Vacuum Pump Failure - What is the Reasons(s)
Old Nov 12, 2019 | 05:58 AM
  #126
Lex2008's Avatar
Lex2008
Originally Posted by MINIMI2
My 2010 S went with no indication at all, no rattle, no bang it just shut off and yellow check engine light came on. (after it died) Checked on board computer, came back CHECK OK. Ran code reader and got 3 or 4 temporary codes, relating to cam position and valve timing. Temporary, meaning these codes had not set as permanent`, they were pending, meaning they occurred when the timing chain sprocket separated from the cam. Simple terms , there were no prior codes before failure. How much trust do put in an on board computer that tells you your engine is OK when your looking at the timing chain and cam sprocket at the bottom of the timing cover! I can see your point about a bad oil filter or botched install being the instigator of so many VC failures. Mine was oem filter, with oil at top of stick. Mini had car for 5 days when we went back to dealer to get Answers. Warranty was 6K miles over, but 2 months under on duration. Service advisor and Lead shop tech took us out to car to tell us the bad news. They said they couldn't help us on a new motor due to low oil and lack of maintenance. I asked the shop tech. to pull the dip stick and show me where it was low. He looked at the service advisor and choked, he said oil level was good and appeared to have been changed recently. ( 2 weeks prior to failure). He also mentioned how clean the engine bay was. I showed them the maintenance schedule I used for the car. 5K miles or less on oil changes with Mini filters. Not their condition based changes at 15 to 18,000 miles. Long story but ended with mini putting in a factory rebuilt and I still payed $350.00 for their bad engineering. And no, they wouldn't replace the computer that couldn't self diagnose a dead car.
How many miles on the motor when it died?
The engine computer cant diagnose a lack of oil into the vacuum pump or incipient failure. The vacuum pump is a simple mechanical design. Obviously a bad design.
Old May 17, 2023 | 04:38 AM
  #127
JaY mini's Avatar
JaY mini
Oil in vacuum pump
Originally Posted by lorenfb
"you will see that the vacuum pump, gets it's oil feed through the rear bearing journal in the cylinder head, from the exhaust camshaft bearing journal supply feed line"
This is not correct. The vacuum pump utilizes a double sealed bearing which DOESN'T
receive ANY lubrication and just relies on its initial bearing grease. To imply that
frequent oil changes will reduce the likelihood of the vacuum pump failing is totally
misleading. There is NO oil flow to lubricate bearing!
The only immediate and realistic solution is a redesigned vacuum pump where the
connection point from the cam shaft can shear easily if the bearing seizes.
I just wanna say real quick... I bought my first Mini Cooper 2 weeks ago, it had a vacuum code so I went to take it off while watching a YouTube video telling me how, well I accidentally took it apart trying to take it off of the block. It had oil in it so I drained it thinking that was the problem... Turned out that it's supposed to have oil in. Mine is the 2008 Mini Cooper S N14.
Old May 17, 2023 | 09:34 PM
  #128
Lex2008's Avatar
Lex2008
Correct. That's lubricating the metal parts. The problem is that these cars burn and leak so much oil that they tend to run in a low oil condition often and if the vacuum pump runs dry and seizes up you end up destroying the valve train.
French engineering genius.
Old Jun 15, 2025 | 07:01 AM
  #129
pkgmSu2000's Avatar
pkgmSu2000
Originally Posted by IDLife Mini
I have spent the better part of 12+ hours reading every possible thread I can find about the vacuum pump. I thought I was having the "Death Rattle" and simply watched a few too many videos from threads talking about timing chain failures... yet all of this originated from seeing drips of oil on the ground closer to the passenger side of the car.
So a quick call to BMP Designs in Tyler Texas sourced me with their timing chain repair kit with everything and at the same time I ordered the two vacuum pump o-rings. WELL... weeks later when I finally have time to dive into this, I discover a bigger issue and definitely one that needs repair immediately.
After seeing the replacement of the mechanical pump with an electric one, I feel this is by far the best route to go. However, I am wondering if an expanding freeze plug would suffice in blocking the original mounting port for the vacuum pump. I can buy for $10 a plug that will fit perfectly, expand to lock itself into place which will also block the oil passage. Any opinions on this? I can indeed get some aluminum bar, turn it on my lathe and put a bolt through it as an attachment for the mounting plate... but I am trying to make a fix that anyone could do with readily available parts.
So that turns me to the new vacuum source. Well having two 7.3L Ford Diesels, you eventually after 300K+ miles of great service will have to replace the vacuum pump that controls the HVAC motors & 4x4 if you have auto locking hubs. This is a self-contained vacuum pump with an internal vacuum switch, turns on at 13in off at 18-19in. These are designed to operate the auto locking hubs on a Ford 4x4 as well as the HVAC systems and a life design of 2000 hours running time. I have found them NEW with isolating mounts for $54.00 at the local auto parts store. Since they were produced for millions of vehicles made by both Ford & Dodge in extreme conditions of off-roading, I am certain this little pump will suffice on my MINI's road trips. Best part is that if it does fail... nearly every auto parts store in the country has them in stock!
See the pics for more details. The pump weighs less than 10oz, so including the loss of drag on the cam and the weight savings... maybe there's a boost in performance by having stable vacuum supply as well!
Any thoughts on this old thread?
holy!!!!
these N14/N18 engines have been around a long time with so many on the road. There HAS TO BE an aftermarket solution out there. There are soooo many trusted Mini tech gurus that know these cars like the back of…
if there is a legit vacuum pump fix, even someone engineers a one off, I’ve got legit $$$$ for you.
Old Jun 15, 2025 | 01:44 PM
  #130
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Originally Posted by pkgmSu2000
holy!!!!
Here's my solution... regular oil changes, and don't let it sit - drive it. My 2012 N18 R55 Clubman was purchased with 32,000 miles on it, and I drove it till it read out at 205,000 miles. All original timing chain, all original vacuum pump, and even the HPFP ran that whole time after being replaced at 36,000 miles. I religiously changed the oil every 5000 miles, and the car never sat for more than a week without being driven.
Old Jun 16, 2025 | 10:26 AM
  #131
pkgmSu2000's Avatar
pkgmSu2000
greatly appreciate the feedback. Could this also mean at the least starting the motor every day letting it run a few minutes? My Mini is not my DD and only plan to drive the occasional canyon cruise, and won’t be driving winter months. What you shared sounds to be petty scary for those who don’t use their Mini as DD.
Old Jun 16, 2025 | 10:48 AM
  #132
Lex2008's Avatar
Lex2008
and some prayer...
Old Jun 16, 2025 | 10:50 AM
  #133
Lex2008's Avatar
Lex2008
NO!!!! You're filling the oil full of fuel. Cold starts are the worst for a host of reasons. Start and drive till hot or don't start it.
Change your oil every 6 months , or 3000 miles. FORGET 5-10k oil changes.
Old Jun 16, 2025 | 11:02 AM
  #134
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If your Mini becomes limited use, then maintenance becomes much more important. ^What he said. When you do drive it, make the trips longer. For oil changes, if you drive less than 5000 miles per year, then oil changes every 6 months. I would do April 1st and October 1st, depending on where you live.
Old Jun 16, 2025 | 11:09 AM
  #135
Lex2008's Avatar
Lex2008
Oil dilution from fuel is no joke. You can fail emissions from old oil that's full of fuel. No joke.
Wet belts in Fords fail because the engineers forgot to consider fuel dilution. Fuel + rubber = fail
Ya gotta run it until it's hot to evaporate fuel and water in the oil. Short trips are a disaster for internal combustion engines.
Summons
Dec 19, 2020 09:18 PM
ToXIc
Jan 8, 2014 01:58 PM
kyoo
Nov 23, 2013 04:51 PM
xsmini
Mar 13, 2013 02:48 PM
Aeromax
Jan 27, 2011 06:53 AM
