Mystery Cable Behind Fuse Panel
Old Sep 11, 2007 | 06:27 PM
roverlandpark's Avatar
roverlandpark
So, I was cleaning the scuff marks off the foot wells and decided to take off the fuse panel. Low and behold I find a loose cable. It looks like some sort of fiber optic cable. Any ideas on what it's used for?
Old Sep 11, 2007 | 11:51 PM
MotorMouth's Avatar
MotorMouth
Look in the passenger side pocket in your boot and you'll find the other end of it. Think Sirius.
(I pulled this outta my butt, however it sounds good so I'm sticking to it unless someone proves me wrong)
Old Sep 12, 2007 | 02:24 AM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I ran across that cable while doing my sport button mod, but never bothered to find out what it was.
Old Sep 12, 2007 | 04:42 AM
roverlandpark
[quote=MotorMouth;1745657]Look in the passenger side pocket in your boot and you'll find the other end of it. Think Sirius.
I have the factory installed Sirius, so I doubt it would be that. I will look in the boot though.
Old Sep 12, 2007 | 07:41 AM
djam43's Avatar
djam43
I know that they do computer updates through the fiberoptic link , so that is probably one of the cables that they attach to.
Old Sep 12, 2007 | 08:02 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
The only parts info for a fiber optics cable at www.realoem.com I can see is that it is used in conjunction with the DIAGNOSIS INTERFACE and it's listed under VEHICLE ELECTRICAL SYSTEM not nav or audio.
Old Sep 15, 2007 | 10:16 PM
Paul's Avatar
Paul
The fiber system consists of a pair of cables. From what I've seen in the R56, each fiber is encased in a flexible plastic tube. If you pull out the plastic piece right above the fuse panel cover you'll see several of them floating around.
Here is a snap of the fiber pair leading up to the CDC location (plugged into an adapter to continue the fiber loop).
Old Sep 15, 2007 | 11:08 PM
MotorMouth's Avatar
MotorMouth
nvm
PsychoRallye
21
Feb 17, 2019 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
MINI Stupor
Oct 1, 2015 11:36 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Brochacho
Sep 29, 2015 10:24 AM
