Hot weather = leaks
Old Jun 3, 2011 | 12:38 PM
tccox's Avatar
tccox
Hot weather = leaks
Well,since it's turned so hot my
MCS seems to have developed some leaks
1. Dripping oil on my garage floor looks like from right (passenger) side of engine. Real slight so far but guess I'd better have dealer look at it.
2. Front fenders, the black wheel arches. something's dripping out from under the hood and dripping down and staining the arches. It's not washer fluid and it's doing it on both sides. Maybe bonnet support struts are leaking ?..
Any ideas?
Old Jun 3, 2011 | 01:53 PM
jcauseyfd's Avatar
jcauseyfd
On #2, is it yellow-ish? If so, I'd assume that is cosmoline. You can do a search on that term for more info.
Also, I assume this is on the 2011 in your sig? If so, mods probably should move this to the 2nd Gen forums.
Old Jun 4, 2011 | 04:03 AM
tccox's Avatar
tccox
No, car has 6000 miles on it, this just started this week
Old Jun 4, 2011 | 05:51 AM
ZippyNH's Avatar
ZippyNH
2011 mini's are refered to as gen2 mini's....
2002-2006 (or 2008 cabrio's) are gen 1 cars, newer ones are gen2...the newer desgin.
Most, if not all gen1 cars are out of warreny.
Your signature says you have a 2011 car.....so gen2
Old Jun 4, 2011 | 06:42 AM
tccox's Avatar
tccox
Sorry, suffered a brain fart I guess. I'll post on the correct forum . How do I delete this thread ???
Old Jun 4, 2011 | 06:43 AM
tccox's Avatar
tccox
Hot Weather = Leaks
Any ideas?
Old Jun 4, 2011 | 10:17 AM
RJKimbell's Avatar
RJKimbell
Any ideas?
Sorry, can't help with #1, but your #2 Issue is Cosmoline Drip, it's a "lubricant" that is applied to all seems as a Rust Inhibitor. There is a product on the market called "CosmoNot" here's a link...
http://www.showcarsupplies.com/shopexd.asp?id=178
Old Jun 4, 2011 | 10:37 AM
MLPearson79's Avatar
MLPearson79
Original thread merged.
Old Jun 4, 2011 | 11:16 AM
ZippyNH's Avatar
ZippyNH
The cars when shiped are coated in a thick waxey stuff....the mentioned cosmoline...it is washed off with near boiling water at the port....the wax/cosmoline is then recovered, and burnt to heat more water....resulting in 0 lanfiil junk...unlike the common.plastic wrap...mini was very proud of this, and did some promotion of it...the negative is it can seep into so creavises....and leak/drip out on the first few hot days...leaving streaks...
Old Jun 4, 2011 | 11:27 AM
MLPearson79
Yep, the yellowish stuff is cosmoline. Prima makes a product called Cosmonot that you can use to remove it easily.
Old Jun 4, 2011 | 11:32 AM
Benibiker's Avatar
Benibiker
Three years later my Mini is still leaking the stuff under the bonnet, door drains, and hatch drain...
Old Jun 6, 2011 | 07:44 AM
tccox's Avatar
tccox
Thanks all. I never would have thought of that but makes perfect sense. It occured during our first really really hot days of the year. I think that explains both issues.
Seems other folks have had the leaking Bonnet
http://minicooperforums.com/forum/ar...hp/t-1283.html
Old Jun 19, 2011 | 10:06 PM
cesar418's Avatar
cesar418
that stuff is turning my clear bra yellow when it leaks haha
potterstein
Dec 30, 2024 05:18 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
David Eric Rosenberg
Sep 10, 2015 12:34 PM
Sep 3, 2015 01:45 PM
Sep 2, 2015 09:05 AM
