Suspension Do I really need camber plates?
Old Aug 28, 2015 | 06:35 PM
ki7hy's Avatar
ki7hy
Just trying to spec out my upgrades and figure out my costs.
Here's the plan.
NM RSe12's with 40 series tires
BR Racing Coilovers
I plan to lower it to the top of the tires to eliminate all gap so maybe 5mm or so into the height of the tire so it just goes lower than the gap. No lower because I have some speed bumps to worry about.
Those rims are only 7.5" wide with 45et, should work out fine with that setup going just that low without any need for plates and no rubbing right?
Thanks for the info ahead of time. Want to be sure this will work before I drop $3500.
Old Nov 17, 2015 | 08:59 PM
blue al's Avatar
blue al
Getting the polyflex front camber adjustment bushes fitted this week,
wheels 7.5 x 17 ET 43, rubber 215/45/17, sorry but no plans to lower at the moment
Will give you some feedback around the end of the year when they have done a months work on our potholed Uk roads
As it might be a cheap option for you
Old Dec 20, 2015 | 06:39 PM
randomquickness's Avatar
randomquickness
well there are no plates that I'm aware of and almost $200 for .75* of camber is a lil pricey. I think you'll be fine, worst case you'll rub the plastic inside the fender and it will clearance itself.
Old Mar 13, 2016 | 08:45 PM
Bster13's Avatar
Bster13
Hello,
Do you have any feedback for the adj. bushings?
There was concerns about a lack of clamping and the adjusters moving around.
Thanks!
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
