Cleaning throttle body - need to replace gaskets?
Old Nov 7, 2018 | 10:17 AM
Ketchup's Avatar
Ketchup
Hi all...2010 MCS Auto trans.
I am getting the P115C code and it seems to run a bit sluggish. I'm sure the intake tract needs a walnut blast...but if I want to check hoses and clean the throttle body, do I need to replace gaskets for the intake manifold and the throttle body?
Thanks a bunch.
Going to check all hose connections from the MAF to the throttle body this weekend.
Old Nov 7, 2018 | 01:26 PM
Yupetc's Avatar
Yupetc
Most often times, the answer would be yes if you haven't taken the throttle body off the manifold. But for me, when I remove the throttle body, I always look at how much protrusion the gasket still makes from the gasket slot. If it still has some, I just put it back on, and to date, I've never had an issue. The longest time since I did that was 30k miles ago on an 09 MCS. Others might disagree, but my opinion is, if there are still gasket left to mash onto the manifold with, then there's no need to replace it.
Old Nov 7, 2018 | 01:33 PM
MiniToBe's Avatar
MiniToBe
also, while cleaning the throttle body, try not to mess with the flap...it might either damage it or require adaptation resetting.
Old Nov 7, 2018 | 01:41 PM
Yupetc's Avatar
Yupetc
Whew... MiniTobe is right, DO NOT move that flap even with the wire loom unplugged. This goes for most drive-by-wire throttle body vehicles, not just the MINI. I'm an active member in forums in which I have vehicles under my possession. I can't begin to name how many people while cleaning their throttle body had accidentally moved the flap and later plug everything back in to find that it doesn't work correctly anymore.
Old Nov 7, 2018 | 01:46 PM
Ketchup's Avatar
Ketchup
Understood! Thanks for the info. Since I don't think this has been done before, I'm going to buy the gaskets since they are cheap.
Can I use MAF cleaner on the body or should I get something else?
Also, is the Bentley manual the best or something better?
Thanks a bunch!
Old Nov 7, 2018 | 01:49 PM
MiniToBe's Avatar
MiniToBe
Check this link
newtis.info
After selecting your car, search throttle body and read through. It might shed more light regarding cleaning or dos and donts
Old Nov 7, 2018 | 02:28 PM
Ketchup's Avatar
Ketchup
Originally Posted by MiniToBe
Check this link
newtis.info
That's nifty ! Thanks!
Old Nov 7, 2018 | 02:37 PM
drea-min's Avatar
drea-min
i just get lucky when i did Walnut Media Blast my 08 Clubman S i cleaned the throttle body,
sprayed with cleaner and manually open and closed the flapper many times i didn’t seperate
remove it although i have gasket on hand, put it back together and runs fine, one thing i’ve noticed
tge flapper was slightly open due to carbon deposits on the edges. Cool!!
Old Nov 8, 2018 | 10:02 AM
Most people replace them if they look all flat and smooshed so they dont get a leak.
https://www.northamericanmotoring.co...-valves-7.html
Post # 156
Old Nov 10, 2018 | 09:19 AM
seandallen's Avatar
seandallen
You've already done all the work to remove your intake manifold. I just looked and found the intake manifold to throttle body gasket for $2.60, and the intake manifold to cylinder head gaskets (4) for $2.93 each. My question is: why wouldn't you replace them? Not being snarky - I just think you'd save yourself from going there again for awhile for just a few bucks.
Carmichael
Aug 20, 2013 12:33 PM
MattyKHZ
Mar 30, 2012 01:01 PM
rustyeuro
Cooper (non S)
Jul 14, 2011 08:42 AM
jc8899311
Cooper (non S)
16
Mar 11, 2010 11:56 AM
paulmon
Mar 19, 2003 03:12 PM
