Interior/Exterior Wire Routing Troubles
Old Jun 5, 2006 | 02:52 PM
qwertmonkey's Avatar
qwertmonkey
I am trying to route a wire from the engine bay to the cabin. I know that there is a harness that passes through by the right cowl, but how do you get a wire through there!??! There is a rubber thing over it REALLY tight that I can move. Is there another way to get through? I'll post pics If I need to.
Thanks,
William
Old Jun 5, 2006 | 03:05 PM
Rev. Limiter's Avatar
Rev. Limiter
Not sure if it will work in this case, but what I generally do is take a wire coat hanger, snip off the "hook" and "twist" part, round the ragged edges with a flat file and shove it next to the existing wires in the middle of the rubber grommet and thru the firewall.
Once thru, tie the wire to the coat hanger (I use 0.030 safety wire) and rapidly "pop" the coat hanger thru the rubber grommet with a rapid movement.
UKSUV's Avatar
UKSUV
It's just a really tight dust boot. Try try try harder.
Old Jun 5, 2006 | 03:12 PM
qwertmonkey
Where does it come through on the other side? I have looked under the drivers side foot well, and cant seem to find it.
Old Jun 5, 2006 | 03:13 PM
onasled's Avatar
onasled
The best way to run a wire through there is this, Poke a small hole through the rubber, just off to one side of the center. Now take a small tube, something about the size of a large drinking straw, but stronger and work it through that small hole you made, the rubber will stretch out enough so it's a very tight seal. Now you have a chase to run wires through.
Trying to get a coat hanger through the center hole where all the wires run is a bad idea. If you damage one of those wires you are in very big trouble.
Old Jun 5, 2006 | 03:14 PM
onasled's Avatar
onasled
Look up ....
Old Jun 5, 2006 | 03:24 PM
qwertmonkey
I did! Call me stupid, but I cant seem to find it!!! LOL! I will take a pictue of it, then someone can circle it, then repost the pic! I feel so stupid! lol thanks for all the help!
Old Jun 5, 2006 | 04:18 PM
kenchan's Avatar
kenchan
poke a hole, take a coat hanger, straighten it out, tape the wire to the tip of the
hanger and just push it through the hole from the engine bay.
then roll onto the floor of your driver side with your back on the floor, look up
with a flash light. if you still can't see it, forget it. you weren't meant to be
working on cars. jk (it's that easy).
Old Jun 5, 2006 | 05:44 PM
qwertmonkey
Its probably just SO obvious that I am ignoring it! I'll do a combo of that and the "straw" idea. I have some 1/8th'' hose from a fish tank that I'll use.
Thanks everyone for the help!
Old Jun 5, 2006 | 05:58 PM
petecrosby's Avatar
petecrosby
I use weedeater line. It's flourescent yellow and, unlike a coat hanger,
non-conductive. Just push it through, tie your wire to the other end,
and pull it through. Works great.
Old Jun 5, 2006 | 07:50 PM
qwertmonkey
non-conductive.
I've got a ton of that. I'll try that too!
Old Jun 6, 2006 | 07:44 AM
kenchan's Avatar
kenchan
that's a good idea!
im gonna tape my coat hanger tool...
Filmy
15
Jun 6, 2023 06:27 AM
twriter
Oct 2, 2015 03:14 PM
minimofo
Sep 30, 2015 12:26 AM
Sc00terbum
Sep 11, 2015 09:07 AM
Filmy
Sep 7, 2015 08:27 PM
