R56 Is this reasonable for a 50k R56S?
Old Feb 28, 2018 | 07:39 PM
SecretSquirrel's Avatar
SecretSquirrel
Greetings MINI folk. Ever since I had to sell my new '13 Justa only a couple of years after purchase, I've been wanting to get back into this world.
These days I'm looking at used S models, and have grown quite attached to a 2011 S for sale. Problem is, I'm not sure what repairs are normal due to the early N18s vs. abnormal at this mileage (50k). I was hoping you all could help.
The items repaired/replaced are:
Oil solenoid under warranty. It leaked. Replaced by new design
High pressure fuel pump. Replaced under special Mini program
Timing chain tensioner seal replacement under warranty
Leak repaired. Axillary coolant temp sensor
That's how they were described to me by the seller/original owner.
Thank you for anyone willing to chime in, I needed a second opinion.
Old Feb 28, 2018 | 07:50 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Welcome to NAM!
First two are common. 2nd two are not, but are pretty minor. Get the service records, and if you are at all nervous, find a MINI specialty shop to do a pre-purchase inspection.
Old Mar 1, 2018 | 04:40 PM
bcriverjunky's Avatar
bcriverjunky
It's due for brakes.
Old Mar 1, 2018 | 05:25 PM
AZdsrt's Avatar
AZdsrt
OP is also due for new battery, I didn't see it in his list..
Old Mar 1, 2018 | 10:27 PM
SecretSquirrel
The owner was just listing things he was considering beyond the standard, so there's a chance it has been done just not mentioned.
When I go take it for a spin I'll make sure to look into the brakes/battery, as all work was done at the local Mini dealer with receipts so if they were taken care of they'd be in there.
Either way, good to know in the event I'll need to do it myself.
Thanks all!
Old Mar 2, 2018 | 05:24 AM
iwashmycar's Avatar
iwashmycar
If its a N18, probably fine. If its a N14, id probably avoid the thing. I thought N18s came in mid-2012?
Old Mar 2, 2018 | 07:10 AM
cornjuice's Avatar
cornjuice
earlier for the 'S' .. JCW changed to N18 mid 2012.
I would schedule a leak down/compression test. If the previous owner/s only drove around town and were scared of the tachometer.. its likely got a thick plastering of carbon on the valves. Taking a look at the spark plugs will give you an idea of what youre dealing with as far a carbon coke too (unless they were changed very recently).
Old Mar 2, 2018 | 08:06 PM
squawSkiBum
Moderator
2011 S is most likely N18. See the FAQ and run the VIN through the VIN decoder, or see realoem.com.
Pat_Cooper
Jan 25, 2006 01:55 PM
dcsmd007
Feb 27, 2004 07:37 AM
chollomo
17
Nov 1, 2003 05:51 AM
chrisfb1
Oct 15, 2003 05:00 AM
