Steering noises when turning slowly
I couldn't find this exactly in the search, so I apologize if you've seen this before...
In the last day or two, my 05 Cooper has been making a weird noise when I turn slowly, e.g., parking or pulling out of a driveway. It's a little hard to describe -- sort of a clunking that I can hear inside the cabin.
I had her in for a service at the dealer in July and they said the control arm bushings looked "worn" but on the service sheet, there was no indication that it was bad.
I had her in for new tires in July at Wheel Works and asked them to check it out. They said the bushings looked fine.
I had her at Wheel Works again in September for brakes and rotors. I asked them to check again and they said everything looked fine.
So, my question -- are there other possibilities for the noise? Is it possible for the bushings to completely wear out in a month and a half?
Thanks!
Thanks!
Unfortunately, it's out of warranty.
I talked to a co-worker who mods his cars and he said it might also be an axle U-joint?
Ugh. I just bought it used in May from a friend and since then, I've had to: get 2 new tires and alignment, replace both front wheel speed sensors and replace the front brakes and rotors. I know this stuff is maintenance, but why she didn't do this before selling it is beyond me.
I just hope this isn't an expensive one.
My little dose of LITHIUM
funsizd:
you don't have "U" joints, so it's not that. While a definitive diagnosis of bushings is hard without pulling them out, I'd check other things first.
Is it a continuous noise, a quick short thunk, or some combination noise (whirr, whiz, clunk, for example)? If everything checks out "solid" in the front end, it could be the shock mounts but they tend to clunk once.
Do you have a limited slip diff in the car (would have been from the factory--it was an option on 05s)? The diff makes a grinding sound when turning slowly.
More info please.
More info please.
Thanks Dr Phil.
On driving for a few more days, I've been able to better describe the sound as a short whizzing noise that only happens when the wheel is cranked to one side or the other. It doesn't happen when driving normally, and it's not as loud as I originally thought.
Embarrassingly, I don't know if I have LSD. I bought the car used from a girl who doesn't know much about cars.
And I haven't had the VIN run through the dealer to get complete specs. It's totally possible that's what it is and I just never noticed before.
Thanks Dr Phil.
I had a clunking noise and you could hear it when I turned the wheels while the car was stationary. It got bad enough that the power steering fluid had to escape out the power steering resevoir.
I had my entire steering rack replaced and the problem was fixed.
Manny_cooper
Sep 10, 2015 11:09 AM
Navigation & Audio help identifying a couple wires
yashmack
Aug 15, 2015 03:11 PM
