Drivetrain Steptron Trans clunks down into 4th can it be fixed
Old Mar 6, 2011 | 07:43 AM
bennettskis's Avatar
bennettskis
At 100k my steptronic started to clunk down shifting into 4th. If I'm careful a slight blip will minimize the effect.
Any solutions or recommendations?
Old Mar 6, 2011 | 09:07 PM
Checkmate_2006's Avatar
Checkmate_2006
I am just curious, what is the slight blip? Is it something you do intentionally or an anomaly from the car or drivetrain?
Old Mar 6, 2011 | 09:28 PM
ggcadc's Avatar
ggcadc
at 100k i would suspect its a secondary effect of something else that needs maintenance... not necessarily the tranny itself suddenly developing this problem. maybe throttle response is compromised by plugs, air filter, maf/map sensor, maybe an o2 sensor causing some odd responses before it throws a code... that's just my initial thought
maybe some background on the general repair of the car, maintenance history, the MOST RECENT changes made would be most helpful.
Old Mar 7, 2011 | 04:20 AM
bennettskis
when I drop into 4th, I increase the throttle a bit. I also notice if i accelerate when going into 4th it shifts smoothly.
As far as maintenance goes, it has relatively new plugs and an O2 sensor and appears to be running smoothly.
Old Mar 7, 2011 | 07:23 PM
ggcadc's Avatar
ggcadc
has the trans fluid been changed?
Old Mar 14, 2011 | 10:58 AM
bennettskis
Yes
The dealer did a service about 10K ago.
Old Mar 22, 2011 | 07:49 PM
Tomas_siba's Avatar
Tomas_siba
just curious, how much did the dealer charge you for the tranny flush?
Old Mar 22, 2011 | 08:35 PM
luseboy's Avatar
luseboy
check your tranny/engine mounts/bushings. could be causing a problem. replace with powerflex if your so inclined. reset your ecu, might help. make sure your plugs aren't worn out, and that your air filter isn't covered with dust. you never know...
wildwestrider
Dec 27, 2015 08:20 PM
molala
Oct 2, 2015 01:53 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Ntety
Sep 2, 2015 08:39 PM
