R56 Things you didn't know about your R56 MINI
Old Dec 29, 2007 | 06:43 PM
  #651
daffodildeb's Avatar
daffodildeb
What does, ANT?
Old Dec 29, 2007 | 06:44 PM
  #652
ajabbari's Avatar
ajabbari
Originally Posted by MCS07MGM
The rear fog lights will not activate unless you first activate the front fog lights ... in turn, fog lights will not activate unless you first activate the headlamp switch in at least the first position past off ...
AND, the rear fog lights really brighten up the landscape behind you, or the flat chrome bumper of a VERY large Kenworth, MAC, or other huge beast right on your tail ...
Not sure about the rear fogs requiring the front fogs to be on. I can distinctly recall testing the fog lights a while ago and being able to toggle each independently. Still I'll have to double check now... I may be wrong.
Old Dec 29, 2007 | 09:13 PM
  #653
lacning74's Avatar
lacning74
At least I thought they did when I turned the rear fogs on as I accelerated away from a surprised tailgater. I will have to double check as well.
Old Dec 29, 2007 | 11:57 PM
  #654
Minidrivr's Avatar
Minidrivr
The rear fog lights work without the front fogs being on in my car, with the headlights on. I didn't try with just the parking lights on.
Old Dec 30, 2007 | 02:43 AM
  #655
miniphatty's Avatar
miniphatty
Rear fogs are independent from front fogs and vice versa or that is the standard - in motion or at a standstill.
Old Dec 30, 2007 | 08:17 AM
  #656
NoModMini's Avatar
NoModMini
...there is nothing in the owner's manual about the sunroof...then again there may be no need to have anything in the owner's manual about the sunroof...
Old Dec 30, 2007 | 08:31 AM
  #657
Sowellman's Avatar
Sowellman
There's also nothing about the front passenger cargo net. I'm still trying to figure out how to work that.
Old Dec 30, 2007 | 08:33 AM
  #658
phantasms's Avatar
phantasms
It comes with an owner's manual?
Old Dec 30, 2007 | 08:45 AM
  #659
NoModMini's Avatar
NoModMini
..oh yeah, one other thing....if you're anywhere near average height, if you are first in line at the traffic light stop line, you can't see it without craning your neck lower and forward....even with the seat lowered to minimum elevation....minor inconvenience.....
Old Dec 30, 2007 | 08:51 AM
  #660
NoModMini's Avatar
NoModMini
...well maybe one more....the warmers in the leather seats will flat out toast your a$$ at position 3 on the control....and there's nothing in the owner's manual about this feature either...
Old Dec 30, 2007 | 09:22 AM
  #661
gokartride's Avatar
gokartride
I didn't know...or expect...that the recent software upgrades for R56 are apparently placing intermittent wiper control for some MINIs as a push-button at the end of the stalk and on some it is retained as the first stalk position (single nudge) as is stated in the owner's manual. I wonder why this is happening and if MINI intends for this all to be consistent at some point? Was this an oops??? Either way they work fine, just a curiosity.
Old Dec 30, 2007 | 09:30 AM
  #662
Sowellman's Avatar
Sowellman
Originally Posted by gokartride
I didn't know...or expect...that the recent software upgrades for R56 are apparently placing intermittent wiper control for some MINIs as a push-button at the end of the stalk and on some it is retained as the first stalk position (single nudge) ...
This isn't a software upgrade. It's for new models only. I had a software upgrade in early November, after the stalk end control emerged. It didn't make any difference for my car.
The upgrade did solve, however, the problem with trying to get the sunroof to reach the crack-open position. The roof now stops there and requires a second tug on the toggle to have the roof panel open all the way.
Old Dec 30, 2007 | 10:04 AM
  #663
gokartride's Avatar
gokartride
I'm mystified. The intermittents on my 5/07 build Cooper worked in position one and now work via a push-button on the end of the stalk following an update in September. My friend's 5/07 build Cooper, updated a few weeks ago, still has intermittents in position one. Weird.
Maybe they just went nuts when I had my updates.
Old Dec 30, 2007 | 10:29 AM
  #664
Sowellman's Avatar
Sowellman
That's interesting. I don't imagine you tried to push in the end of your stalk before you had your software update. I'm wondering if your May build had a different stalk from the factory than earlier builds, anticipating a later change.
The stalk in my early March build car doesn't push in at all. If there was a change, it would seem the stalk itself would have to be replaced. Does yours push in just a bit, or more like the engine start button?
Old Dec 30, 2007 | 10:43 AM
  #665
R56 Ed's Avatar
R56 Ed
Try this: http://www.lightinsight.com/our_product.htm
It works great!
  #666
ATCQL's Avatar
ATCQL
Back to those fog lights in the front,i found out the other day when the brights are on and you turn on the fogs,it dims the headlights.Q
Old Dec 30, 2007 | 10:48 AM
  #667
Msteadman's Avatar
Msteadman
Also if you have the front fog lights on, then switch on your high beams, the front fogs turn off altogether. Safety precaution since you shouldn't use your brights in fog.
Concerning the ability to switch them on - with the auto-lights they activate simply by pushing the toggle, as doing so switches on low beams automatically. And I definitely can turn on just the rears without the fronts, and vice versa.
Old Dec 30, 2007 | 12:45 PM
  #668
daffodildeb
My week 3 build was updated a couple of months ago, and now works with the button.
Do you have the auto-wiper option? That's the only way you'd get a button in the first place.
Old Dec 30, 2007 | 01:57 PM
  #669
carjoy's Avatar
carjoy
I had the software upgrade awhile back and mine still only work by nudging up. Which is a good thing because I don't have a push button on the end of my stalk. What I was hoping for with the upgrade is the setting to have the rain-sensor come on automatically when the car is started. They are now including it with the SET program. Maybe I need another upgrade to see it??? I'll have to call.
Old Dec 30, 2007 | 02:02 PM
  #670
Sowellman's Avatar
Sowellman
That's interesting and baffling in the same breath. Yes, I have the auto wipers. Still have to flick the stalk up once to turn them on. End of the stalk doesn't do anything.
Old Dec 30, 2007 | 04:35 PM
  #671
Minidrivr's Avatar
Minidrivr
Is there a button on the end of the stalk on a week 3 car? Seems odd they would put the button in and not use it.
Old Dec 30, 2007 | 04:37 PM
  #672
daffodildeb
Yup there's a button on mine--and I use it. There was a button on it before the software upgrade, too, but then I had to push the stalk slightly upwards to activate the auto-wipers. At first I was mad that I'd "lost" the auto-wipers, until I thought to push the button!
Old Dec 30, 2007 | 05:09 PM
  #673
gokartride's Avatar
gokartride
Ditto for me except I thought I'd lost my intermittents. Looks like we have a bit of a mystery on our hands, although as I said the intermittents work fine via the end-of-stalk button (which I could swear did not work before), so it's doesn't seem to be a problem.
Old Dec 30, 2007 | 05:40 PM
  #674
Minidrivr's Avatar
Minidrivr
With the HD radio, you can use the left/right arrows on the steering wheel or dash control to switch to the other HD channels. Most of the HD stations around here broadcast a second station on HD2, commercial free.
Old Dec 30, 2007 | 05:46 PM
  #675
Msteadman's Avatar
Msteadman
So is the conclusion on MINI's that have the button, intermittent or auto rain sensing mode is now activated by said button rather than nudging up. While on MINI's without the button (still haven't quite figured out where the cut off is) it's obviously still activated the original way, even after any software updates?
Hope that made sense...
It's so ridiculous, my MINI has HD radio and I haven't used it even once. Not even sure if any HD stations are broadcast in my area... Always either using Sirius or my iPod via the aux jack. Gonna have to check that out now.
