Serpentine Belt Won't Go !!
Old Feb 12, 2014 | 07:58 PM
allstar195's Avatar
allstar195
I have spent hours trying to get the serpentine belt on my '05 S. The tensioner is up and pinned at the second hole. But the belt is still a little short of fitting.... I just don't get it. Please Help Thx
Old Feb 12, 2014 | 08:51 PM
JoeGravelle's Avatar
JoeGravelle
Is this a new belt or the old belt? As long a you have the proper sized belt, the belt is routed correctly and not snagged or half on it should fit.
Old Feb 13, 2014 | 01:49 AM
ZippyNH's Avatar
ZippyNH
If a short belt is used....
Have a helper pull back on the tensioner tool....this will give you about another 1/4 inch of movement....or simply buy the next longer belt...aka...get the 535 instead of the 532 of the 539 instead of the 535....
The prior owner might have installed a +2 crank damper...meaning a longer belt is needed than the "common" ones folks suggest.
Old Feb 13, 2014 | 03:23 AM
mrbean's Avatar
mrbean
I've run into this problem before only to realize I routed the belt around the pulleys incorrectly.
Old Feb 13, 2014 | 05:12 AM
allstar195's Avatar
allstar195
Thanks But The belt is a 548 (6PK1390) and is new and clean. Its routed all the R53 pics I have seen. BTW this repair is due to the fact that the Idler Pulley came OUT !! Thx Again
Old Feb 13, 2014 | 06:19 PM
allstar195's Avatar
allstar195
HELP !!! Still ideas to get this on !!!!
Old Feb 13, 2014 | 06:39 PM
JoeGravelle
Compare it to the old belt and make sure they are the same size. Other than that we've pretty much covered all of the bases on belt install issues.
Old Apr 14, 2020 | 04:38 PM
Lauren Thompson's Avatar
Lauren Thompson
Any luck?
Having the exact same issue - I know this post is super old - hoping you found a solution and can share! We’ve tried so many times, routes belt correctly, even bought the tool.... at a loss.
martinb
Oct 7, 2015 05:00 PM
TifosinDel
Sep 28, 2015 10:45 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
vargasgal
Sep 17, 2015 10:02 AM
