Suspension Something rattling after lowering
Old May 27, 2005 | 12:52 PM
SuprCooperS's Avatar
SuprCooperS
I installed a set of Tein S lowering springs on my car and when i turn the wheel to the right and i am doing more than 5mph, there is something rattling on the front driver side. ANybody have any thoughts? I am taking it in for an alignment, think that will fix the problem??
Old May 27, 2005 | 12:56 PM
minimonkey's Avatar
minimonkey
Alignment might be the problem. I recently lowered mine, and they did so a complete alignment. But from what you discribe, that rattling may go away after getting it aligned.
Old May 27, 2005 | 01:15 PM
onasled's Avatar
onasled
First guess would be a loose drop link.
Old May 28, 2005 | 04:18 AM
SuprCooperS
many thanks to everyone who gave thier advice, i get it aligned today and will analyze the situation further after that
Old May 28, 2005 | 10:15 AM
kenchan's Avatar
kenchan
my guess is that it's still rattling...
check you endlinks as mentioned above. also might want to
check brake/abs line brakets if they were put back correctly.
Old May 28, 2005 | 04:54 PM
JCampos's Avatar
JCampos
Exactly what I was going to say.... you probably just forgot to tighten up one of the endlinks. If thats not it, make sure that you arent getting any rubbing anywhere.
Old May 28, 2005 | 05:11 PM
onasled's Avatar
onasled
Originally Posted by JCampos
Exactly what I was going to say.... you probably just forgot to tighten up one of the endlinks. ......
..... yea, sure ......
Old May 28, 2005 | 06:09 PM
JCampos's Avatar
JCampos
haha, actually I was... I forgot to do it myself once
Old May 28, 2005 | 07:25 PM
onasled's Avatar
onasled
... me too .... Lucky I caught it before I left the driveway.
Old May 29, 2005 | 10:40 AM
SuprCooperS
I couldn't get the alignment done the other day, so i have an appointment for tommorow, memorial day , my day off. But I took off the wheel and took off, then retightened the end links and it still makes the sound. I also made sure the abs, and brake lines were correctly placed. My friend thinks something is rubbing against my brakes. Any thoughts on this? BTW, thanks for all your help once again everybody I am kind of new to all this.
Old May 29, 2005 | 02:14 PM
gowest's Avatar
gowest
I find that many people do not get the top strut nut tight enough when using hand tools and the result is a rattle. I recommend an air wrench to tighten this nut if nothing else.
Old May 29, 2005 | 06:33 PM
onasled's Avatar
onasled
...ouch, .... not great advice here.
Old Jun 2, 2005 | 10:56 AM
SuprCooperS
thanks everyone for your input. i got the car aligned and it runs like a champ, the mechanic said that the brake backing air intake was loose and that was what was rattling, who would have thunk it???
Old Jun 2, 2005 | 04:39 PM
JCampos's Avatar
JCampos
Actually, thats the way it should be done, just by someone who knows what they are doing. Or you could take a torque wrench to em once they are back in the car.
ToyCar
Nov 19, 2023 05:20 AM
rob&JCW
Oct 9, 2015 11:12 AM
rob&JCW
Sep 10, 2015 12:06 PM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
Sep 8, 2015 11:37 AM
