oil pressure light after oil change
Old Jan 14, 2020 | 09:24 AM
lotter1's Avatar
lotter1
I know what you thinking, search! But read me out.
I changed the oil on the car and since then I have had the oil light in some sort of fashion. Here is the sequence of events.
  1. Drained oil,
  2. Removed filter - noticed black piece of plastic(Drain back plunger) floating in assembly.
  3. The plunger seemed damaged and was, The 3 prongs were missing and so was the outer spring. Guessing PO's shop is to thanks for that.
  4. Researched
  5. Bought Ford power stroke part( 904-261) which I have read has been used with success.
  6. Installed plunger, Fumoto Valve and new MAN oil filter.
  7. Filled with oil, Mobil-1 5w-30 full synthetic for high mileage vehicles.
  8. Started and had a light come on. Stayed on throughout the rpm range.
  9. Removed filter and the plunger was not seated properly. Re-seated it making sure it is in there good. Installed oil filter.
  10. Started it, no oil light- Yay!
  11. Drove car and the oil light came on once the car was at operating temp. Light would go out when the rpm was above 1300-ish or if the car is cold.
  12. Ordered factory oil filters from Way.
  13. Replaced filter.
  14. Same results as step 11.
At this point I am not sure what is next? In some of the post I have read, if you use 904-261 you have to use the old outer spring? If so, why do some of the vendors here sell it as is?
Any thoughts or help appreciated
Old Jan 14, 2020 | 03:00 PM
booyah93's Avatar
booyah93
I broke my black spring valve plastic when I first got my mini.
Buy an oil filter housing with gasket, and replace the housing.
i might remember to post a picture of it tonight after work.
the black peice by its self is strictly not serviceable .
Old Jan 22, 2020 | 02:54 PM
lotter1's Avatar
lotter1
Ok,
Went to the junk yard and got a drain back plunger that was in better shape than the one that came out of my housing. Only the 3 clips on the longer tabs were broken off but got it installed. No more light in any rpm range. So I am guessing the replacement drain back plunger( Dorman 904-261) is not a replacement part. I modeled the mini plunger up and will be printing some here in the future. I have also been looking at the springs, the outer one can be sourced but can only find similar springs to the inner spring.
Cheers
Old Jan 22, 2020 | 08:23 PM
booyah93's Avatar
booyah93
Originally Posted by lotter1
Ok,
Cheers
You are a savage. Can we reuse the old spring?
Old Jan 23, 2020 | 05:17 AM
JAB 67's Avatar
JAB 67
Just today Outmotoring.com claims to have the plunger back in stock.
Old Jan 23, 2020 | 07:36 AM
lotter1's Avatar
lotter1
Yeah you can. The PO lost the outer spring so I was looking at the potential replacement options
When I needed it last week, I emailed someone there asking about it, still waiting for a response. I will print some and have it ready for next time.
Old Mar 21, 2021 | 07:59 PM
lotter1's Avatar
lotter1
Changed the oil again. The junk yard plunger also disintegrated. I t appears only to be the outer piece. At least both of my previous outer pieces broke. Like I mentioned in an earlier post, I modeled the plunger and printed some pieces. Seeing that the inner section was still good, I reused it and the springs with the part I printed. The printed part snapped right in and all is good so far. If you would like the STL file, PM me and I pass it along.
Old Mar 22, 2021 | 11:09 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Just order a new valve from Outmotoring.
Old Mar 27, 2026 | 05:13 PM
Pakkiro's Avatar
Pakkiro
I can't find it anywhere, please.
Please, friend, I can't find the part and it's the only thing I'm missing to rebuild my R52.
Old Mar 30, 2026 | 06:47 AM
lotter1's Avatar
lotter1
I will have a look for the files. I did have one of my PC's go down and I lost a bunch of things.
Old Mar 30, 2026 | 07:06 AM
Pakkiro's Avatar
Pakkiro
Voy a buscar los archivos. Se me estropeó un ordenador y perdí un montón de cosas.
Te lo agradecería mucho, amigo! Todavía está pendiente. I would really appreciate it, friend! It's still pending.
alistaircookie
12
Nov 28, 2020 11:46 AM
pepperwhitejcw
May 14, 2018 03:55 AM
fourpaws
Dec 21, 2017 04:38 PM
SpyderCKE
22
Aug 19, 2008 05:51 AM
Jeffy
Cooper (non S)
Jun 2, 2006 08:16 AM
