Door lock problems
Old Feb 12, 2012 | 03:12 PM
  #376
chubster's Avatar
chubster
here's a pic of my 04's door insides....just not sure if thats what its supposed to look like
Old Mar 13, 2012 | 08:50 PM
  #377
tga3's Avatar
tga3
Originally Posted by tga3
I have same symptoms reported by edkim, pimpedout97x, and dustinhxc on page 4 of this thread:
  • Driver's door will not unlock with the remote or dash switch. (I have to use the key in the driver's door to open it).
  • Driver's door will not lock with the switch or at speed
  • HOWEVER, the driver's door will lock with the remote.
Can someone confirm that this is a legitimate failure mode for the actuator? I assumed if it failed, it wouldn't power lock at all, not sort of work.
I don't want to buy the part and rip apart my door until I'm confident this is the problem.
Wow! On June 09 I put up this post. I wait 9 months to order the part, and then let it sit on a shelf in my garage for 2 years (!) before I get tired of unlocking the driver's door with my key and change it (what a PITA, BTW).
Anyway, just to close the loop (should it be of help to anyone), it was the driver's side door lock actuator/latch, part #51.21.4.433.804 (or 51.20.0.556.768). Changed it tonight and my power locks work normally again.
Old Mar 16, 2012 | 12:59 PM
  #378
Winston03's Avatar
Winston03
Driver's side - 127K Miles. Is it easy to get to the plastic cable piece to reattach it?
Old Apr 3, 2012 | 08:50 AM
  #379
tvacc's Avatar
tvacc
Drivers side, 50K miles.
Replaced the cable, worked till I put it back together. Now does not work. Will have to open it back up.
Old Apr 3, 2012 | 09:20 AM
  #380
norm03s's Avatar
norm03s
Something slipped out of place.
Old Apr 16, 2012 | 06:53 PM
  #381
CRRIKEY's Avatar
CRRIKEY
found this, im going to give it a try. hope everyone benefits from it as well
http://www.instructables.com/id/Repa...or-L/?ALLSTEPS
Old Apr 17, 2012 | 10:33 AM
  #382
CRRIKEY's Avatar
CRRIKEY
just gutted mine and cleaned the motors, worked like a charm!
Old May 5, 2012 | 04:50 AM
  #383
MeBoosta's Avatar
MeBoosta
Happened to me as well man. I pulled the door panel off and placed the anchor back in its original place.. Nothing broke, it just came out of place.. Strange isn't it?
Old May 5, 2012 | 06:17 AM
  #384
MeBoosta's Avatar
MeBoosta
Ok guys, from reading this thread its safe to say that door lock issues are common in these cars..
The door lock actuator and window regulator on my passenger door both went awhile ago. I din't bother getting into it because I knew that replacing both at once was going to cost me an arm and a leg. Also, my window regulator would work sometimes, it wasn't permanetelly "broken", same with the door actuator. I could never unlock the car using the cabin controls nor the key, but then again I can lock the door using the key.
What I did--- So I decided to pull the door panel off and take the car into one of those drive through car washes, I wasn't too surprised to find water dripping inside the door... Chances are that moisture is creating resistance both on the actuator and regulator..
What the is causing the problem---
Well, at least on my car I'm blaming it all on the window seal.. I'll replace it and let you guys know if water still leaks inside...
2004 R53
Old May 12, 2012 | 12:38 PM
  #385
Imnuts55's Avatar
Imnuts55
2004 Mini Cooper S driver side door.
Old May 25, 2012 | 10:34 AM
  #386
razz's Avatar
razz
2002 MCS April 02 build, drivers side, 80k miles, will lock but not unlock.
Old Jun 12, 2012 | 11:14 AM
  #387
JEC's Avatar
JEC
Both of the cables on the driver's side door latch are off. I can fix this if I could get the door open but I can't remove the panel without opening the door and I can't open the door till I fix the cables. How can I get the door open or remove the panel if the door is closed?
Old Jul 17, 2012 | 02:27 AM
  #388
hawaiianmini's Avatar
hawaiianmini
2010 with15,000 miles. Passenger side.
Old Jul 17, 2012 | 05:47 AM
  #389
gknorr's Avatar
gknorr
This happened to me on the passenger side. I think I somehow was able to remove the panel with the door closed by sliding the seat to certain locations. It still ended up damaging one of the clips that holds the panel on. You can also remove the seat to make more room if necessary - it's only 4 torx bolts (I think T-40s). If you do remove the seat, disconnect the battery before disconnecting the airbag connector.
Old Jul 17, 2012 | 10:46 AM
  #390
Winston03's Avatar
Winston03
Driver's side will not work with the key fob or the panel "unlock". I can lock it from the inside by pushing it down and unlock it with 2 actuations of the handle. It will lock from the outside using the key in the slot, both unlock and lock. The dealer quoted me $400.00 without even looking at it. There must be a lot of similar problems. I can Open/Close it many times for $400.00.
Old Jul 17, 2012 | 11:05 AM
  #391
gknorr's Avatar
gknorr
Another dead lock actuator. You can get a new one for a little over $100 from Classic MINI and put it in yourself!
There's also a how-to on fixing a broken actuator, but it's pretty time intensive and there are a lot of small pieces to keep track of.
Old Jul 22, 2012 | 03:32 AM
  #392
Wagnbat's Avatar
Wagnbat
My passenger side went out about 3 years ago, at about 30k.
Pulled off the panel, put tension on cable (could still hear actuator TRYING to work)... And with tension on the cable it worked fine. So I routed the cable around a part in the door it's not normally routed around, and it has worked ever since... Just by adding a bit of tension to the line.
Old Jul 22, 2012 | 07:06 PM
  #393
hawaiianmini
. Dealer will replace door latch under warranty. Windshield washer hose needs to be replaced also, keeps on popping off at the nozzle. Amazing for a car only two years old.
Old Jul 28, 2012 | 09:34 PM
  #394
Bbmatt's Avatar
Bbmatt
So I'm still not understanding how the remote can "lock" the passenger side window, but can not unlock it. When I press the unlock button, I hear something click on the passenger side door, but nothing unlocks.
what do i need to replace?
04, 99k miles.
Old Aug 6, 2012 | 07:30 PM
  #395
moodylewdd's Avatar
moodylewdd
'02 MCS passenger side....114,500 miles.
Old Aug 14, 2012 | 01:40 PM
  #396
Chappy's Avatar
Chappy
'04 MCS 84K, driver's side
Old Aug 14, 2012 | 01:43 PM
  #397
Chappy's Avatar
Chappy
Hey Winston, Did your '03 have AutoLock and if so, does it still work or has it bit the dust too? I have the same problem as you described AND my AutoLock no longer works.
Old Aug 14, 2012 | 01:59 PM
  #398
Chappy's Avatar
Chappy
Originally Posted by anyheck
Everyone who's doing a door lock replacement should take a look at this video:
http://www.youtube.com/watch?v=N9H33ad1UcA
He does a LOT of really informational automotive repair videos, that even if not directly on Minis are applicable in general terms.
Great video, thanks!
Old Feb 2, 2013 | 09:13 AM
  #399
LMarble's Avatar
LMarble
I safety wired my original cable 2 years ago and still working fine. My cable lock also kept popping off. Stainless steel wire loop will keep it for a 5 to 7 years.
I have a 01 bmw X5 that had the same issue in 05, it lasted till 11. The plastic finally disintegrated.
Old Apr 23, 2013 | 02:19 PM
  #400
indiR53's Avatar
indiR53
Passenger side on 04 Cooper S will not unlock with inside toggle but does unlock with a pull of the door handle, autolock and locking with the key both work...does it sound like it's just the cable?
