Door lock problems
Old May 29, 2011 | 04:43 PM
  #351
gknorr's Avatar
gknorr
Originally Posted by valvashon
maybe they are repairable!
Val
It would be very difficult - I tried to "repair mine" before buying the replacements (so I ended up taking everything apart twice!) Once I had it out, I took a few things apart on the actuator and also sprayed some graphite lubricant in it....to no avail...it's always fun to tear something like that open though
Old Jun 26, 2011 | 06:54 AM
  #352
Luice73's Avatar
Luice73
03 S 64k and my drivers side lock is just about dead. If I click the unlock switch a bunch of times I van get out of the car. Otherwise I have to lower the window and open the door from the outside. It seems to be stuck somewhere in the middle. Also the hatch will not pop open usin the key. I have to use the pull cable under the seat. What is going on!!!
Old Jun 27, 2011 | 10:19 PM
  #353
Johnna's Avatar
Johnna
'05 MCS 92,000 miles. Driver's side door handle locks with remote but won't unlock with remote. Will unlock with key. Latch works from the inside.
I fixed it last night. The solution was to replace the driver's side lock actuator (+/- $150 parts).
Removing the door panel was easy once I figured out the arm rest pad removal.
Removing the old actuator was tricky as it is a VERY tight fit. I had to loosen the window rail guide and slide it over to make room.
Hooking up the actuator end of the inside lock release cable was very tricky. I had to put a small clamp on the outside door handle to hold it in the unlocked position. Then I had to manipulate the hooking end of the cable with one hand and the inside door pull with the other. The tricky part was hooking on the cable end entirely by feel. There has GOT to be a better way to do this. If you know the trick, please share it with us.
Old Jul 5, 2011 | 11:56 AM
  #354
ikappedkermit's Avatar
ikappedkermit
Get this: we have two mini's, both '05 Copper S - mine has 75K on the clock and my sons has 68K... my passenger door and his drivers door both quit early last week!! Now what are the chances of that happening?? Evidently 100%
Old Jul 13, 2011 | 12:23 PM
  #355
lowb35's Avatar
lowb35
03 MCS, drivers side only at 84k. Locks/unlocks w/ key so chose to ignore it for time being. Wanted to save my money for what I felt would be imminent PS failure based on the age of my car, which just happened now at 87k.
Old Jul 13, 2011 | 12:32 PM
  #356
gknorr's Avatar
gknorr
Does anyone know if the new replacement actuators are better than the original actuators?
Or will we just have to replace these again in another roughly 8 years/100k miles?
Old Jul 13, 2011 | 01:05 PM
  #357
cristo's Avatar
cristo
Alliance Member
I wouldn't mind having to change them every 8 years or 100K.
My last car (1982 VW Rabbit S) went through several from 1982 to 2003,
(mostly on the driver's side) and they were simple mechanical latches.
Old Jul 22, 2011 | 09:03 PM
  #358
jeff323's Avatar
jeff323
So out of the blue both my doors will not open using the interior door pulls? I can get them to open if I use the central locking switch and if I use the key fob while in the car, but the locks will not come up if I just pull the handles on BOTH doors. This really confuses me as I could see one side failing, but both at the same time? This seems almost more of an electrical issue than a mechanical one, but yet I thought the interior door pulls worked on pure mechanical function? Any ideas?
Old Jul 23, 2011 | 05:19 AM
  #359
Johnna's Avatar
Johnna
How bizarre to have two separate cable actuated locks fail at the same time! Can't wait to hear what you discover when you remove the door panels.
Old Jul 23, 2011 | 10:45 AM
  #360
gknorr's Avatar
gknorr
If the key and the center console switch will unlock and lock the doors, then your actuators are working. There's a cable that runs from that handle to the actuator, and it sounds like, oddly, both got undone at the same time.
Are you able to open the door at all with the inside handle? If that cable is loose, I don't think you would be able to.
Old Aug 6, 2011 | 05:28 PM
  #361
R53fort's Avatar
R53fort
I'm not sure if this has been stated yet in this thread, but working in the BMW side of the cars there have been problems with the BMW's. From BMW's standpoint if the lock actuators are lubricated with any kind of silicone or lithium based lubricants then it will cause premature failure of the lock actuators.
From the looks if it the locks on my car are not that different in some ways than that of an E46. So my guess is that the internal makeup is the same.
I have and 04 MCS and the right side one just quit on me today. Millage is 111500.
Old Aug 21, 2011 | 09:47 AM
  #362
vroooom's Avatar
vroooom
2003 MCS with 117K miles. My passenger side actuator went out a couple months ago and I couldn't unlock the door with either the remote or the center console toggle. I finally got a chance to rip into it this weekend and it looks like I'll be buying a new module and putting it in this week
Old Aug 25, 2011 | 03:38 PM
  #363
cetro's Avatar
cetro
2011 Clubman with 300miles. Door locks and unlocks fine, but the indicator is not working.
Old Sep 2, 2011 | 10:11 AM
  #364
wakewen's Avatar
wakewen
2003 S 58K miles, driver's side.
Old Sep 6, 2011 | 06:27 PM
  #365
Rexalot's Avatar
Rexalot
2005 R50, 55K Drivers side. Won't "autolock", doesn't unlock with fob or dash switch.
Passenger side door cable decided to pop out just after this started this weekend. I fixed that already.
Old Nov 15, 2011 | 10:14 AM
  #366
devinw's Avatar
devinw
2003 R53. 99K now, but ~90K and the passenger's crapped out. Haven't replaced it yet. :(
Old Jan 5, 2012 | 02:54 PM
  #367
shorn's Avatar
shorn
Originally Posted by Johnna
'05 ...
I just pulled out my passenger side actuator this aft. Best way I found was to detach the interior door handle cable at the door handle end; not the actuator end. Remove the door handle mech w 3 phillips screws, flip over, then snaip out the cable sheath, then remove the cable from the door handle. Then pull the cable and actuator out the opening in the int. door skin. To do that you need to detach/remove some plastic clips that guide the cable from handle to actuator - no big deal. Reinstall in reverse order. If you replace the actuator - as I'm fixin' to do - I suspect that the cable will need to be connected to the new actuator, as the actuator won't come with the cable. But I haven't bought it yet.
I did partially disassemble the actuator to see if I could find anything obviously wrong. That's 2 hours of my life I'll never get back. My suspicion is its an electrical issue. There are two motors for locking and unlocking, a microswitch to signal for window drop-down, and some 'wiring' encapsulated in plastic. Me thinks bad or intermittent connections between the motor(s) and the 'wiring'. Looks like the same poor design as the boot latch mech. which I also had to replace. Best to just replace it.
1/7/12 update: I replaced the actuator (MINI speak="rotary door latch") and that fixed the 'does not unlock electrically' issue. So I did an autopsy on the bad one. I was wrong; the problem was not with the electrical connections in the mechanism. The problem, in this case, turns out to be a defective lock motor. Well duh. There are two small motors in the mech. One locks and the other unlocks. They both appear to be identical. The good one measures 20 ohms and spins fine at 5 volts. The bad one measured 3k ohms and does not spin. There is nothing exotic going on in the mech. A 7 pin connector has pins dedicated to the window drop down micro-switch/sensor, another two devices (not equipped in this version of the actuator but appear to be for another switch and ?), and the two motors that share a common and have each a dedicated pin. There is a capacitor across each motor motor winding for electrical noise control.
So I'm saving the bad part in case I have to replace another motor - this side or drivers side. Plan B of course is to buy another $175 part.
Old Jan 6, 2012 | 08:01 AM
  #368
anyheck's Avatar
anyheck
Everyone who's doing a door lock replacement should take a look at this video:
http://www.youtube.com/watch?v=N9H33ad1UcA
He does a LOT of really informational automotive repair videos, that even if not directly on Minis are applicable in general terms.
Old Feb 5, 2012 | 09:17 PM
  #369
Daverlee's Avatar
Daverlee
I have a 05 MCS with both doors NON FUNCTIONAL. Does anyone have any tricks to connect the inside door handle cable back on to the hook at the lock mechanism.
Old Feb 6, 2012 | 11:03 AM
  #370
YELLOWMINIAZ's Avatar
YELLOWMINIAZ
I just started a thread today and I ran into this thread.
Mine is 05 Cooper R50 stopped yesterday. Passenger side 116,200 miles.
Old Feb 8, 2012 | 01:23 PM
  #371
Colo's Avatar
Colo
03 MCS (build date 02/03) Passenger door quit around 68K last summer. Does not respond to auto lock, fob, or switch. Dealer quoted about $340 to fix. I haven't done anything about it yet.
Old Feb 8, 2012 | 04:02 PM
  #372
northbarts's Avatar
northbarts
02 MC passenger door power lock failed 20k miles after the driver side door lock failed. Dealer repaired the first issue at a premium price, so I want to do my own repair this time. Is anyone familiar with troubleshooting and repairing the central locking system on a 2002 MC?
Old Feb 8, 2012 | 06:31 PM
  #373
YELLOWMINIAZ
Contact Way Motor Works.
He is fixing mine at a much cheaper price then the dealer.
Old Feb 8, 2012 | 07:10 PM
  #374
Pepper63's Avatar
Pepper63
Pepper White 2007 Cooper S
My car only has 43,000 miles on it an the trunk won't stay locked. Anyone else having this problem?
Old Feb 12, 2012 | 01:40 PM
  #375
chubster's Avatar
chubster
Originally Posted by timcuculic
So after I parked my 2003 Mini Cooper S (110,000 miles) the other day, when I tried to open my door, it would not open. I could tell the cable was still connected, because pulling on the interior door handle would move the door unlock button slightly. I was able to roll down my window, and open it from the outside.
After reviewing this thread, I went down and bought a replacement cable, assuming that the cable needed to be replaced.
After getting back from the dealer, I took the door panel off to take a look. Since I could not see where the cable connected to the actuator, I used my camera to take a couple picks.
The following is what I found. The cable popped out of the actuator ( the photos are not as nice as Volki's, but I thought they may be useful ).
So, I reached in there, and pushed the cable back in. It didn't really snap into place, it just kind of slid in there. If it popped back out eventually, I would not be surprised. This is what it looked like after I put it back in.
I hope these photos help you visualize what is going on inside the door.
Also, for those of you that need the cable, I bought mine at Prestige Mini in Mahwah NJ, for $11.73 plus tax. Here is the info:
Part: Bowden Cable
Part number: 51-21-7-143-538
Again, this is the part number for a 2003 Mini Cooper S. I'm not sure if it's the same for all years.
After seeing the cable, I think it would be very tricky to replace it without taking the actuator out. You would have to reach in, open the little flap, release the cable, slide the new cable on, close the flap, all without seeing what you are doing (unless you have a fiber optic camera). I guess it's worth a shot though!
Here is what the cable looks like:
Good luck!
Hi Timcuculic! Thanks for posting this, I think I may be having the same issue...suddenly my door stopped unlocking via the handle. I pulled the panel off to take a look and now the door will no longer open from the inside either. I'm wondering if your door would unlock via the key and/or centre switch? Mine will, as well as opens from the outside as you said yours did. Sounds like yours was a simple fix...has it lasted?
C
