Old May 16, 2018 | 05:25 AM
  #19576
djohnson34's Avatar
djohnson34
Passed 150K on my 03 MCS
Old May 16, 2018 | 05:55 AM
  #19577
Mini1011's Avatar
Mini1011
Just finished wrapping my mini. It was a lot of work but it turned out pretty good.
Old May 16, 2018 | 02:00 PM
  #19578
bratling's Avatar
bratling
Super Moderator
Gorgeous!
Old May 16, 2018 | 02:05 PM
  #19579
miniCPA's Avatar
miniCPA
Great job - it looks incredible.
Old May 16, 2018 | 02:26 PM
  #19580
Mini1011's Avatar
Mini1011
Thanks guys! There are a few spots that need to be done again but you can't really tell. The back bumper cover was definitely the hardest part.
Old May 16, 2018 | 03:58 PM
  #19581
BluGnat's Avatar
BluGnat
Last night, we bought mine a little brother. "Ruckus" is a 2008 Justa in Oxygen Blue (R56?). My 16 year old son has always kept amazing grades in school (in stark contrast to his older brother who excels in every other way except grades), so this is a reward for that anticipated continued grade success. Today, Ruckus got window tint, and I ordered him a Craven dipstick.
Old May 16, 2018 | 05:18 PM
  #19582
I am impressed. Nice job. You boost my courage to just do it on my Porsche.
Old May 16, 2018 | 05:37 PM
  #19583
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Swapped out OEM filter with AFE, added 8 hp to the car. . .
Well probably .8 hp or nothing different at all except a bit of dirt lifted from the air-box. Makes me feel better at least.
AFE Dry Panel Filter
Old May 16, 2018 | 05:46 PM
  #19584
Mini1011's Avatar
Mini1011
Thank you. I highly recommend watching some YouTube videos before doing it specially on how to do areas that are recessed. My biggest tip is to clean the car extremely good and I mean extremely well. I cleaned mine multiple times and still found certain areas that had dirt which will ruin the whole panel that your doing.
Old May 16, 2018 | 07:17 PM
  #19585
oregon's Mini maintenance day
Today must be Oregon's Change The Air Filter Day. Synchronization of Mini health maintenance.
My down to earth Mini only gets the down to earth essentials.
Old May 16, 2018 | 07:29 PM
  #19586
Minnie.the.Moocher
It's the sneezing that made me think of air filters. And I have been allergic a lot these past few days. I didn't have one of those fancy plaid work clothes however.
Old May 17, 2018 | 03:11 AM
  #19587
cristo's Avatar
cristo
Enkei PF01 17x7 + Michelin PS S4 215/45/17 arriving today.
Will have to look for a break in the rain to swap them on this weekend.
Old May 17, 2018 | 04:52 AM
  #19588
I ran K&N but after finding dust in my intake tract I switched to AFE and I really like them. Inspected after a few track days and I'm sold on them, now they are in both minis!
Old May 17, 2018 | 12:31 PM
  #19589
JABowders's Avatar
JABowders
Veteran: Army
Just ordered a basket full of fun from ECS ... now I'm looking forward to the end of the rain so I can install it all.
Motor On!
Old May 18, 2018 | 03:50 AM
  #19590
cristo's Avatar
cristo
Here they are (click for bigger pics) :
Attached Thumbnails What did you do to your mini today?-d7k_3815web.jpg   What did you do to your mini today?-d7k_3816web.jpg
Old May 18, 2018 | 05:13 AM
  #19591
njaremka's Avatar
njaremka
Community Builder
Community Influencer
Nice
Old May 18, 2018 | 07:03 AM
  #19592
kurtsunn's Avatar
kurtsunn
Just ordered a new vacuum pump from ECS - speakers from eBay arrived, will install tomorrow (replacing blown driver's side woofer)
Old May 18, 2018 | 07:01 PM
  #19593
Struns's Avatar
Struns
Just changed mine a few weeks ago ,leaking and it sounded funny, easiest thing I've done so far. That oil cooler/filter housing gasket was definitely a PIA.
All I did today was put on the rear mud flaps...I did the fronts 5 months ago
Old May 18, 2018 | 09:39 PM
  #19594
MSFITOY's Avatar
MSFITOY
Two spoke delete...Sparco Champion
Old May 18, 2018 | 09:48 PM
  #19595
a walter mitty dream with mini at the track
Today we got to live out our larger than life dreams. We spend the afternoon at the track. Desire and I were the first to arrive. Great turn out with 5 R53s and 1 R50. Met two new Miniacs. A nice dry and partly sunny day in the low 70s.
Desire and I were the first to arrive at the track
enough Mini's to have an orgy ; six gen 1 and one countryman
the last run group of the day at dusk
Old May 19, 2018 | 09:25 PM
  #19596
Snaps's Avatar
Snaps
Couple weeks ago, I was in the process of removing the front end, and the subframe in order to prepare to replace the clutch, and rear main seal. Since then, I've done the following:
-New inner, and outer balljoints
-Powerflex LCA bushings
-Powerflex Front Sway Bar bushings
-New Tie rods
I wasn't able to work on Egan last weekend due to some personal stuff. Today I got all of that done, but also discovered some more things I can replace in the process.
So I know the oil pan gasket is leaking, as well as the crankshaft position sensor o-ring, and the oil cooler gaskets (oil filter housing gasket appears to be fine for now).
Just when I thought I was done buying new parts, I'll be replacing those three items in the process as well since I have full access to them all. Tis' the quirks of owning a Mini for almost 12 years. :D
Old May 21, 2018 | 08:38 AM
  #19597
TheBigChill's Avatar
TheBigChill
Kumho Ecsta PS31 on order. Got all 4 for $230 shipped... Hopefully they're not terrible.
Old May 21, 2018 | 05:48 PM
  #19598
gum's Avatar
gum
I was able to removed my r52 crankshaft sprocket!
with elbow grease and a heat torch with a 3 legs puller, I screwed back the bolt to support the puller!
so I am happy camper since I would have a new timing chain, rails, canshaft sprocket and that thing that adjust the chain,
Old May 21, 2018 | 07:44 PM
  #19599
dnsherrill's Avatar
dnsherrill
looks great...are the headlight rings and hood scoop painted?
Old May 21, 2018 | 08:13 PM
  #19600
Ive's Mini's Avatar
Ive's Mini
Hit this today!
