What wears on the door stops/door mechanism?
Old Apr 22, 2010 | 02:59 PM
ulrichd's Avatar
ulrichd
When I close my 04 Cooper driver door it sounds like a 72 Pinto, while my passenger side sound like a BMW built product. Door hangs straight, no sag, no accidents, nothing loose in the door cavity or storage bin.
Just curious what wear items are there that might contribute to this?
Thanks.
Old Apr 22, 2010 | 05:03 PM
JAB 67's Avatar
JAB 67
Does your door strap work? In other words, when you open the door do the detents hold it in position?
Old Apr 22, 2010 | 05:55 PM
Mello_Yellow's Avatar
Mello_Yellow
Yea, both our Minis (R50 and R53) have this issue.. the R53 worse. Passenger doors are as smooth as butter. I don't know if it's just cause those doors are used more.. maybe it needs oil or something? I have no clue. I'm interested in a fix for this. Sometimes when it's really cold or really hot, it's so loud I have people look at me in parking lots from 30 feet away when I close my door.
Old Apr 23, 2010 | 07:44 AM
ulrichd's Avatar
ulrichd
Yes, door stays open.
Old Apr 23, 2010 | 07:45 AM
ulrichd's Avatar
ulrichd
I know it's embarrasing.
Old Apr 23, 2010 | 08:45 AM
Capt_bj's Avatar
Capt_bj
it could simply be the hinge
put a couple of drops of 3 in 1 oil, or even motor oil on the hinge....a little will go a long way.
There should be a retaining bolt on the bottom of both hinges - you might even loosen that to ensure you get some lubricant into the hinge pin ... but be sure to retighten.
If not the hinges then it is possibly the 'check strap' which is the part that stops the door from swinging too wide and provides the check-stops which hold the door open. Try applying a little bit of grease .. you can probably look at it and tell what side is getting worn/rubbed.
Old Apr 23, 2010 | 09:38 AM
MLPearson79's Avatar
MLPearson79
White lithium grease spray is the answer to this problem...other members here have used it to solve the "squeaky door" problem
Old Apr 23, 2010 | 05:01 PM
Capt_bj's Avatar
Capt_bj
or spray the entire hinge area with PAM
same outcome
woodstudio
Mar 15, 2020 08:28 AM
DeniseNY R52
May 17, 2016 05:16 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
