R58 Fog lights OEM? '12 JCW R58
Old Jun 4, 2024 | 09:21 PM
MiniConn's Avatar
MiniConn
After a 2 month rebuild, got car back together and figure lights aren't working. Toggle shows lights on dash, went to check bulb land I don't see a bulb. It's a 6 wire plug that connects each fog. There appears to be a halo DRL on them too that doesn't work, bit oddly did with blinker (figure that one out). I've checked power wire to the black box under hood that looks like a ballast and has mini logo on it. Box is grounded as well, someone it has + & - to it.
Do you think previous owner swapped fog lights from a different MC?
What is box on fire wall under hood switch?
Ballast wedged next to strut tower and fuse box.
Is this a R58 factory fog controller?
Old Jun 5, 2024 | 03:17 AM
DogfaceSGM's Avatar
DogfaceSGM
I think someone swapped LED fogs into it over its life.
Old Jun 5, 2024 | 06:56 AM
Yep they got the old and nla fog led kit from MINI
https://www.northamericanmotoring.co...-as-drl-s.html
Old Jun 5, 2024 | 07:23 AM
maccoder's Avatar
maccoder
@ECS Tuning You are spot on. I have this retrofit kit installed on my 2012 R56 MCS and module box looks exactly the same.@MiniConn I would check wiring. There is one wire that should go through firewall into cabin and connect to FRM. Also, if IIRC I had to do some programming to get rid of strobing on start. Search for "MINI LED DRL retrofit kit" (or something like this) and you should find a few threads discussing installation details here.
Old Jun 5, 2024 | 07:27 AM
MiniConn's Avatar
MiniConn
Awesome thank you everyone for the information, at least this gives me a direction to figure out what I'm working with. So there should be a signal wire tap somewhere if I'm understanding correctly? Something must have gotten bumped or disconnected when front end and motor/Trans was removed.
Old Jun 5, 2024 | 07:40 AM
maccoder's Avatar
maccoder
Just did a search on my Mac and found installation PDF for this kit. This should give you an idea how it should've been installed and what's missing in your case.
File Type: pdf
Old Jun 5, 2024 | 07:42 AM
MiniConn's Avatar
MiniConn
Oh my gosh thank you! I'm off to a meeting so haven't been able to look into this yet! Really appreciate it.
Any chance you can help with my "ticking" thread too? 🤣🤣🤣
Old Jun 5, 2024 | 07:54 AM
Yep its was in one of the threads also.
You can only get some of the parts from that old retrofit NLA kit. https://www.realoem.com/bmw/enUS/sho...45#63122348832
The light itself.
https://www.ecstuning.com/b-genuine-...h/63122348832/
Old Jun 5, 2024 | 08:02 AM
MiniConn's Avatar
MiniConn
The lights work because we discovered they were both flashing with the blinker (thanks to seeing our reflection in the car ahead of us. 🤣 ). Just gotta track down the issue now. Gotta love other people's DIY's!
Old Jun 5, 2024 | 12:28 PM
maccoder's Avatar
maccoder
Oh and please disregard my comment about coding. I just realized I have confused this with MINI Xenon headlights retrofit kit installation. That one required some coding. LED DRLs kit worked out of the box - no coding required.
Just in case though - check that inline fuse for DRLs is good. I had that fuse blown in the past. Literally blown. Even the holder was damaged and I had to install completely new inline fuse with holder. This thread has some pictures: https://www.northamericanmotoring.co...d-drl-kit.html
Dmads
Jul 30, 2021 03:29 AM
umberto
Dec 12, 2016 03:05 PM
joetiii
Apr 18, 2012 09:16 PM
jakeryanitc
Oct 5, 2008 12:50 PM
The MINITOR
Electrical
Sep 23, 2005 01:11 PM
