02' "s" ac not blowing cold
Old Jun 8, 2008 | 12:09 PM
smi2710's Avatar
smi2710
ok so heres the dilemma
right now the the Hvac controls in the car have a lil issue (im in search of a replacement unit ) the circulation option is constinitly on? green light lit and it wont turn off
anyway when we turn AC on it doesnt get cold i have checked the pressure and it say around a 100psi indicating warning
im guessing theres a blockage somewhere or not
all help diagnosing this would be great
also when i turn ac i should hear it kick on in the engine bay but at last i dont notice any real change again im guess due to the blockage assuming there is one
thanks
edit
i check the fuse and relays and fuses are good the relay however not sure how to check them but they look ok i suppose i reseated all of them
these were all in the engine compartment if theres more please let me know
and for sure the ac is not kicking on when i turn it on definitly cant here the compressor so im back to the original idea of BLOCKAGE just dont know where to start resolving that problem
thanks
again
eric
Old Jun 8, 2008 | 06:15 PM
Eurothrasher's Avatar
Eurothrasher
thanks
edit
thanks
again
eric
Generally, in a car that is 6 years old with some possible 70,000 miles on it that blows hot a/c and compressor doesn't kick on, used to mean a bad A/C seal, and thus no freon, or 134a in the system.........When there is no refrigerant in the system the compressor will not kick on.
Old Jun 8, 2008 | 06:39 PM
smi2710's Avatar
smi2710
but it says 100psi
we have 56k on the car
im getting a ac check at firestone with 25.95 check deal
Old Jun 8, 2008 | 07:02 PM
Eurothrasher
but it says 100psi
100 psi or 1.0 lbs?
I don't beleive the AC hoses can withstand 100 psi. not sure what you are registering there......usually refrigerant is measured in Lbs. and our probably takes no more than 2-3 lbs for the entire system.......
If you are registering 1 lb., it's low. Most places will not refill the system until the leak is located no matter how small the leak is. They can use dye in the system to locate the leak, and fix, then refill with R134a.
Good luck
Old Jun 8, 2008 | 08:01 PM
AliceCooperWA's Avatar
AliceCooperWA
Try a coolant recharge kit at your local auto parts store. I think its possible to have pressure and still be out of coolant.
I think the high pressure side can withstand 100psi. the average hose for air compressors can withstand much higher.
Old Jun 9, 2008 | 06:26 AM
smi2710's Avatar
smi2710
well i tested with teh kit i had bought to recharge my other car
i put the pressure gauge on the well only connector it would fit on driverside the one farther back towards firewall ( even tho they are both near the front but like 5 inches apart and the rear one is down a lil in height
anyway im going to get the firestone A/C check done today
according to my gauge it goes up into the red area stating 100psi "warning"
Old Jun 9, 2008 | 08:40 AM
smi2710's Avatar
smi2710
update
just got the system checked from firstone
no leaks freon is ok
they said electrical
so i am getting a replacement hvac control from a guy on these forums
because my air recirculation light is always on im guess theres more issues in my unit
am i correct in thinking this may be the culprit seeing as how the fuses are all good
Old Jun 9, 2008 | 04:06 PM
Huxley's Avatar
Huxley
A/C check
To check the presure in a car, the car has to be on and the A/C on full blast. If you are reading 100-150 psi at this point...RUN! The lines can hold this pressure, but the pressure DROPS when the car is on to the 30-45 psi range. Therefore, if the car is reading this while running, the native state would be in the 300-400 psi range, way beyond the line's ability to hold--and it'll kill the compressor.
At my store (I run the largest Advance Auto Parts store), I have a recharge kit with hose and guage (that tells you when you're good) for $20 this month.
Happy cooling!
Bill
Old Jun 10, 2008 | 06:28 AM
smi2710's Avatar
smi2710
huxley
when i checked i had turned the A/C on in the car but alas the compressor wasnt on
i did use that pressure gauge from that recharge kit and it was in the red area
however i did get it professionally check ( well firestone checked it ) and said freon and pressure was good but that i had a electrical issue ?????
as i stated earlier i am awaiting a new/used HVAC control unit for the dash area of my car since somethign is wrong with it
but if anyone haas any other suggestions i check to see why my compressor isnt switching on i would greatly appreciate it
thanks guys
Old Jun 11, 2008 | 10:04 AM
//MZero's Avatar
//MZero
Well...it COULD be a relay. You say that you just looked at them to check and see if it was ok. Really, just looking at it doesn't tell you much, especially since its probably in a sealed black little box. Even when you take them apart it can be hard to see a problem. I haven't checked anything on the MINI specifically, but if you have any other relays that are the same shape and rating as the A/C relay and will fit into its spot, AND they are known to be in good working order...swap the relays and try that.
It normally is not the relay, but you might as well try it to officially rule it out.
Old Jun 16, 2008 | 08:25 AM
smi2710's Avatar
smi2710
i will try a new relay (14.00 from dealer) after i get my new HVAC controls to see if that fixes it
otherwise i guess im off to the dealer for a diagnosis
Old Jun 16, 2008 | 09:24 AM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
HVAC
update
If Firestone says there are no leaks and everything is fine that means the compressor is running normally.
What did they say when you told them that you could not hear the
compressor engage?
Could it be a compressor clutch problem?
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
simo711
Oct 8, 2015 07:07 PM
silence2-38554
Sep 28, 2015 12:19 PM
kevinlhr310
Sep 27, 2015 02:31 PM
