R56 Things you didn't know about your R56 MINI
Old Nov 19, 2007 | 08:40 AM
  #601
miniphatty's Avatar
miniphatty
Originally Posted by The Meal
No, say it ain't so. :( :( Do you have a reference or link for this information?
~Neal
Drove mine out two days ago and it has the secret compartment - Very very cool imo. (Week 40 production car).
Old Nov 19, 2007 | 08:48 AM
  #602
The Meal's Avatar
The Meal
Cool to hear. Label me hypocritical, but I'm hoping to have the secret compartment *and* the USB functionality with the bluetooth (which I rather doubt will be available as I hear it's a) one of the few advantages offered by an '08 model, and b) actually expected to be rolled out *late* to US cars for that model year). My build is a Wk 45, so we'll see...
~Neal
Old Nov 19, 2007 | 08:50 AM
  #603
miniphatty's Avatar
miniphatty
Originally Posted by laughbuddha
Can't we just let him enjoy his discovery and share that joy with us?
So far, i've asked 6 people to push the secret compartment and when it opened out, they all went "oooh".
I knew about the secret from these forums but i went "oooh" when i finally opened it in mine
Old Nov 19, 2007 | 12:29 PM
  #604
Cabbagehead's Avatar
Cabbagehead
Pushing the start button will not shut off the engine if the Mini is going faster than approximately 5 mph.
Old Nov 19, 2007 | 12:46 PM
  #605
daffodildeb's Avatar
daffodildeb
Originally Posted by oxyblue11
The later models DO have the hidden compartment. The ones on the early models are sealed.
Nope--there's a retrofit for the early models that came in with the compartment sealed. Mine is a week 3 build, and it was fitted with the compartment a few months ago.
Old Nov 19, 2007 | 01:46 PM
  #606
Rubbus's Avatar
Rubbus
Originally Posted by Robin Casady
I had a similar experience going back to my 1990 Acura Integra (keeping it as a garbage scow)...
LOL! That really cracked me up!
Old Nov 19, 2007 | 01:51 PM
  #607
ddnmkun's Avatar
ddnmkun
The $500 option driving lamps are very bright that it can only be turned on together with High beam.
Which is kinda useless under most driving conditions..
Old Nov 19, 2007 | 01:53 PM
  #608
CaMiniMe's Avatar
CaMiniMe
is there a way to open the rear hatch without pushing the button on the FOB?
Old Nov 19, 2007 | 02:00 PM
  #609
oldsbear's Avatar
oldsbear
There is a button under the handle on the hatch. It works if the car is unlocked.
Old Nov 19, 2007 | 02:09 PM
  #610
daffodildeb
Mine doesn't work.
Old Nov 19, 2007 | 02:13 PM
  #611
jascooper's Avatar
jascooper
Originally Posted by daffodildeb
Mine doesn't work.
It's not in the center. It's kinda off to the side under a rubber hump...
Old Nov 19, 2007 | 09:18 PM
  #612
Minidrivr's Avatar
Minidrivr
Also if you have the convenience package, it will unlock and open the hatch if you have the key fob in your pocket. And it just unlocks the boot, not the doors. It relocks when you close it too.
Old Nov 28, 2007 | 06:52 AM
  #613
jascooper's Avatar
jascooper
If you have to push really hard to shut the boot, you can adjust the rubber stops to make it easier.
I had to get out of the car a couple of times when the warning light was on because I didn't push hard enough when closing the boot. Screwing down the stops solved the problem.
Old Nov 28, 2007 | 07:03 AM
  #614
R56 Ed's Avatar
R56 Ed
Unlike my Garmin StreetPilot, the MINI Nav system actually works in buildings and underground! Yesterday I was in a big parking garage, bottom level, and the screen showed every move I made! I've even been in long tunnels (under the Chesapeake Bay) and the system still shows my progress through the tunnel. I always thought the antenna needed a clear path to the satellites, but maybe there is also a gyrocompass onboard that helps out? This thing even works in my home garage. How's it do that?
Old Nov 28, 2007 | 07:48 AM
  #615
Robin Casady's Avatar
Robin Casady
IIRC, you can also adjust the position of the latch on the body of the car. When you compress the rubber bumpers, it changes the cushioning. Changing the latch would be the desired way to adjust the boot closing.
Old Nov 28, 2007 | 07:51 AM
  #616
Robin Casady
I believe that the NAV uses info from the OBC to tell how far you've moved, and in what direction. This is information an add-on NAV would not have access to.
Old Nov 28, 2007 | 08:09 AM
  #617
jankey's Avatar
jankey
How do you know the date of birth of your MINI? How can I find mine?
Old Nov 28, 2007 | 08:42 AM
  #618
TheOfficeMaven's Avatar
TheOfficeMaven
Indeed. The feature is called "Dead Reckoning" and it's part of most OEM nav systems and some high end portable units as well. The nav system is hooked into the speedometer of the car as well as the reversing system in order to allow it to continue to navigate without a satellite fix.
Old Nov 28, 2007 | 08:49 AM
  #619
jascooper's Avatar
jascooper
Changing the latch position would change the alignment of the body panels and would not be the desired way. The rubber stops are easily adjusted for a reason. Wrong again, Robin!!!
Old Nov 28, 2007 | 09:53 AM
  #620
Minidrivr's Avatar
Minidrivr
That could be dead reckoning or it could be the OEM nav uses a good chipset. Newer Garmin units with the Sirf chipsets can get locks without any view of the sky. My 76CSx works wonders, even in tunnels and concrete structures like parking garages.
Old Nov 28, 2007 | 09:56 AM
  #621
TheBigNewt's Avatar
TheBigNewt
Hold down the reset trip odometer button on the tach for about a minute. A bunch of information about the car appears including the VIN number and as I recall the build date or week. I found this by accident and posted it somewhere.
Old Nov 28, 2007 | 10:08 AM
  #622
TheOfficeMaven
It's DR for sure. All the high end Siemens VDO units support it (and they make the MINI's nav system). However, the MINI's nav system does have a great ability to rapidly obtain and lock a satellite fix as well. I'm not sure what chipset it uses for its GPS receiver though (although I kind of doubt it's a SiRF since the system has been around longer than those chipsets have been - at least for the 1st gen cars anyway).
Old Nov 28, 2007 | 11:04 AM
  #623
R56 Ed's Avatar
R56 Ed
Thanks everybody! It even registers turns in the underground garage! How cool is that?
Old Nov 28, 2007 | 11:56 AM
  #624
jankey's Avatar
jankey
Hey Newt
It worked!!! My Dol was born 6/12/7. Thanks so much for the info.
Old Nov 28, 2007 | 12:26 PM
  #625
SteelersFan's Avatar
SteelersFan
Here is your original thread. Very good info!
