Drivetrain Where is the FRP Sensor wire located? (meth kit install)
Old May 6, 2019 | 12:21 PM
VisualMemoryUnit's Avatar
VisualMemoryUnit
I been searching for help for a few days on this, any help to push me in the right direction would be greatly appreciated.
I have an n18 r60 with a jcw turbo swap. I bought the snow performance stage 3 meth kit and I'm trying to wire it up but I hit a wall. The instructions say to tap into the Fuel Rail Pressure output wire, I cannot find where this wire is. Does anyone know how or where I can tap into this wire?
Old May 6, 2019 | 12:36 PM
VisualMemoryUnit
Picture of instructions.
Step 6 is where I'm having an issue.
Old May 6, 2019 | 01:29 PM
NeonLed's Avatar
NeonLed
Here you go. Just click on the blue ID numbers to see where the wire goes, like (X60232), then you can see the connector view of it to see the pin out of the connector. https://www.newtis.info/tisv2/a/en/r...ystem/CkWtJMJk
Old May 6, 2019 | 08:00 PM
VisualMemoryUnit
Thank you so much! This helps a lot.
Old Feb 2, 2021 | 11:37 PM
Khairun Lamb's Avatar
Khairun Lamb
I have the same set and could not find where to tap for IDC. I clicked the link but does not seem to work anymore. Where did you tap and what kinda settings do you have? Appreciate the help
Old Feb 3, 2021 | 12:43 PM
thebombardier's Avatar
thebombardier
I found this guide for installing an Aquamist kit on an R56 showing the pin out on the ECU harness. Top for N14 and bottom for N18.
Old Feb 3, 2021 | 10:23 PM
Khairun Lamb
Thanks Bombardier!!!!
I just checked on mine and it has 2 blue wires which is supposed to be tapped as instructions below. So I guess I just follow as per right?
Step 6: Using preferred electrical fitting connect each BLUE wire to the wires on a single fuel injector. The wires are interchangeable.
Appreciate the help, Meth newbie here..... :-)
durantson
Apr 1, 2020 07:33 AM
victor247
Jul 22, 2014 07:26 PM
Axion
Electrical
Nov 14, 2011 10:24 PM
qwertmonkey
Jun 6, 2006 07:44 AM
