R56 N18 valve cover replacement
Old May 15, 2021 | 02:54 PM
jncunha's Avatar
jncunha
Hi,
My 2011 Cooper S has a leak all around the valve cover. I can't see oil pooling on the connection between the block and the cover but the block is stained with oil.
I'm looking to get a replacement valve cover and I'm wondering if anyone has experience with aftermarket ones or if it makes sense to get a replacement one from the dealer (much more expensive).
I can find a bunch of them in eBay but I don't know much about these brands and how they perform with time. Does anyone have any experience?
https://www.ebay.de/itm/373216307759...53.m1438.l2649
https://www.ebay.de/itm/203196421490...53.m1438.l2649
https://www.ebay.de/itm/133537082500...53.m1438.l2649
Thanks!
Old May 16, 2021 | 04:36 PM
Yoshimura 1's Avatar
Yoshimura 1
Look at ECS tuning for a valve cover
Old May 17, 2021 | 11:48 AM
We have the fitments and the correct ones if you select your MINI.
https://www.ecstuning.com/Mini-2011-...s/Valve_Cover/
Old May 17, 2021 | 11:35 PM
jncunha's Avatar
jncunha
I would love to the ECS part but the thing is that I'm based in Europe and I believe that delivery costs will be high (given the size of the part) and the time to get it here will be at least 2 weeks.
Old May 18, 2021 | 11:30 AM
We ship worldwide and you can get more items you cant get over there from us and place a larger order. You can also change the shipping to ship faster with a cost.
Old May 18, 2021 | 11:41 AM
Minifenrir's Avatar
Minifenrir
Just replace the valve cover gasket, it's much cheaper. I just changed mine out this past weekend along with a new PCV diaphragm. 2011 Cooper S
Old May 19, 2021 | 09:14 AM
jncunha's Avatar
jncunha
That's something to consider for sure. I'll take a look at the website then.
Where did you get the gasket and the PCV diaphragm? Are they OEM?
Old May 19, 2021 | 10:10 AM
Minifenrir's Avatar
Minifenrir
ECS has a good selection of valve cover gaskets. I also buy from Pelican Parts, Way Motor Works and a few others. To be honest the PCV diaphragm came from eBay.
https://www.ecstuning.com/b-genuine-...t/11127582400/
Old Jun 23, 2021 | 06:07 PM
Dcb22's Avatar
Dcb22
Thanks!
Old Jun 23, 2021 | 06:11 PM
Minifenrir's Avatar
Minifenrir
Old Jun 23, 2021 | 06:12 PM
Dcb22's Avatar
Dcb22
Awesome! I just found this video showing how to do it:
I also have a 2011 MCS
Old Jun 24, 2021 | 01:37 PM
Thats right here: https://www.ecstuning.com/b-hamburg-...27646552v~ham/
Old Apr 10, 2022 | 06:19 AM
Bossworld's Avatar
Bossworld
Sorry, bumping an older thread but any more thoughts on after market rocker covers?
I previously tried changing out the PCV and cover only, and the car ran terribly with the aftermarket PCV. Had to put the old one back (with one snapped clip) and it's been OK for two years since but I've still got a chirping noise at low revs and it's either the PCV or a pulley.
Old Apr 18, 2022 | 11:27 AM
The ones we have are good. Make sure you get the ones from us and it was installed correctly.
Sounds like the pulley. When it chirps,.
Old Apr 20, 2022 | 05:14 AM
bagwell's Avatar
bagwell
same issue I had when I swapped mine :(
Old Apr 20, 2022 | 08:01 AM
Gubi's Avatar
Gubi
I got a Uro Parts brand one for my 2012 and it worked perfectly fine.
After ten years the original PCV diaphragm was pretty darned shot. Should've replaced it sooner, I think.
Frixos
Dec 30, 2019 11:24 AM
Jwanck11
17
Nov 13, 2019 07:05 AM
Tom.R56
Apr 3, 2019 10:56 AM
Wado1
R55 :: Clubman Talk (2008+)
Sep 9, 2016 05:46 AM
TheZap
Apr 1, 2014 05:59 AM
