Suspension NM Engineering torque arm insert install/engine bushings
Old May 13, 2012 | 04:13 PM
  #151
JPMM's Avatar
JPMM
found the rattle, it was a cable for a radar detector, behind the mirror ,no longer used, tied it in a knot for now
r
Originally Posted by ScottG
Hey JPMM,
The vibration you are most likely hearing is the secret glove box....mine does it also, but only first thing in the morning....The BSH arm will break in a little....but here's a little trick for anyone that wants a little more comfort from the BSH arm....I drilled (4) 5/8" holes thru the rubber bushing to remove a few notches off the 90 durometer reading of the bushing. I'm sure it's not recommended my BSH but it hasn't caused any issues on mine. Drll 2 holes on the horizon of the center of the lower bolt hole and 2 vertically....it helps a little on the sound & vibration. Also, NM is redesigning their inserts to include a stainless steel plate on either side of the bushings to stop them from squeezing out....they should be out shortly.
Old May 16, 2012 | 07:46 PM
  #152
gregsmini's Avatar
gregsmini
Installed the NM Torque Arm Insert over the weekend along with the Helix FMIC. Car runs and shifts great! My daily commute is 60 miles round trip and now have driven three days. Drives like a different car, great improvement
Old May 16, 2012 | 08:52 PM
  #153
TerminalVelocity's Avatar
TerminalVelocity
Definitely a big thumbs up! That FMIC is on my short list of ever growing mods! I know it's only been a few days but do you think it was worth the money?
I have the NM insert and I know how well my Coupe responded to it. Using "bang for the buck" as a factor I'd say it's probably the best mod I've done so far.
Old May 17, 2012 | 03:46 AM
  #154
gregsmini's Avatar
gregsmini
Well, that's a good question. I don't know where I'm going with future mods, but I think the FMIC would be part of the foundation of solid car if I choose to build from here. I'd like to buy the Accessport, but right now that's not in the budget. All I can say is right now the car is running great and some of it seems to be due to the FMIC.
Now that said, I want to measure the improvement in meaningful way. I have an account at www.Fuelly.com where I have tracked over 28k miles and I am averaging 31.7 mpg. I'm anxious to see what happens with my fuel mileage over the hot summer. My daily commute is 60 miles round trip with over 40 miles on I-476 outside Philly.
You can go to the Fuelly.com site and track my mileage, or better yet, track your mileage too. My account is the same name as here.
Old May 17, 2012 | 08:24 PM
  #155
TerminalVelocity
Haha, I realized after I wrote that that the question I posed was a bit premature. It was late. I'm looking forward to hearing how it goes down the road and I think it's a great mod when looking toward future power upgrades as you mentioned. That's my plan anyway.
THanks for the link. I'll have to check it out!
Old May 18, 2012 | 04:13 AM
  #156
TazMinianDevil's Avatar
TazMinianDevil
I did this last night along with the front bushing too. Its a snap to do the NM insert, the front bushing on the other hand... PITA. Had to setup a C-clap press to get it out. Minor vibration, but nothing too bad. No more missed 3rd while making lefts and accelerating hard!
Old May 25, 2012 | 09:28 AM
  #157
dboard7's Avatar
dboard7
So I got the "fix" from NM for the bushing coming out and after I tighten it down it barely touches the bushing defiantly does not push it back in or stop it from coming out, anyone else have this issue?
Old May 25, 2012 | 11:46 AM
  #158
JPMM's Avatar
JPMM
see post # 130
heres my solution works great
Old Sep 6, 2012 | 10:07 AM
  #159
absoluteczech's Avatar
absoluteczech
any updates on peoples NM insert coming out? I'm thinking about buying it, but dont want to have problems with it
Old Sep 6, 2012 | 10:19 AM
  #160
MiniBOL's Avatar
MiniBOL
I've had mine for over a year and no problems. 👍
Old Sep 6, 2012 | 10:22 AM
  #161
JCW Jet's Avatar
JCW Jet
They originally had a slight issue with the drivers side bushing squishing out a little, but the metal plate that now comes with the bushings seems to hold it in IF you put a slight bend in the plate before you install it. Just installed mine, bent the plate about a 1/4" inwards, torque it down properly and it holds it perfect. Found the best prices at this new MINI Site....very cool:
http://shop.MiniDynamics.com/NM-Engi...t-NM228856.htm
Old Sep 6, 2012 | 10:26 AM
  #162
madmaxxed's Avatar
madmaxxed
I purchased and installed mine before NM updated the design with the support bracket. Mine has been installed for over 6 months without any issues. I did contact NM and they sent me the bracket at no charge. I don't see that backing out at all with the bracket on. Worthy upgrade!
Old Sep 6, 2012 | 11:02 AM
  #163
TerminalVelocity
Nearly a year for me. No support bracket. No problems. Even if they do bulge a bit it won't hurt anything since you haven't actually removed anything from the car by installing them. However the more solid the attachment the better the performance.
Old Sep 6, 2012 | 11:49 AM
  #164
slinger688's Avatar
slinger688
Had mine approx 4 years with no issues.
Old Sep 15, 2012 | 02:16 PM
  #165
Ironmansoltero's Avatar
Ironmansoltero
just installed mine during a lunch break at work lol, cant wait to get outta here and rip through some curves
Old Sep 16, 2012 | 07:40 PM
  #166
conrad0102's Avatar
conrad0102
You're going to love the decrease in torque steer
Old Sep 23, 2012 | 07:38 PM
  #167
RobMuntean's Avatar
RobMuntean
I have a question. It seems one my driver side my torque arm insert may be loose. During cold driving or the car being unwarmed it seems to rattle when the road isn't smooth at all. I am guessing it might be the issue cause my shocks don't seem to be the issue. Ever since I did get my TAI put in it seems like that's been the issue for the last 10K. Just wondering if anyone else had this happen to them?
Old Sep 24, 2012 | 08:25 AM
  #168
conrad0102's Avatar
conrad0102
Did you do the install yourself? I did mine and it took like 15 minutes and I have had no problems what so ever.. wouldn't hurt to take the time to maybe just re-install it and make sure you have the right torque and all.
It's such an odd thing that people experience "rattling" The part I installed was just an insert to a factory made part and was semi squishy so I have now idea where any type of rattling would come from except perhaps improper install. or Maybe if you replaced the whole torque arm and it just wasnt the right size.
It's funny though. Everytime someone posts about the torque arm I get concerned and go check on mine and make sure its still under there lol.
Old Oct 5, 2012 | 02:39 PM
  #169
ballyrick's Avatar
ballyrick
Torque arm inserts
Just had NM engine torque arm inserts (sold/shipped by Way) installed this afternoon. Noticeable improvement in handling, shifting and throttle response.
An excellent, simple to install modification, especially considering the price.
Ballyrick
Old Oct 21, 2012 | 12:40 PM
  #170
Ta87's Avatar
Ta87
Agreed! Just installed it this morning and I have to say, it's definitely an improvement.
I was skeptical before buying it but thought, "Oh, what the hell- it's 60 bucks." Best 60 dollars spent on the car.
Old Oct 21, 2012 | 12:44 PM
  #171
Ta87's Avatar
Ta87
I forgot to mention, I did my install on a 45 degree morning. I think that facilitated the install. I read about some of you guys having to use a mallet to force the arm back to its original position so I just wanted to bring that up now that the weather all around should be cooling down.
Old Oct 21, 2012 | 12:50 PM
  #172
conrad0102's Avatar
conrad0102
Yeah my brother got mine for me for Christmas. Best Christmas present ever. If you haven't already I'd look into the resonator delete
Old Oct 21, 2012 | 01:02 PM
  #173
Ta87's Avatar
Ta87
Already did! Have 2nd Cat and Resonator removed. I'm in the process of uploading for another user asking about the sound.
I'm new to the world of cars but I'm learning a ton thanks to you all! Cheers!
Old Nov 8, 2012 | 10:59 AM
  #174
jman311's Avatar
jman311
I (until recently) had the NM mount installed on my '10 R56 automatic, but took it out because of excessive vibration when at a stop. I had it on the car for well over a year, and I swear over time the vibrations slowly got worse, to the point my brain felt like it was rattling in my head. Not sure if the maybe the mount material stiffened/hardened over time (Arizona heat?), or perhaps the engine itself just vibrates more now.
Having removed the mount, I really do miss the benefits of having it installed, but I found myself eventually shifting into neutral at every. single. stop. I am thinking about trying the softer yellow Powerflex mount, but I'm wondering just how much less the vibration will be ... and if it turns out to still be too much, could the mount(s) be modified (drilled?) to find the perfect trade-off between performance and sanity?
A similar question has been posted in the Gen 1 forum regarding the Powerflex mount, but I put this here being I have a Gen 2.
Old Nov 8, 2012 | 12:15 PM
  #175
JackMan017's Avatar
JackMan017
I have an auto too. For the reason you explain is why I'm still hesitant doing this mod. Sure the car will torque steer less, but I just don't think I'm prepared to handle a constant vibration at idle. Was your vibration always at idle? Idle only or driving too?
