R56 2013 R56S oil pressure sensor wiring
Long story...need to know which color wire connects to which color wire on either side of connecting harness for OP sensor. Anyone know or have access to wiring diagram with wire colors indicated.
Thanks!
Thanks!
here you go
https://www.newtis.info/tisv2/a/en/r...ntrol/CkYCzqZ9
if you look inside the plug, you will see the numbers or at least no.1 pin notated.
oil pressure sensor wiring colours
so my three wires are different colours than the diagrams in this thread. I have a 2013.3 N16. there is a green and a black twisted together, and a white. my hope is that I can figure out how to use the three-wire sensor in the oil filter housing of my new N16, in my single-wire 2007 that had the head mounted sensor. or find a single-wire sensor that fits the oil filter sensor hole.
Oil pressure solenoid
here you go
Oil pressure valve is the sensor on the oil filter housing. The solenoid is the one attached to the oil pump. Read live data of the oil sensor to see what the numbers are and if they make sense.
VisualMemoryUnit
Feb 3, 2021 10:23 PM
victor247
Jul 22, 2014 07:26 PM
K9Projectworks
Sep 12, 2011 07:01 AM
