R56 Things you didn't know about your R56 MINI
Your outside mirrors can be rotated a quarter turn towards the window and reduce side clearance.
They are on a spring-loaded latch, just slightly raise them as you rotate them.
There is also a "Power-Fold" option to do this with an electric motor on a switch.
Saw them unloading one of the completely enclosed 'MINI Carriers" from Brunswick at the new
Fort Myers MINI Dealership, no room for mirrors inside the Transport.
Whoa! That sounds great (folding the mirrors manually)! Can you post a photo of what they look like folded, or describe in a little more detail how to do it? (I'm afraid I'll twist the wrong way or too hard and end up breaking the mirror).
Thanks for the tip...this is one of the very few I've seen that I didn't know about.
When returned to normal position, you can feel a very positive, spring-loaded 'detent' that keeps them in position.
Just grab with both hands and twist, you will not break anything and they will twist that quarter turn in either direction, so if you clip a pole backing up, it might save the mirror.
^^^^^ And only if you are going to lay the seat backs down, lay the hat-shelf in the fold, fits great and more importantly, prevents the seat-belt attach points from marking the seat backs.
It is probably in this huge thread somewhere, but I just picked up my 2010 MCS and there are Puddle Lamps under each door! I had no idea until I opened my door and noticed all this light on the snow on the ground below. Sure enough, I looked under the door panel and there was a light there. Cool!
sorry. after you pointed it out, i realized it's still confusing how it's oriented, but yeah, "good side" towards the front, the "curve" goes over the hump, and that "lip" kinda wraps around the edge of the rear seats.
I can if it is in a paper sleeve. Haven't tried a hard plastic shell. I also keep my GPS in its case in there when not in use.
Not sure if everyone has it - it's part of the "storage pack" option, with the storage nets on the transmission tunnel and boot, etc. Australian cars all have the "pack" as standard now (early R56s missed out) - maybe US ones do too. I gather that if you order the CD 6-stacker, this is where it goes.
Same with 2007. Did you notice that the trianagular nets have two layers and an opening at the edge? You can put things inside them, as well as using them to hold things against the side of the boot.
And - depending on which way you fit them, you can have the opening either facing the hatch or the back seat (or one of each). I carry my fold-up umbrella in one of them, and with the opening facing the hatch it rattled on the hatch, but other way around it's fine. Also a good place for tyre gauge, spare driving light globes, and assorted other paraphenalia.
The triangle net in the boot is perfect for a bottle of vino
. You can even twist the net around the neck to keep it securely in place for any sharp cornering that may be required (or any sharp cornering for fun ;-)
Jim
I still use one triangular net with the boot box (great for groceries and twisty roads). The box doesn't go the full width of the boot, so there is room for the net with my flat tire repair kit.
