Suspension Pilo Racing Custom Coilovers Coming Soon
Old Aug 15, 2005 | 03:59 PM
MiniPilo's Avatar
MiniPilo
I am expecting the first prototype of the Pilo Racing Coilover Next week.
Some features include:
Front and Rear 32 Way Adjustable Shocks
Front Camber Adjustment
Pillow-Ball upper mounts
SAE-9254 Cold-Wound Steel Springs
Adjustable Ride Height
I'll have more info on this coming in the following weeks
Old Aug 15, 2005 | 04:01 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
How is the price gonna look. Congrats on putting this together
Old Aug 15, 2005 | 04:13 PM
MiniPilo's Avatar
MiniPilo
Hoping to be in the $1000 Range
Old Aug 15, 2005 | 04:18 PM
Tirewarmer's Avatar
Tirewarmer
What brand shock are you using?
Old Aug 15, 2005 | 04:28 PM
onasled's Avatar
onasled
Dan, Spring rates please. Piston diam?
Old Aug 15, 2005 | 05:20 PM
MiniPilo's Avatar
MiniPilo
We are using a custom shock.
The spring rate is 7KG/mm (approx 400 lbs/inch
I do not have the piston diamater as of yet
Old Aug 15, 2005 | 05:37 PM
kyriian's Avatar
kyriian
a lill late to the party dont u think dan?
would love to see pics, any chance to change spring rates front and back? could be a nice challenger to replace my eibach/koni combo
Old Aug 15, 2005 | 05:47 PM
MiniPilo's Avatar
MiniPilo
Not really to late. Now that the car's are getting a little older, and people are buying used etc, these products are still good sellers. I take my time on each product, and make sure that I am happy with the design etc, then I go into production. It's takes some time, and I think this will be a great product.
One that that other kits do not have is the integrated front camber plates. A product that I think is essential. Where others are charging 400 for that alone, ours comes standard.
When I have the prototype, I will get pictures out to you all.
Old Aug 15, 2005 | 09:56 PM
VoiD's Avatar
VoiD
sounds very interesting..
can't wait!
Old Aug 16, 2005 | 09:05 AM
kenchan's Avatar
kenchan
Is the damp adjustment on the side of the casing for the rear?
Is it bound-adjustment only?
Are you going to offer lower spring rates for street?
Old Aug 16, 2005 | 09:21 AM
MiniPilo's Avatar
MiniPilo
It is only single adjustable,
The adjuster is on the top of the rear.
Depending on the demand, I may be able to have diffrent spring rates. What rate would you be interested in.
Old Aug 16, 2005 | 09:58 AM
satay-ayam's Avatar
satay-ayam
Ok, I'll continue the barage of questions :smile:
monotube damper or twin tube?
Old Aug 16, 2005 | 10:13 AM
kyriian's Avatar
kyriian
talking about spring rates... if you ask me i'd take 300 front, 350 back... maybe even more bias to the rear... something like 275/350 would be awesome
Old Aug 16, 2005 | 10:16 AM
kenchan's Avatar
kenchan
Thanks dan.
As far as springs, I think I want something near the H-Sports so
about 250lbs/in area? maybe 300lbs/in max? Are these linear rate
springs?
I like the fact that it comes with pillow mounts so I don't have
to dissassemble my current setup just to install it.
Would you be willing to do a "street version" with:
1. No front camber adjustment.
2. Pillow mounts front and rear.
3. Spring rate 250lbs/in to maybe max 300lbs/in range
and be about in the $700 ball park? or even less?
Old Aug 16, 2005 | 10:17 AM
topgearnut's Avatar
topgearnut
Sounds alot like Megan Racing Coilovers in terms of description - though currently Megan doesn't have a Mini Application.
http://www.optionimports.com/meracoki8924.html
Springs are made of SAE-9254 Steel
- Spring Rates: 8kg Front and 6kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cyliner Design
- Aluminum Brackets
32 Levels of Adjustment
Old Aug 16, 2005 | 12:25 PM
MiniPilo's Avatar
MiniPilo
- Aluminum Brackets
I am working with megan to create the Pilo Racing Coilovers. though they are being built to my spec, and design.
I will be testing every thing, tweaking spriong rates, and then I will be having my final design made.
Old Aug 16, 2005 | 12:35 PM
MiniPilo's Avatar
MiniPilo
It is a monotube design, and they are linear spring rates
Old Aug 16, 2005 | 01:13 PM
satay-ayam's Avatar
satay-ayam
Sounds like a nice setup. Can't wait to see it
Old Aug 16, 2005 | 01:17 PM
oldschool's Avatar
oldschool
Sounds interesting and very silmilar to the D2 and Ksport coilovers currently on the market. Both of these systems offer a choice in spring rates.
I'm interested to know in the total length of the damper and how much adjustability the camber plates and lower mount offer.
https://www.northamericanmotoring.co...ad.php?t=48582
Old Aug 16, 2005 | 01:29 PM
onasled's Avatar
onasled
.......The adjuster is on the top of the rear.......
...bummer....
Old Aug 16, 2005 | 01:41 PM
kenchan's Avatar
kenchan
Originally Posted by onasled
...bummer....
yep... considering coming in late in the game i would've
kinda expected it on the side of the casing, but it's probably
just more cost to build those so defeats the purpose.
oh well, i guess i'll look at the KW's again.
Old Aug 16, 2005 | 02:26 PM
MiniPilo's Avatar
MiniPilo
Adjustments on the side is just a totally diffrent ball game when it comes to building shocks. Unfortionatly, It's something that only a couple mfg's can do. It would be nice, but I feel that for the price and featurs offered, this will be a nice setup.
Old Aug 17, 2005 | 02:33 AM
S1monLM's Avatar
S1monLM
Isnt their coilover design and assemble in Taiwan, I doubt they are DOT approved
Old Aug 17, 2005 | 04:45 AM
MiniPilo's Avatar
MiniPilo
I am not aware of an actual DOT Approval Process for Suspension. Have you checked to see if other suspensions are dot approved, before making that comment? I know there are DOT Approvals for Brake Lines, Head and Tail Lights, as well as tires.
Old Aug 17, 2005 | 09:28 AM
topgearnut's Avatar
topgearnut
I did a little research on the RSX forums - it's sort of a mixed bag of opinions on the Megans. They're mostly in competition with Tein SuperStreets and the D2's that I posted about earlier. A budget coilover which gives a decent amount of performance for the money. Once nice thing about the Megans is that if it includes the upper pillow ball - it would place it just ahead of it's competition. But if your serious about tracking your car - they suggested saving your money for a higher quality coilover - ex. Tein Flex Line or Tanabe - probably the Bilsteins in our case - since we lack alot of JDM manufacturer support for our cars :(
I don't have a bottomless budget like some peeps on this forum so I'm looking forward to what options are gonna be on the table in the next few months before I lay my hard earned money down.
As for being made in China - I think alot of items asides coilovers are being farmed out to China, Taiwan, HK - whatevers. In fact some JDM companies market - "made in japan" - gee kinda like "made in the USA" on their sites to keep rumors at rest.
nuff said for me
-TopGearNut-
