R56 Things you didn't know about your R56 MINI
Anyone notice if you leave your lights on the car doesn't "ding" at you? Instead, they turn off with the car, and come back on as soon as you start it again.
I, for some reason, left my lights on a couple times in the beginning and was happy this happened.... otherwise, I would have come out to a dead battery.
Jim
Thank you for the info on the random radio glitch. This is something that has been puzzling me for some time. I even posted a thread on this, but got no responses making me think I was crazy. Would this be related to the push button computer on the end of the turn signal stalk? Sometimes it seems that the computer decides to randomly switch modes (like from displaying speed to the next display). I swear I haven't accidentally hit the little button.
Jim
Jim
The problem is when you're half-way through changing gear AND you need to dip your lights, eg when coming into a blind curve or over a crest. In Australia MINI doesn't bother to move the lights stalk to the other side, so I get the same problem - can't dip the lights and change gear simultaneously. (As the occasional oncoming blinded driver will testify.)
IMHO the best way for dipping lights is one noone has used, to my knowledge - where you push the stalk AWAY to dip the lights and pull it towards you for high beam. The advantage is that you sometimes need to quickly dip the lights and you can just flick your hand at the stalk in a single movement. Pulling the stalk towards you is a slower, double movement, more suited to putting high beam and driving lights on because you don't normally have to do that unexpectedly.
I set my rally car up this way years ago - but I only bothered because I had to change the whole lights setup anyway. It was a Japanese-spec Datsun P510 with the circuits permanently powered (the switch closed "earth") and where the stalk swapped between running lights and low-beam headlights or between low and high beam depending on the position of the dashboard switch. Seriously weird.
Let me guess - you drive an auto?
Jim
And it's not so good for the lights, either.
If you think the Mini is hard work, I used to have a Mercedes with its single multi-function stalk on the left, so the left hand had to do the wipers as well!
Andrew
BTW, in Australia we used to call it "three on the tree" to rhyme the same as "four on the floor".
However, I think it's also BMW being lazy/cheap. I used to have a Belgium-built Astra with the stalk on the left, but I have a new Astra loan car (the MINI is sick) and they've gone to the trouble of swapping the stalks for right-hand-drive this time. For the BMWs, most in Australia are autos so it's no big deal but lots of the MINIs are manuals which is where it matters - maybe they just didn't think that through or something.
I'd never thought of that. Makes good sense!
The only time the MINI dings with the lights on is when the light switch is in the middle, running lights, position. When the lights are full on, they all turn off with the key. But when the switch is in the middle, running lights only on, position, the car bings until you turn the switch all the way on or off.
After a year and a half of owning my MINI, I am STILL discovering new things.
If you are listening to your ipod and you press the small "m" button on the dash, then turn the selector ***, you can jump songs by 10 songs. ie: you listening to track number 113, you press the"m" button, move the dial to the right and it'll jump to 123, 133, 143, 153, 163 etc.
Dunno what this is good for
but hey, it's certainly different.
but hey, it's certainly different.Are you playing songs through a Playlist, or through selection by album and/or artist?
I just tried it...didn't work for me. Tried holding it down as I twirl the **** too. I'm using the latest iPod Classic 120gig version... I was REALLY hopeful this might be the quicker solution to scrolling through hundreds of artists or album titles...does that work for you as well or just for individual songs?
I'll have to try this on MP3 CDs. I mostly hit the "List" button and use the album & track hierarchy, but by default it just shows track numbers so maybe it'll work. When my MINI's back from the doctors' I'll give it a go.
When you say "daytime running lights", do you mean the headlights on low beam, or do you have separate running lights like they do in places like Sweden? If it's the headlights, could you describe where the menu option is - I haven't found it and maybe it's a US-spec only thing.
With the lights set to the Parking light option I find that to be closer to a true Daytime running light, although with the tail lights also active (which I fine with me).
Things you didn't know....
Bought my Mini in Dec 2007, just found out that not only are the seats heated(knew that) but the back of the seat is also heated! Not very cold here & don't use it much in the winter anyway. Maybe I'll try reading the owner's manual again.
What do you mean by "back"? Lower back, only, right?
When you say "track # 113"...my display shows song titles, not Track #s...so you said you're using an iPod...what version?
The main difference between daytime running lights and just leaving the low-beams on is that the dash lights don't turn on with daytime running lights.
In my NAV equipped 2007, you turn on daytime running lights in the Settings menu. Not sure how it is done on more primitive models.
No, the heat radiates all the up the back. It works great after a long day on the course or a tough excercise work out.
#6 is the heating element for the back.
I'll be out of warranty in about 12,000 miles. Guess I need to get cracking on checking this out. Wonder if it will be cool(er) at MITM?
Don't laugh--I've been in the Rockies in 90° weather. No fun. And we've had a record summer so far in the Houston area.
(I'm moving--just need to figure out where. Retirement next year!!!)
