Need help 2007 N14 cooper S top end rattle
Old May 8, 2018 | 09:25 AM
R53R56Will's Avatar
R53R56Will
Hi guys i have a horrible rattle coming from the cam cover area above cylinder 1 right by the pcv pipe. The rattle happens when the engine is warm between 2,000-3,000 rpm. But only on a steady throttle as soon as the engine is pulling it goes. The noise is very metallic.
I have already replace the chain, guides, tensioner and vanos gear. Also done a walnut blast about 6 months ago.
Has anyone had this before? I'm thinking hydraulic lifter sticking?
Old May 8, 2018 | 12:23 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Could be the infamous N14 death rattle due to the chain guide going. IMO you STOP driving now. Park it and have it looked at.
Old May 8, 2018 | 05:34 PM
jcwcoopster's Avatar
jcwcoopster
He already changed the guides.
Old May 8, 2018 | 05:48 PM
Whine not Walnuts
yes but who did the work?
Old May 8, 2018 | 09:17 PM
R53R56Will's Avatar
R53R56Will
I did the work. I worked for bmw/mini for 10 years. I know how to do a R56 chain ��
Old May 10, 2018 | 05:47 AM
MiniToBe's Avatar
MiniToBe
as whine said, stop the car and pop the valve cover and take a look. did you use the 82mm tensioner? do you have enough oil in the engine?
Old May 10, 2018 | 12:26 PM
R53R56Will's Avatar
R53R56Will
I have used the latest genuine mini 'long' chain tensioner. It's not the chain. The noise isn't there from cold only starts only when the engine is warm and gets worse the hotter it gets. 'Do I have enough oil in the engine' seriously?
Old May 10, 2018 | 12:34 PM
MiniToBe's Avatar
MiniToBe
what's with the attitude?
we are asking questions to fill the gaps in your diagnosis...we're not with you and we dont know what you or someone else did on your car!
people are something...good luck mate!
Old May 11, 2018 | 12:58 PM
Whine not Walnuts
Long distance car diagnostics is like throwing darts blindfolded. The more we now, the bigger slit in the blindfold.
So as the engine heats up something is expanding and rattles. For me I would recheck all the torque settings on the head.
Old Jun 25, 2018 | 01:25 PM
drea-min's Avatar
drea-min
Since the subject is rattle noise, i can not pin point where its coming from, stetoscope all around the top valve cover i dont hear snapping chain or bearing noise, i did disconnect the brake booster vacuum hose and the noise came quiet, do i need to replace the vacuum pump? When i put my hand on the vacuum connection it pulling vacuum. This car is my '08 R55 Clubman S
Old Jul 4, 2018 | 01:03 PM
bugeye1031's Avatar
bugeye1031
Moderator
I know that you said the noise is coming from near cylinder number one, but could it somehow be the vacuum pump....completely opposite, but they can make a helluva racket...
Old Jul 4, 2018 | 08:43 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
How many miles on the car? High mileage N14 vacuum pumps have been known to seize, that stops the camshaft, pistons hit the valves, and you're buying a new engine. If you even suspect the vacuum pump then replace it, cheap insurance.
Old Jul 6, 2018 | 03:13 PM
drea-min's Avatar
drea-min
I did replaced the vacuum pump and its more quiet now, atleast timing chain will be done later i hope it will stay Quiet for awhile.... I have time to make my wish list for a big job..
Old Jul 6, 2018 | 03:14 PM
drea-min's Avatar
drea-min
I did replaced the vacuum pump and its more quiet now, atleast timing chain will be done later i hope it will stay Quiet for awhile.... I have time to make my wish list for Timing chain job..
Systemlord
May 3, 2019 04:43 PM
TimBaleia
Jun 2, 2017 11:53 AM
BLiNKFAST
Aug 21, 2016 06:10 AM
odieman23
Aug 18, 2016 04:57 AM
NC Doug
Oct 20, 2014 10:03 AM
