SES light on after replacing motor mount
Old May 21, 2011 | 09:11 PM
minimaesjc's Avatar
minimaesjc
HELP! we just replaced the leaking right motor mount and the ribbed belt everything was all good then we started the engine the SES light is now on and the engine died on the first start but started fine the second time. Any ideas? This is our first DIY on the new MINI. its a 2006 R50 with 70k miles.
Thanks, marilyn
Old May 22, 2011 | 04:44 AM
HRM's Avatar
HRM
My guess is a loose wire. The cam sensor is near the belt, the ground strap is there. Looking up the code would be a big help.
Old May 22, 2011 | 09:57 AM
minimaesjc's Avatar
minimaesjc
thanks, this is our first diy and we don't have the tool to read codes. the ground strap was disconnected when we removed the bracket for the motor mount could that set a fault?
Old May 22, 2011 | 11:22 AM
HRM's Avatar
HRM
If the car was turned to the on postition while it was removed it is possible. There isn't much more in the area that can be bumped, but double check all hoses and connections.
Old May 22, 2011 | 11:35 AM
minimaesjc's Avatar
minimaesjc
thanks, we double checked everything and it looks good so we are now in the market for a peake tool so that we can read the fault codes and get this cleared up any suggestions for places with the best price.
Old May 22, 2011 | 02:23 PM
HRM's Avatar
HRM
I would just disconnect the battery for 5 mins. If the code is important, it will return. If not....
Old May 22, 2011 | 02:50 PM
hexon's Avatar
hexon
With my Nissan I could just drive down to some place like autozone or advanced auto parts and they could pull the codes for me (for free). I haven't tried this on my Mini but I don't see it being much different.
Old May 26, 2011 | 06:20 AM
minimaesjc's Avatar
minimaesjc
ok the ses light went out on monday and came back on wednesday after the engine rpm dropped. we now have a peak tool and the fault code is p0340. which the peak book tells us is a camshaft sensor.
Old May 26, 2011 | 07:38 AM
HRM's Avatar
HRM
That is right next to the motor mount on the pass side, sort of between the mount and engine. Probably a loose wire. It' near the top/center and probably can be banged by a belt going on or coming off.
Old May 27, 2011 | 05:58 AM
minimaesjc's Avatar
minimaesjc
we will check for a loose wire. is there a way to check for sensor failure?
Old May 27, 2011 | 09:12 AM
rkw's Avatar
rkw
You can read the code with an OBD reader. If you go to some auto parts stores like AutoZone, they will read it for free.
However, the most likely problem is a loose wire around the area you worked in.
Old Jun 7, 2011 | 07:37 AM
minimaesjc's Avatar
minimaesjc
thanks for all your helpful hints, well it seems that in fact the camshaft sensor connection was the cause and after r&i and checking all connections the light has been out. knock on wood.
Old Jun 7, 2011 | 07:56 AM
quikmni's Avatar
quikmni
Thanks for the update and glad you solved the problem.
Old Jun 17, 2011 | 12:12 PM
jboy_nm's Avatar
jboy_nm
How hard was it to change the motor mounts on your own? Mine need to be done.
Old Jun 17, 2011 | 12:49 PM
quikmni's Avatar
quikmni
Not too bad. You do need an E12 External Torx socket and long extensions for the bottom bolt. I purchased a External Torx set at Sears. There are various large mount bolts to remove. You will need to support the car on jack stands and use a jack to support the mount. The hardest part was getting all the black goo off. Also, check to make sure black goo did not get all over your serp belt, if so you should replace the belt.
Here is one NAM link:
https://www.northamericanmotoring.co...ount-leak.html
Old Jun 17, 2011 | 05:22 PM
WiggleStik's Avatar
WiggleStik
This very thing just happened to me. I replaced the mount and 2 days later I received all kinds of faults. Was about to replace the sensor, then it occurred to me that I might have bumped/pulled on the connector when replacing mount. Voila!!!! it was slightly backed off the sensor. Reseated it and it's been running perfect since then. I was told by Waylen at WayMotorWorks that a loose wire or a pinched wire somewhere could be the problem and it will cause all kinds of weird fault codes. Once again he was dead on. Simple fix.
Alkaidovich
Jan 30, 2021 01:35 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
