new to forum.. 2011 mini rough idle, misfiring post... yes again
Old Mar 4, 2015 | 07:44 PM
Alix0r's Avatar
Alix0r
Hey all so I'm new here but not to the car world and forums. I have read through many many threads already and I suspect the problem is the HPFP...
but any way so my GFs car is a 2011 Cooper S and she is getting the common misfiring/rough idle symptoms. I have already replaced the plugs and ignition coils and I just did the dreaded walnut blasting of the carbon build up(which wasn't too bad actually lol)... but to no avail it is still having the issue.. any input on this or is the HPFP the next logical step?
Thanks, Jason
Old Mar 6, 2015 | 07:42 PM
renchjeep's Avatar
renchjeep
When my 2011 MCS HPFP started showing symptoms, it was not very long before the "half check engine light" came on, and sometimes it would go into limp-home mode---no turbo. When I pulled codes, I had misfire and fuel pressure codes. New HPFP cured these issues.
Old Mar 10, 2015 | 03:19 PM
nkfry's Avatar
nkfry
Get the car hooked up to a proper scan tool, and don't keep throwing parts at the car.
Failing HPFP's are being covered out to 120k miles (on 07-09 cars) under dealer warranty, so a dealer visit may not be too bad of an idea for a free pump that would otherwise cost you around $600.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Mar 10, 2015 | 03:33 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
2011 HPFP's being covered by warranty? Any link to Mini/BMW offering this? I only see early cars being mentioned.
Old Mar 10, 2015 | 04:40 PM
afadeev's Avatar
afadeev
HPFP is covered under extended 10 year/120K mile MINI warranty for N14 engines, but the it's not really free. You will be asked to pay for 1 hour of labor to "diagnose" that it truly is HPFP, before a dealer will attempt to process the warranty swap.
https://www.northamericanmotoring.co...-for-hpfp.html
And if they disagree with you that the root cause is HPFP, you will be out of 1 hour of labor and then need to take your car to a competent independent to deal with the underlying problems.
a
Old Mar 12, 2015 | 12:04 AM
renchjeep's Avatar
renchjeep
My 2011 MCS HPFP was covered under remaining factory warranty, only days before it expired. Not sure if it was extended for the N18. Seems to be a LOT of HPFP issues lately, even on the N18 engine. Carbon walnut blasting on an N18? I thought that the N18 was not going to have the N14's carbon buildup issues?
Old Mar 12, 2015 | 06:54 AM
Helix13mini's Avatar
Helix13mini
^This^. It's smart to mention the 'campaign' to your service advisor so they know you are aware of it.
Old Mar 13, 2015 | 01:56 PM
afadeev's Avatar
afadeev
*sigh*
Carbon build-up is an issue on all direct injection (DI) engines, N14, N18, multiple BMW N-series and S-series engines, etc.
N18 may have partially mitigated the severity with redesigned crankcase ventilation, but the underlying problem of no fuel splashing over/cleaning intake valves is still there.
a
iggi
18
Feb 9, 2026 01:00 AM
Cereall
Sep 5, 2019 06:05 PM
wind715
Aug 11, 2015 07:56 AM
ludedude
Aug 10, 2015 07:16 PM
Lt. Dan
Aug 10, 2015 08:23 AM
