Touchy Accelerator Pedal
Old Jun 29, 2018 | 10:06 AM
jglover's Avatar
jglover
08 S .Since this is my first Mini I am not sure weather they are just touchy or the is something wrong. Got the car off of Craigslist as a project. When I first scanned it it had a code related to the pedal. I replaced the pedal and code went away. Still have a touchy pedal. By touchy i mean that when you depress from a stop it very responsive. If you slow down quick and then need to accelerate then it comes on very quickly. Is there a difference between the black pedal and the on with the Stainless Steel cover?
Hope this makes sense.
Old Jun 29, 2018 | 11:02 AM
RB-MINI's Avatar
RB-MINI
Since you bought the car used, I would check if a sprint booster or another brand throttle adjuster was installed. They add multiple settings for faster pedal/throttle sensitivity, and also include stock and sometimes lower like for valet parking.
Old Jun 29, 2018 | 12:06 PM
MiniToBe's Avatar
MiniToBe
Black pedal is used on Non-S. The chrome on is used on the S model.
Old Jun 29, 2018 | 05:35 PM
jglover's Avatar
jglover
Yes, MiniToBe I am aware of that. But my cheap a** put in the black one in chrome car. Is there a difference between the two?
Old Jul 2, 2018 | 06:05 AM
MiniToBe's Avatar
MiniToBe
I haven't driven one with this set up, but I did use a black one instead of chrome to eliminate codes/diagnosis and didnt notice a difference. Both car were automatic by the way...
I just looked at realoem.com and it seems black or chrome could be used for the same application, but it seems like you may not use one from automatic trans on a manual trans!!
https://www.realoem.com/bmw/enUS/sho...diagId=35_0322
Old Jul 2, 2018 | 07:39 AM
cristo's Avatar
cristo
Alliance Member
My 2009 JCW R55 has a very responsive go pedal. I actually like it like this.
Much quicker than the slow throttle response on my old R50.
When I tried engaging the Sport button, it was way too twitchy, so I never use that.
Old Jul 2, 2018 | 09:43 AM
They are the same on the structure, just the added stainless plate, but.....
https://www.ecstuning.com/Mini-2008-...terior/Pedal/2
One part # is for the auto and one is for the manual. Same with the NON S one( all black) My guess is you have the wrong pedal.
Old Jul 4, 2018 | 12:54 PM
bugeye1031's Avatar
bugeye1031
Moderator
Wonder if the accelerator is touchy because of the drive by wire mapping (sprint booster or maybe an AT pedal in a manual car or vice versa) or if it is because the pedal back pressure (physical pressure against the sole of your shoe) is lower than you're accustomed to. I found the latter to be a problem in my 09 S and my 09 JCW....(made a mod to add more back pressure).
Da_Ghost
How to
Jan 14, 2017 03:51 PM
jhbjrpdx
May 28, 2013 04:26 AM
Bmont82
May 31, 2012 08:40 PM
Duck360198
Electrical
May 6, 2006 09:54 AM
bigmini
Mar 14, 2004 07:10 AM
