Suspension Thoughts on lowering springs on stock setup?
Old Mar 6, 2016 | 05:39 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
I was considering coilovers but was just curious on hearing if anybody has lowering springs on stock setups?
I was thinking about lowering an inch or less. Can the stock parts handle this? Im not going to track it at all, just normal daily driving
Old Mar 6, 2016 | 06:20 PM
toyopet's Avatar
toyopet
1 inch is fine. I would wait until swift has a set for the F56.
Old Mar 6, 2016 | 09:35 PM
honderpilot's Avatar
honderpilot
I have nm springs on stock suspension
Old Mar 7, 2016 | 03:57 AM
Mini_Vinnie
Moderator
Ok great. I always did this on my Subarus so I figured I'd get opinions here. I was looking to get springs and I might as well replace the rear sway bar since everything will be off back there
Old Mar 7, 2016 | 09:13 AM
vetsvette's Avatar
vetsvette
Moderator
MiniMania has a kit that includes everything.
NM spring, NM RSB, and NM adjustable control arms. I'm leaning towards that myself.
Old Mar 7, 2016 | 12:58 PM
NM springs
B46/48 (2.0T)
Front: 33mm (1.30") & Rear: 31mm (1.22")
B38 (1.5T)
Front: 30mm (1.2") & Rear: 30mm (1.2")
or the H&R ( 1.1" Front / 1.1" Rear ) ones. Depend on the drop.
https://www.ecstuning.com/Mini-2014-...nsion/Springs/
The NM are one BO right now but should be coming back soon.
Old Mar 7, 2016 | 04:29 PM
Mini_Vinnie
Moderator
NM springs
B46/48 (2.0T)
B38 (1.5T)
Awesome, thank you! I was looking at the H&R ones but I didnt know if they fit my Mini. There is no 2016 option when I select the year
Old Mar 7, 2016 | 04:33 PM
honderpilot
I have nm and I love them, I'd strongly consider them over h&r
Old Mar 7, 2016 | 07:54 PM
Mini_Vinnie
Moderator
Can you post s picture or send me one?
Id love to drop it that much but Minnesota winters can be interesting to say the least
Old Mar 8, 2016 | 04:53 AM
Welcome,
Yes we will be updating the site very soon.
Old Mar 8, 2016 | 06:59 AM
honderpilot
Pm me an email. It isn't that much lower but they look better in my opinion and I've heard that other owners from previous gen mini's have liked nm better.
Old Mar 8, 2016 | 07:39 AM
vetsvette's Avatar
vetsvette
Moderator
I've heard nothing but good things about the NM springs. It's probably the route I'll take if I can't scrape up the cash for a good coil over system. I believe the NM springs would be a good match for my sport suspension.
Old Mar 8, 2016 | 12:37 PM
marshun's Avatar
marshun
I had the H&R for 1 month. Couldn't stand the ride. Took it back and had NM installed and have been pretty happy. Maybe the H&R are not as bad if you're not running run-flats.
Old Mar 8, 2016 | 04:11 PM
Mini_Vinnie
Moderator
Ok, sounds like NM for sure!
Thanks guys!
Old Mar 9, 2016 | 07:10 AM
Welcome.
Old Mar 10, 2016 | 06:43 AM
randomquickness's Avatar
randomquickness
I'm quite happy with my NM springs and 25mm rear sway. Paired with the stock sport suspension struts it rides great. I was planning to replace them with coilovers at some point but since I like the ride height I'll probably just swap in some Koni yellows around 50k miles
Old Mar 11, 2016 | 12:37 PM
Mini_Vinnie
Moderator
That's exactly what I was thinking about doing too
Old Mar 11, 2016 | 02:03 PM
vetsvette's Avatar
vetsvette
Moderator
^^^ Ditto ^^^
Madmini20
Feb 28, 2016 08:11 AM
rossgo_R53
Feb 22, 2016 11:38 AM
Wertles
Feb 11, 2016 07:55 AM
EnormousMini
Feb 10, 2016 09:30 PM
Antberrie
Feb 9, 2016 01:33 PM
