Clunks on bumps
Old Jan 28, 2018 | 07:04 AM
FLKeith's Avatar
FLKeith
Clunks on bumps
I have a 2007 R56 with 160k miles that clunks when going over bumps. I jacked up the car an tried shaking wheels and lifting them with a pry bar to see if there is noise or movement from suspension bushings and didn't find anything. Bouncing on the corners of the car doesn't clunk. I guess it could be engine mounts but how do I check them? Anywhere else to look? Any suggestions?
Old Jan 28, 2018 | 11:03 AM
oldbrokenwind's Avatar
oldbrokenwind
Have you checked for a loose exhaust pipe?
Old Jan 28, 2018 | 11:51 AM
holkki's Avatar
holkki
Rear sway bar bushings?
Old Jan 28, 2018 | 06:08 PM
FLKeith's Avatar
FLKeith
Yes. Checked from front to back and i can't get it to hit the body
Old Jan 28, 2018 | 06:09 PM
FLKeith's Avatar
FLKeith
What is the best way to check the sway bar bushings? I have tried moving them but don't know if that is enough.
Old Jan 28, 2018 | 06:42 PM
BeardedForever's Avatar
BeardedForever
Strut mounts may be torn, struts may be worn.
Old Jan 28, 2018 | 08:36 PM
R56BrgMcs's Avatar
R56BrgMcs
mine clunks as well on bumps. waiting for the snow and wet weather to leave before i check to see what it is and fix it.
Old Jan 29, 2018 | 09:21 AM
MiniCooper_S's Avatar
MiniCooper_S
Could be that your battery came lose and is sliding into the firewall.
Old Jan 29, 2018 | 02:07 PM
nkfry's Avatar
nkfry
Is the clunk at the front or the back of the car?
I'm beginning to see a lot more of the gen 2 cars in for front sway bar bushings causing a clunk in the front.
But as for the rear; it could be anything from failed end links to sway bar bushings or shock top bushings.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 30, 2018 | 06:18 AM
I would say end links or sometimes the hatch lock adjustment on the back, the front it can be the upper mounts or the endlinks/ball joints.
Old Jan 30, 2018 | 09:54 AM
J Free's Avatar
J Free
Following, mine is doing the same at seemingly all 4 corners. It's driving me nuts, but I just dumped a cars worth of money into this thing so I can't even dream about fixing it until the weather is nice again.
Old Jan 30, 2018 | 08:40 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Good advice from all above. At 10+ years and 160K miles you need to check every piece of rubber in the suspension. Good chance that the shocks are worn out as well. My rough guess at where to start:
1) sway bar bushings front, then rear
2) front shock top mounts
3) front shocks
4) rear shocks
5) front, then rear end links
6) front control arm bushings
7) front ball joints
Fortunately most of these aren't big $ for parts and you can do the work yourself if you aren't scared of a socket wrench set.
Old Jan 31, 2018 | 09:08 AM
dmyer's Avatar
dmyer
I have similar issues with my 2007 at 100K....
My shocks were bad and when I replaced them/rebuilt the struts... a lot of the noise went away although I still have a few rattles and clunks left. My heavier NM engineering rear sway has always made more noise and the Polyurethane Sway bar bushings don't help and need grease or it squeaks!! IMO... my car at this age is allowed a few rattle and squeak!! That means it is still running!
Old Jan 31, 2018 | 05:50 PM
FLKeith's Avatar
FLKeith
Thanks for all the suggestions. Next question ... what is the best way of checking if any of these parts are bad? I have tried going over the suspension and can't find any thing wrong but maybe I am not checking it correctly.
MiteyF
Aug 27, 2017 07:24 AM
delsurviajero
Aug 25, 2016 01:54 PM
bennettskis
Mar 22, 2011 08:35 PM
kenchan
16
Oct 16, 2003 08:29 PM
mexminime
Mexico
Sep 1, 2003 01:34 AM
