Door lock problems
Old Feb 20, 2011 | 07:23 PM
  #326
Sheltieladyblue's Avatar
Sheltieladyblue
My husband fixed ours with a mirror and a tube of super glue!Im serious!
Old Mar 1, 2011 | 10:20 PM
  #327
tjmm's Avatar
tjmm
Well I'm new to the forum and my R50. When I purchased it neither remotes worked. Everything locks and unlocks manually with key in the door and the central locking switch. I didnt pay it much mind until now. So if we could recap for a minute. Am I to understand this is an ongoing issue since the 1st gen and has not had a viable solution. If we could summarize what's going on. Is this normally a mechanical issue or electrical? The reason I'm asking is I have access to wiring diagrams and general repair on most vehicles. If we could narrow this down I would be able to have some info available for most as well as correct mine. Thanks
Old Mar 2, 2011 | 04:08 AM
  #328
Walt's Avatar
Walt
I don't think it is an on-going issue that the keyfob remotes never work, but the power locks work OK otherwise. That rules out all the typical mechanical failures within the doors themselves.
Did you buy your MINI used? If neither keyfob ever worked, I would suspect they need to be programmed to your MINI. Wiring diagrams and general repair techniques aren't going to help. You will need to have a MINI dealer program them in for you. That, unfortunately, is not a do-it-yourself job.
Old Mar 2, 2011 | 04:05 PM
  #329
zpnbyu's Avatar
zpnbyu
see message 330
Old Mar 2, 2011 | 04:12 PM
  #330
zpnbyu's Avatar
zpnbyu
I have never had a problem initializing my remotes. It's quite simple, really. Get in your car and lock the doors. Put the key in the ignition and turn to the first position and wait at least 5 seconds. Turn off the ignition and within 30 seconds do the following sequence: press and hold the unlock button, then press and release the lock button 3 times, then release both buttons. Wait about 30 seconds and the doors will unlock and lock. Then reinsert the key into the switch, turn to first position and wait 5 seconds, then turn off and remove. Initialization is complete. If during the process, the doors do not unlock and lock automatically, just start over. Sometimes if you don't use a remote for a long time, you may need to reinitialize it.
Old Mar 19, 2011 | 06:32 PM
  #331
skirule's Avatar
skirule
my far it's ok
MCS 04 106000
Old Mar 21, 2011 | 12:39 PM
  #332
Lukeqotsa's Avatar
Lukeqotsa
03 MCS, Drivers side, 70k
Old Mar 26, 2011 | 03:21 AM
  #333
ALL4CAB's Avatar
ALL4CAB
05 Mini Cooper @ 64K miles driver side - do not remember the breakout as my thermostat was replaced at the same time total $870
Old Apr 4, 2011 | 11:51 AM
  #334
Tinklespout's Avatar
Tinklespout
04 driver side lock died at 57K mi
04 driver side lock died at 57K mi. Might there be a recall?
Old Apr 5, 2011 | 12:06 PM
  #335
markjenn's Avatar
markjenn
Doubtful. There is no safety angle and essentially all the cars that are failing are now well out of warranty so no economic benefit to BMW. I doubt the problem is so widespread or annoying that BMW is going to do the recall just for goodwill.
If BMW won't recall the badly-flawed power steering pump/fan problem (which does have a safety angle), they're not going to recall this.
- Mark
Old Apr 8, 2011 | 10:57 AM
  #336
Tinklespout
door lock problem
So is there a synopsis yet on how to repair this? I hate buying parts I don't need. Thanks a lot?
Old Apr 8, 2011 | 11:02 AM
  #337
gknorr's Avatar
gknorr
Depends on what your problem is. If you can't open the driver or passenger door using the inside handle, you may just to re-insert the door handle cable into the actuator. I had to do this once on the passenger door a year or two before the actuators went bad.
If the power locks don't work at all, you'll need new door lock actuators. Got mine from minicarparts.net:
http://www.minicarparts.net/Nxt/sear...=door+actuator
Old Apr 11, 2011 | 11:36 AM
  #338
Neufusion's Avatar
Neufusion
My driver side door lock went out a while ago and today the inside handle decided to give out as well. I'd be be able to roll down my window and open it from the outside if my window wasn't broken as well.
Yay 100k!
Old Apr 11, 2011 | 11:41 AM
  #339
gknorr's Avatar
gknorr
Yay 100k!
For the window, have you tried banging above the lower speaker on the door while repeatedly pressing the power window switch? Works every time for me! Been like that for a year or two.
Old Apr 16, 2011 | 05:38 PM
  #340
owyangs's Avatar
owyangs
Is the actuator the problem?
My remote locks/unlocks all doors except the driver side. It opens both windows. Console switch locks/unlocks all doors except the driver side.
Driver door opens from inside and outside and can be locked/unlocked with the key.
Is this the actuator?
Old Apr 16, 2011 | 07:04 PM
  #341
gknorr's Avatar
gknorr
Yup - sounds like the actuator to me.
Old Apr 18, 2011 | 01:50 PM
  #342
Neufusion's Avatar
Neufusion
Ya I've tried that but it has never worked for me...
Update: LOL I've tried a bunch of times and it has never worked. I was pulling up to the drive-thru ATM and realized I was going to have to climb out my passenger door so I hit it and clicked the switch and it instantly rolled down. haha Gotta love these MINIs - They sure have character.
Old Apr 19, 2011 | 07:09 AM
  #343
cristo's Avatar
cristo
Alliance Member
Every once in a while, I'll repeatedly bang on that area while the window is going up,
and again while it's going down, and it seems to keep the window motor happy for
a longer period of time.
I'm thinking it dislodges more crap from the contacts that way.
Maybe so, maybe not, but it seems to be true.
Old May 2, 2011 | 05:22 PM
  #344
james2133's Avatar
james2133
I got a 2005 MCS 55000 miles and the passenger door only unlocks by pulling the handle. None of the electrical methods work... help
Old May 2, 2011 | 05:38 PM
  #345
gknorr's Avatar
gknorr
Another failed door lock actuator. You can get a new one for about $120:
http://www.minicarparts.net/Parts/51_21_4_416_272.cfm
There's not much room in the door to work, but it is definitely a repair you can do yourself.
Old May 3, 2011 | 03:04 PM
  #346
james2133's Avatar
james2133
from all the great post on here that is what I figured that it was but was hoping that I was wrong. Before I spent the money I figured I would seek the genius from you guys. Thanks for the confirmation. Ill order it and yank it out. I have already dove into the door so I'm not to worried. once again thanks
Old May 8, 2011 | 10:43 AM
  #347
Runemtight's Avatar
Runemtight
Me too
05 MCSC right side
Old May 18, 2011 | 10:50 AM
  #348
kek2011's Avatar
kek2011
05 MC 80,000mi. Neither passenger or driver doors will unlock or even unlatch from inside. Pain in the rear!
Old May 26, 2011 | 05:42 PM
  #349
mark malley's Avatar
mark malley
Door and Window!
Both the driver door lock and window have died. 2004 Cooper S- 130,000 miles. Lock works manually, but switch won't unlock driver's door. When door opened window only retracts intermittently. No power windows from inside switch. Hmm?
Old May 29, 2011 | 04:27 PM
  #350
valvashon's Avatar
valvashon
Originally Posted by tga3
I have same symptoms reported by edkim, pimpedout97x, and dustinhxc on page 4 of this thread:
  • Driver's door will not unlock with the remote or dash switch. (I have to use the key in the driver's door to open it).
  • Driver's door will not lock with the switch or at speed
  • HOWEVER, the driver's door will lock with the remote.
Can someone confirm that this is a legitimate failure mode for the actuator? I assumed if it failed, it wouldn't power lock at all, not sort of work.
I don't want to buy the part and rip apart my door until I'm confident this is the problem.
This is exactly what my car is doing- a 2002 MC. Started happening at about 70 or 80k, car just turned 100k. My locks aren't programmed to lock at speed but that's the only difference.
If you look at "volki's" excellent pictures and imagine the actuator with the cover off, there is a gear/lever thing between 4 and 5 that moves as it should when the remote button is pushed but only moves a little with the toggle switch or when unlocking is tried with the switch or remote. Can't imagine what is different about the signal it gets between the two but I imagine being that sensitive means the coil in the actuator is bad.
Can't wait to scrape together the $116 to get a new actuator and have a crack at pulling the old one completely apart- maybe they are repairable!
Val
