Suspension Helix R56 Coilover installation
Old Feb 28, 2007 | 11:34 AM
Helix13mini's Avatar
Helix13mini
With a lofty 9 miles on our new R56, we tore apart the suspension to see what it looked like.
The rear stuff is geometrically the same as the R53, with the only major difference being the aluminum trailing arms. There is also a bushing at the bottom of the dampeners that fits into the trailing arm that will be required if you install aftermarket dampeners or coil-overs.
The front is a bit different, with a new subframe geometry, as well as new strut tops (bearings). The big news is that the new strut tops are now camber adjustable (although not much adjustment is available: I would guess half a degree). They are not the same shape or bolt pattern as the 53s, so new camber plate tops will need be manufactured.
The rear swaybar seems to be exactly the same as the R53s. I'll confirm that later today when I try to install one. Rear control arms seem to be exactly the same as well.
While the stuff was apart, we of couse had to try fitting stuff on the car so we went about installing a R53 coilover setup. It's not a direct swap but with a little persuation, we were able to get it done. The biggest problem was fitting the stock swaybar drop links. With the new angles of the subframe, it looks like lowered cars will have an issue of the drop link smashing against the lower control arms. If I were smarter, I would be able to tell if this is true for all lowering springs or just the coil overs that we installed, but the links were too long. I did quick measurements and am pretty sure that the REAR links from the R53 will do the trick. I'll confirm that later as well.
Here's how it sits now, and after lunch I'll play with it some more.
Other interesting notes are that there is no flange after the second cat, and therefore producing a 'cat back' exhaust will involve either cutting and flanging a la BMW aftermarket exhausts, or designing an exhaust with the cat included (yikes).
Old Feb 28, 2007 | 12:06 PM
JuniorMint's Avatar
JuniorMint
This is all good stuff I've been waiting to hear. It sucks that the camber plates wont transfer but the possibility of the coilovers is good news, the end link deal doesnt seem like that big a set back.
About the exhaust, that sounds like it going to be a pain. So the new exhaust has two cats, a resi, and a muffler. Knocking some of those off should make some nice improvements, a full turbo back is looking pretty nice.
Old Feb 28, 2007 | 12:14 PM
rubyred3's Avatar
rubyred3
lowering really helps the look of the R56, it doesn't look as tall and goofy anymore. . .
Old Feb 28, 2007 | 12:26 PM
Dr Obnxs's Avatar
Dr Obnxs
Thanks for the tidbits
of information. Now, get out that sawzall and really mod the sucker!
Matt
Old Feb 28, 2007 | 03:06 PM
Helix13mini
Okay, more info:
the R53 rear sway bar installs and fits perfectly: no changes needed there. It's actually a little easier installing it compared to the old cars because there's less exhaust shielding and junk to slide the bar by.
The drop links for the front sway bar was more involved: I thought that I could use the shorter ones from the rear of the old car, but discovered, feeling kind of stupid that the ball joints point in the same direction in the back. In the front the drop link ball joints point in opposite directions. So I cut one of the ball joints off of the rear swaybar link (and no, good Dr., I didn't use a Sawzall; I used a cutting wheel ) and welded it the opposite way. Stop groaning you purists, I'll bet money that weld holds for the life of the car: remember that the drop links have mosly longitudinal load, not lateral. It looked like this:
It works excellently and has full range of motion. I still have to play with the heights of the car and corner weigh, but that's for another day. If I get a chance tomorrow, Big Brakes .
Here she is:
Old Feb 28, 2007 | 04:27 PM
Ralph@Helix's Avatar
Ralph@Helix
I'll make sure we get those BBK's in tommorrow Eric
Old Feb 28, 2007 | 04:37 PM
Tüls's Avatar
Tüls
Turbius Maximus
ha ha! awsome stuff guys... nice job being hard core about stuff... as you well know... that's what R&D is all about!!
Old Feb 28, 2007 | 05:12 PM
cooldaddy's Avatar
cooldaddy
that car is starting to look really nice, great job...
Old Feb 28, 2007 | 05:23 PM
JuniorMint's Avatar
JuniorMint
looking good
Old Feb 28, 2007 | 07:12 PM
MX100's Avatar
MX100
looking good!
now get on the short shift kit!!
please.
Old Feb 28, 2007 | 07:23 PM
Maxicooper's Avatar
Maxicooper
Sweet ride.
Old Feb 28, 2007 | 08:22 PM
mistro's Avatar
mistro
don't forget us R53's...
Old Mar 13, 2007 | 05:13 PM
AZMCS's Avatar
AZMCS
Wow. I may actually get excited about the R56 if you guys keep this up.
Old Mar 31, 2007 | 06:03 PM
vdubdoug's Avatar
vdubdoug
I actually drove the Helix r56 today and all i can saw is WOW. Aside from the Styling shortcomings (Side grilles, and center console), it is an awesome car. it goes like Stink, and handles and rides great. Plenty of power, and it just feels smooth with a bit of harhness.
i can see one of these in my Future.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
