Cold Start Issues Database
Old Jan 25, 2010 | 11:30 AM
  #326
torobud's Avatar
torobud
Bob '07 MCS +1
Old Jan 25, 2010 | 12:33 PM
  #327
iwashmycar's Avatar
iwashmycar
Model: 2009 R56 Mini Cooper S
Build Date: Oct 2008
Miles: around 32,000 miles
Duration: 1-2 minutes
Frequency: twice a week, when parked nose down
RPM range: idle - 2500
Ambient Temp: 30 F
Oil: Mobile 1 0W-40 Full Synthetic
for our Ohio people, and my problem details...
https://www.northamericanmotoring.co...ue-at-mag.html
Old Jan 25, 2010 | 12:50 PM
  #328
DangerMan's Avatar
DangerMan
John '08 MCSa +1
full-monte @ 30K miles
Old Jan 25, 2010 | 01:57 PM
  #329
John928's Avatar
John928
John '08 MCS +1
clatter first time ~7k miles, started when we left coast of MS for northern climate, about 6 times since. Replaced tensioner at 20.5k miles.
Old Jan 25, 2010 | 02:15 PM
  #330
kopov's Avatar
kopov
Alex-2007 MCS with 34K, tensioner replaced first then at 30K-the whole assebly.
Old Jan 25, 2010 | 04:11 PM
  #331
MINIdave's Avatar
MINIdave
Dave
2009 Clubman S
Tensioner replaced at 3k, no problem since. 13K on it now.
Old Jan 26, 2010 | 10:58 AM
  #332
MrCooperS's Avatar
MrCooperS
Moderator
-Threads Merged-
Old Jan 27, 2010 | 03:10 PM
  #333
Spectral G's Avatar
Spectral G
Dan, 07 MCSa +1
Old Jan 28, 2010 | 08:46 AM
  #334
netma1000's Avatar
netma1000
Just got back my 08 (Jan08 build) MCS for the cold start issue. 25,500 miles.
They replaced the Timing Chain and tensioner as well as 7 other parts for this issue. On start up - no noise.
Because of P0302 code, they also replaced two injectors. And while they were at it they also found a leaking thermostat which was also replaced.
Back to being a happy camper again.
Old Jan 28, 2010 | 05:56 PM
  #335
Flyinace2000's Avatar
Flyinace2000
March 09 build MCS
Had vacuum pump replaced only to have problem come back next morning.
Dealer then replaced tensioner and timing chain (1/28/10 13500). Will report back if problem returns.
https://www.northamericanmotoring.co...-post1516.html
Old Jan 29, 2010 | 08:14 AM
  #336
zemina's Avatar
zemina
Model: 2008 R56 Mini Cooper S
Build Date: February 2008
Miles: around 23500 miles
Frequency: First time
Ambient Temp: 46 F
Oil: OEM
It's first time so far and the noise not that loud. I just start drive gently and a minute later the noise gone.
Old Jan 29, 2010 | 08:34 AM
  #337
JimRoberts12's Avatar
JimRoberts12
just got mine back with new time chain tensioner. not much description at all though. says the chain was measured at 67mm?
also got full brakes that weren't due for another 4k miles...not sure how that worked? but cool
Old Jan 29, 2010 | 09:16 AM
  #338
razotong's Avatar
razotong
Yuki 07 mini cooper S +1
Old Jan 30, 2010 | 06:51 AM
  #339
R3R's Avatar
R3R
2010 MCS (December 2009 assembly date)
300 miles (1 week old)
Metal on metal rattle from the left side of the engine, yesterday, twice after cold starting at 3 Fahrenheit (-16 Celsius), lasted about 2-5 minutes, sounded like a diesel engine
What should I ask the dealer to change or check on such a new car? Any advice please, as I don't want to drive 150 miles to the dealership for naught?
PS The car has been towed to the dealer for replacing the intake manifold with the redesigned 4 port one, after having presented the icy throttle starting problem later during the day...
Old Jan 30, 2010 | 08:58 PM
  #340
skippydog's Avatar
skippydog
Guys Im sorry but with the merge of my thread with this one by the mods my count got trashed. I started a petition on the mini cooper archive site below as well as if you want to register in the comments section we can keep a more accurate count. It appears that this issue is getting serious enough where we should be trying to do something about it.
http://www.minicooperspeed.com/mini-cooper-cold-start-knocking-noise-issue-2007/
http://digg.com/motorsport/Petition_...oper_S_and_JCW
Old Feb 1, 2010 | 09:41 PM
  #341
CruiseControl's Avatar
CruiseControl
2009 MCS 5200miles. Finally repaired with a new chain, tensioner and a bunch of other parts.
Thank you all for your info.
Kevin
Old Feb 2, 2010 | 03:47 AM
  #342
J_'09s's Avatar
J_'09s
I changed my oil to 0w-30 and the rattle has been nonexistent for me. Literally went from every other day to nil. Its been two months and about two thousand miles since i last had the noise. Success in my book.
Old Feb 2, 2010 | 06:56 AM
  #343
Panozster's Avatar
Panozster
What did you use before the recommended 0 W-30 W??
Old Feb 2, 2010 | 02:53 PM
  #344
J_'09s's Avatar
J_'09s
before this, castrol 5w-30, before that the original oil. Yall should try it out and report back!! Its not that cold here though. It never gets below freezing where i currently live. So this may not help you all out who live in the frigid temps!!
Old Feb 2, 2010 | 02:58 PM
  #345
skippydog's Avatar
skippydog
Are you using castrol edge or gtx?
Old Feb 2, 2010 | 03:05 PM
  #346
J_'09s's Avatar
J_'09s
I was using castrol syntec before, this time i put in the Mobil One 0w-30, the carton with a little bit of green on it. After i put it in, it felt really strong.
Old Feb 2, 2010 | 05:58 PM
  #347
ADRIANAB2007MINI's Avatar
ADRIANAB2007MINI
Cold start up
2007 mini s
37k
duration about 4-6 minutes
idle
it has happened so many times i lost count
I JUST NEED TO VENT AS I AM HOPING MINI WILL COME TO REALIZE THE ERROR IN THEIR WAYS. I PURCHASED MY MINI IN 07 AND ABOUT 7 MONTHS AFTER I HAD THAT DREADED PINGING NOISE I TOOK IT TO GET REPAIRED AND AFTER GETTIN THE COLD SHOULDER THE SERVICE CENTER REPAIRED THE CAR AS IT WAS A RECALL AS HE STATED OF A TENSIONER ISSUE ( OH IM A CHICK PLESE DONT JUMP MY THROAT IF I SAY IT IN A NON TECHNICAL WAY) PICKED UP MY CAR AND THEN IT CAME BACK I TOOK IT TO ANOTHER DEALER AND THEY COULD NOT REPLICATE THE ISSUE THIS IS THE GRIPE HOW MANY TIMES CAN THEY HIDE UNDER THE COVER OF DARKNESS WITH THIS WE CANT REPLICATE THE ISSUE JUNK SO I LEAVE MINI A RATLLTING ABOUT A THEN I TAKE MY CAR BACK IN BECAUSE ITS MAKING A NOISE LIKE THE WHOLE MOTOR IS ABOUT TO EXPLODE. SO THEY REPLCAED THE TIMINMG CHAIN TENSIONER AND THE CAM SHAFT FINALLY I TAKE MY BABY FOR A RIDE AND GUESS WHAT LIKE BUUUUUUUTTTTTTEEEEEERRRRR. AND THEN DISASTER THESE SO CALLED MINI LICNESED MECHANICS DID SOMETHING AND MY BABY WAS LEAKING OIL FOR A FEW DAYS WHEN I REALIZED IT WAS MY CAR I HAD THEM TOW MY CAR IN LONG STORY SHORT.... HEAD BLEW OUT SO THEY CHANGED IT SO NICE OF THEM ( OH I SURE DID GO TO ANOTHER DEALER I DID NOT WANT THEM TOUCHING MY CAR AGAIN) WHEN I WAS GIVEN MY CAR BACK IT HAD NO POWER AND THE NOISE PERSISTED I TOOK IT BACK AND SORRY CANT REPLICATE THE ISSUE NOW I HAVE A CHECK ENGINE LIGHT WHAT CAN I DO I HAVE CALLED MINI OF NORTH AMERICA AND THEY ARE GOING TO HAVE SOME BIG WIG LOOK AT MY CAR AND SAY..... SOOOOORY WE CANT REPLICATE THE ISSUE!!!!!!!!!!! IM AT WHITS END THE CAR HAS FAR LESS POWER THEN ITS POTENTIAL ITS PINGING AND THE CHECK ENGINE LIGTH IS ON THIS WILL BE MY SECOND WEEK IN CONTACT WITH THEM AND I DUNNO I AM GOING TO JUST HAVE TO WAIT AND SEE HOWEVER FYI I WONT BE SURPRISED IF THEY CANT FIGURE OUT WHAT THE ISSUE IS THEY HAVENT THEN AND THEY PROBABLY WONT NOW.... MY CAR MAKES A FUNNY NOISE IN THE MORNING I NEVER HAD TO RE START MY CAR AFTER THE LAST REPAIR 65 % OF THE TIME IT TURNS OFF NEVER WHEN I ENGAGE THE CLUCH JUST TURNING IT ON THE IDLE IS FUNNY LOOKING IT JUMPS FOM 1/2 TO 1 RMP MY CAR NEVER EVER EVER FUNNY IDLED NOW IT DOES AND THE WORST PART I HAD AN AUTOMATIC LOANER THE OTHER DAY IT HAULED MORE BUM THAN MY CAR THAT MADE ME FURIOUS. OVERS ;O( OH MY WHOLE ORDEAL HAS BEEEN 2 YEARS AND COUNTING NOT TO MENTION I HAD A CLUTCH REPAIR AND A THROW OUT BEARING JOB DONT ASK ME I TOOK IT IN ONE DAY AND THEY GAVEIT BACK WITH A FUNNY CLUTC NOISE
Old Feb 3, 2010 | 05:27 AM
  #348
rhawth99's Avatar
rhawth99
All caps and no paragraphs make your rant very hard to read Adriana.
Old Feb 3, 2010 | 02:03 PM
  #349
dmeadow's Avatar
dmeadow
Sigh
July '07 build. MCS auto. Had the rattle a couple of times.
Took it to Momentum Mini here in Houston and got the usual run-around. Ranges from essentially "they all do that when it is cold" to "bring it back if it gets worse" (and in the same conversation). Even had the service rep tell me that the weather is getting warmer so it should stop.
Old Feb 7, 2010 | 11:20 AM
  #350
nickminir56's Avatar
nickminir56
Problem (finally) solved at 19845 miles
Jan 08 build. MCS auto. Rattle almost everyday (<40F) or even park at slope (<50F), rattle noise range from annoying to scary.
First my dealer replace time chain tensioner @ 8600 miles, oil level checked. Problem was still there but the rattle period was shorten somehow from (10+ mins to <5mins). After warming up, the engine still runs rough at winter at low rev compare to summer.
Finally at they fixed the problem by replacing the whole time chain assembly as reported by Motoring file in May 2009:
http://www.motoringfile.com/2009/05/...d-start-issue/
It's 2 days engine out job according to my dealer. Now the engine runs with no rattle noise at all @ 27F, parked 10 hrs. The engine also runs as smooth as summer across the whole rev range.
