the helpful answers...
Old Feb 2, 2010 | 08:11 PM
  #188
ZippeeGear's Avatar
ZippeeGear
--Dan
Mach V
Thanks for your thoroughness. By the way, do you ship out of state?
Old Feb 3, 2010 | 02:04 AM
  #189
Uncl3's Avatar
Uncl3
Yes he does.
Old Feb 3, 2010 | 09:34 AM
  #190
Mach V Dan's Avatar
Mach V Dan
We ship anywhere! To get a shipping quote, add items (like Rota RBs) to your shopping cart, and enter your zip code.
--Dan
Mach V
Old Mar 10, 2010 | 10:45 AM
  #191
hunter99's Avatar
hunter99
Dan,
How are you on stock of the 17" royal black RB's right now? I was going to get some black webspokes but really still like these wheel a lot. Also wich center bore do you have if you have them? Lastly, How much of a change is the offset and will I notice it?
I am going to just go with the stock tire size and am about to buy a set so now would be a good time to get these. Any rubbing issues I need to be aware of? Tried to find earlier in the thread and there was a mention but it didn't make full sense.
Thanks, and sorry for all of the questions. If I get them I'll send you pics of them on a PW/B with Aero kit.
Old Mar 10, 2010 | 12:28 PM
  #192
Mach V Dan's Avatar
Mach V Dan
None on hand, but will have them again in a week, give or a take a few days.
Also which center bore do you have if you have them?
56.1mm, no hubcentric rings needed.
Only a few mm. You will not be able to detect it.
None.
--Dan
Mach V
Old Mar 11, 2010 | 04:15 PM
  #193
DrewN's Avatar
DrewN
Dan's the man (I know every Dan likes to call himself the man but Mach V Dan's the man for real). He's put up with my idiotic questions the past couple of weeks.
Dan -- so I decided to actually look at the freakin' labels on the RBs this time. 56.1mm, hubcentric, pop 'em in and go. Mine are going on in two days. Thanks for all your help and fast delivery
No pics btw because I am not lowered (yet) and the Mach V is nicer looking than mine.
Old Mar 12, 2010 | 12:16 PM
  #194
Mach V Dan's Avatar
Mach V Dan
New color -- Hyper Black.
Thanks for your business.
--Dan
Mach V
Old Mar 12, 2010 | 02:37 PM
  #195
Folic Acid 9's Avatar
Folic Acid 9
I have the Hyper Blacks on my Dark Silver and I love them.
Old Mar 13, 2010 | 01:06 PM
  #196
DetroitWheels
The Rota RB 17x7.5 +45 o/s w/56.1 hub Royal Lip (polished) Hyper Blacks are going on my R53 Cooper S for this summer, Dan has sent a set out UPS as we speak. Thanks again Dan.
Dan commented earlier in the thread about running 235/40/17's with no proplemo (rubbing) and catseye mentioned running 205/45/17's and Msteadman is running 215/45/17's with Eibach springs and no comments of rubbing, now I'm wondering whether 215/45/17's or 225/45/17's will work out fine (no rubbing) with my H Sport spring kit set-up??? Sounds promising and both sizes offer huge options of tire availability.
I would be open to any thought or observations on these compo's.
Spring is almost here!
Old Mar 13, 2010 | 01:32 PM
  #197
Mach V Dan's Avatar
Mach V Dan
...I'm wondering whether 215/45/17's or 225/45/17's will work out fine (no rubbing) with my H Sport spring kit set-up???
Generally speaking, 215/45R17's fit okay, but 225/45R17's are prone to rubbing because of the taller diameter.
--Dan
Mach V
Old Mar 14, 2010 | 08:56 AM
  #198
DetroitWheels
--Dan
Mach V
Ok, one more time and I'll hopefully be all set up here. Am I asking the wrong question Dan? "215/45R17's fit okay"... Let me go one further with you, do you feel maybe... 215/40/17 with my one inch lowered progressive spring package would be a better, more max'ed out wheel well fitment with no potential rubbing??? I hate to make all these dart throwing questions, so to speak but, for me anyway, this is kind of a fuzzy science. I think the Dunlop Direzza Sport Z1 Star Spec would be a good choice price/performance in the 215/40/17 size. At the end of the day, the $ half grand $ question is... do you think I'm there, or do you think of something better? Thanks again
Old Mar 14, 2010 | 05:54 PM
  #199
Folic Acid 9
I am running 235/40/17's but I have no suspension mods.
Old Mar 14, 2010 | 07:33 PM
  #200
mini coop's Avatar
mini coop
Dan, I'm looking at circuit 10, circuit 8, torque, fighter 8, and group n models of Rota. Which of these Rota models fit Mini's? I have a 2008 base and I am concerned about fitting over the caliper etc. I wish to stay with 15 inch and use 195/60/15 or 205/55/15 tires. Also do the stock Mini center caps work on Rotas? Do you include shipping, mounting hardware (lugs and centering ring)? What about tax? Thanks I'm seriously loking at Rota for my car.
