How to remove dash or dash pad (rattle fix?)
Old Jul 31, 2008 | 10:15 PM
rodH's Avatar
rodH
just bought a used MCS 2003. There is an area under the dash pad that is rattling like crazy. Sounds like just a clip is lose or something. Is there a simple "how to" remove the pad?
Old Aug 1, 2008 | 01:11 PM
rodH's Avatar
rodH
no one?
Old Aug 1, 2008 | 02:40 PM
Xymox's Avatar
Xymox
What part of the dash? Driver's (left) a-pillar area?
Old Aug 1, 2008 | 03:10 PM
rodH's Avatar
rodH
under the dash pad
Old Aug 1, 2008 | 04:28 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Open both doors...on either end of the dash are plastic panels...pop the panel off and you will see two Torx head screws...remove the two screws on each side...there are two more screws above the speedometer bezel...remove these as well...then while sitting in the drivers' seat pull up a little in the center of the pad...once it "breaks" loose pull up and away from the windshield. It helps if the steering column is in the all the way down position.
Old Aug 3, 2008 | 06:44 AM
techtipz's Avatar
techtipz
Yeah, your whole dash has to be removed. There is a centering pin near the windshield that is most likely causing this noise. Are you looking to do this yourself? Its a timely process.
Old Aug 3, 2008 | 09:15 AM
rodH's Avatar
rodH
Ya, I was going to do it myself, when you say "timely" are you talking several hrs? The instructions to remove the dash in this car seem fairly simple, what takes so long?
id does sound like it is coming from the center by the windshield. Ii was hoping it was just the nipple, but playing with that proved that it is something underneth.
Old Aug 3, 2008 | 09:49 AM
Xymox's Avatar
Xymox
Originally Posted by rodH
I was hoping it was just the nipple, but playing with that proved that it is something underneath.
*Snickers*
Old Aug 19, 2008 | 06:28 PM
instrumetal86's Avatar
instrumetal86
bump... anymore on this...anyone try fixing it? im having the same issue.
Old Aug 19, 2008 | 08:15 PM
JPMM's Avatar
JPMM
I fixed it,cheap and posted here
somewhere I posted the fix ,its cheap and takes about ten minutes.If I have a chance I'll look for it. Otherwise do a search
Old Aug 19, 2008 | 10:52 PM
drsilvermini's Avatar
drsilvermini
Here is a how to for the dash removal
5 Piece Dash Removal DIY
Old Aug 19, 2008 | 11:58 PM
rodH's Avatar
rodH
I HAVE BEEN searching like crazy, can;t find it
Old Aug 20, 2008 | 12:16 AM
rodH's Avatar
rodH
narrowed down my search and think I found it.
Funny thing is, after trying to take apart the dash and giving up I worked a temporary alternative based on a similar concept. I shoved a black sock down there, then I put a layer of automotive weather stripping between the windshield and dash. Rattle gone (now I am missing a sock).
Here is a link to your fix
https://www.northamericanmotoring.co...02#post1707702
Old Oct 18, 2008 | 10:13 AM
pimpedout97x's Avatar
pimpedout97x
im having a horrible rattle too everytime i hit a bump, my bass broke or made something come loose lol.
im gonna take my dash pad off today and see what it is.
Old Oct 18, 2008 | 04:37 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Stuff a stip of 1in² foam window airconditioning insulation between the windshield and the dash. Get a strip that is long enough to run the entire gap. This fixed my dash rattle that has been there since the car was new. All my mods, mostly the polyurethane engine bushings, had exasperated the rattle.
Old Oct 20, 2008 | 01:52 AM
darksun's Avatar
darksun
Whats this ? Can you explain in detail please. I have the rattle 1 year now...
Old Oct 20, 2008 | 04:02 AM
pimpedout97x
Go to your local hardware store and ask for that, they'll point you to where its at
Old Oct 20, 2008 | 05:37 AM
darksun's Avatar
darksun
I mean it's in english and i don't understand the term!
Old Oct 20, 2008 | 06:34 AM
pimpedout97x
just a piece of foam..anything will work
W0TM8
Dec 19, 2019 07:50 AM
alistaircookie
Oct 8, 2015 10:52 AM
squawSkiBum
Oct 2, 2015 09:21 AM
iclancy82
Aug 11, 2015 09:35 AM
