Suspension NM Engineering torque arm insert install/engine bushings
Old Apr 4, 2011 | 07:28 PM
  #51
claud's Avatar
claud
It's been a couple of weeks since the install and the NM has smoothed out the shifts and quickened the response. No change in install for 2011 MCS.
Old Apr 8, 2011 | 08:34 PM
  #52
SpyVsSpy's Avatar
SpyVsSpy
Just installed my NM Torque Arm bushings. I had the older trianglar torque arm and initially ordered the wrong ones for an '07. I ran the car hard and did not notice any additional vibrations. My initial assessment, it appears to reduce the torgue steer greatly. The install was easy, as previously posted by someone else, 25 minutes once it is raised. Think this was an excellent investment
Attached Thumbnails NM Engineering torque arm insert install/engine bushings-torque-arm.jpg   NM Engineering torque arm insert install/engine bushings-nm-torque-arm.jpg
Old Apr 8, 2011 | 08:42 PM
  #53
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Originally Posted by MotoMando
How much torque (no pun intended) do you tighten the bolts after replacing the inserts. Can someone verify that this would fit a 2011 MCS?
Armando.
Yes they will fit the 2011, you just need the round NM torque bushing.
Glad you got em so fast. You've got one of the few triangular mounts.
Old Apr 15, 2011 | 10:44 AM
  #54
MotoMando's Avatar
MotoMando
Installed Successfully
I just installed the bushings. Took me an hour since I didn't know what I was doing. I initially was trying to figure out how to remove the existing rubber inserts. Doh! Turns out you just place the new ones on top. Next, I couldn't figure out how to shimmy the assembly back into place. Double doh! I tried to lift the engine. Nope. I tried to lift with a jack. Nope. I tried to push it back towards the back. Nope. I had to pull it forward. Make sure you also pull the engine towards the front when trying to align the bolt.
I forgot to take pictures since I was too busy trying to remove the original inserts. Don't do that.
Old Apr 15, 2011 | 11:07 AM
  #55
Short Wait's Avatar
Short Wait
I spent about 10 minutes trying to figure out how to remove the original bushing without damaging it when I realized what to do. I'll bet quite a few of us have done this but are too embarrased to admit it. lol
Old Apr 15, 2011 | 02:03 PM
  #56
MADnFL's Avatar
MADnFL
I did mine yesterday. I was up on Rhino ramps, trying to get enough leverage to get the bolts loose, then I had to get a 16mm 1/2in drive socket(Autozone) to torque the bolts to 80ft lbs. I sprayed some WD40 on the inserts. It was not to bad and took less than an hour. Now I will tell the wife that some jack stands and a hydraulic jack would make a great birthday present
Old Apr 15, 2011 | 06:14 PM
  #57
SpyVsSpy's Avatar
SpyVsSpy
Yup, I am initially guilty. I loosened the forward bolt and removed the back bolt and swung down the torque arm. I pulled my motor forward and used a big flat head screw driver as a pry bar to move it back into place.
Old May 8, 2011 | 04:04 PM
  #58
Alexander!'s Avatar
Alexander!
recommended and very easy to install on a '11 S. I used a bottle jack and a board to hold up the engine to make it easier to bolt back in. Tightened bolts to man-torque specifications.
-Alex
Old May 12, 2011 | 10:16 PM
  #59
darthhen's Avatar
darthhen
From reading all the posts on this, I just ordered a set from Way
Old May 13, 2011 | 01:27 PM
  #60
AudioGuy's Avatar
AudioGuy
Does this do anything for an automatic car? Or does it just help out manual tranny equipt?
Old May 13, 2011 | 01:47 PM
  #61
VMCMDN's Avatar
VMCMDN
Just ordered my set yesterday, they are now on their way
Old May 13, 2011 | 10:38 PM
  #62
Eclipse11S's Avatar
Eclipse11S
+1 Anybody ????????
Old May 14, 2011 | 05:25 AM
  #63
10Zero's Avatar
10Zero
Originally Posted by Eclipse11S
+1 Anybody ????????
I put it on my 2010 AT, and it was a definite improvement, but I didn't like it. The reason I didn't like it was because when the AT in drive (or whatever gear), the RPM's idle slightly lower than a MT at idle...and this caused an excessive amount of feedback vibration through the car. If you can tolerate that, then it's a good mod.
Old May 14, 2011 | 08:33 AM
  #64
Eclipse11S's Avatar
Eclipse11S
@ 10Zero... Thanks for your Feedback.
Old May 14, 2011 | 10:41 PM
  #65
MADnFL's Avatar
MADnFL
My 2011 MCSa doesn't have any problems except answer the go peddle a bit faster in non sport mode.
Old May 15, 2011 | 10:30 AM
  #66
WayMotorWorks
Vendor
On AT cars this usually goes away after 2 weeks and the bushings settle in. But this can also happen if the bolts for the mount are over tightened.
Old May 16, 2011 | 12:27 PM
  #67
jman311's Avatar
jman311
I experienced added vibration when I first put the bushing in too, mostly at idle ... but as Way stated it does reduce over a few weeks time. After the break-in period I think my vibration is still slightly higher than it was pre-mod, but not enough to bother me (like it did on day 1 after install). Definitely worth the trade-off for me.
Non-sport mode is actually usable now!
Old May 16, 2011 | 04:21 PM
  #68
10Zero's Avatar
10Zero
Ah...good to know. Wish I knew that before getting rid of it. I torqued my bolts to spec, but I only ran the bushings for about 3 days (and not very many miles) before deciding it wasn't for me...and I sold my bushings.
Might have to try it one more time, because it sure felt nice when accelerating.
Old May 20, 2011 | 07:05 PM
  #69
pocari's Avatar
pocari
most of you will laugh at me but im wondering how much a shop would charge to install this
Old May 21, 2011 | 11:28 AM
  #70
cop1406's Avatar
cop1406
Way charged me 20 bucks today at AMVIV. Will report after some miles.
Old Jun 4, 2011 | 06:54 PM
  #71
Augie05's Avatar
Augie05
You guys still liking this mod? Any updates for the new ones just installed?
I would like this if it really helps reduce the torque steer.... my biggest complaint with the car.
Old Jun 4, 2011 | 08:29 PM
  #72
slinger688's Avatar
slinger688
Some people have reported that it does. When I put mine on, I think it did almost nothing for the torque steer but it did help power transfer with some added vibrations. Some do believe that torque steer is caused by the steering geometry and some flexing of the front wishbone bushings which is logically likely. If that is the case, I am at a loss to explain why these inserts would help with torque steer. Maybe someone who knows the suspension geometry can help.
When I put on my AST coilovers with front camber plates (with -2.1 front camber) and changed my ride height (1.2" lower), I feel that that change did remove quite a bit of the torque steer. So ride height and changing the suspension geometry seems to help.
Old Jun 4, 2011 | 09:27 PM
  #73
n1tr0's Avatar
n1tr0
lowering my mini w/ the prokit springs almost completely eliminated the torque steer... of course having Jan add a ton of HP and a ridiculous amount of torque brought it back ... fwd + power = torque steer
Stiffening up your mounts will help get more of that power to the ground effectively
Old Jun 23, 2011 | 03:50 PM
  #74
MiniBOL's Avatar
MiniBOL
Drove to NM and got mine today. Will install next week when I change the oil and install the NM springs. I'm excited!
Old Jun 23, 2011 | 06:17 PM
  #75
MADnFL's Avatar
MADnFL
80ft lbs
