R56 Wheel Size Question
Old Mar 23, 2014 | 08:58 AM
DOtheDEW's Avatar
DOtheDEW
Wheel Size Question
i found a nice deal on a used set of bbs CV 17inch ET38, would that be safe to run?
Old Mar 23, 2014 | 09:07 AM
BubbaJCW's Avatar
BubbaJCW
I'll jump in here and make a few assumptions.........
I had these on my Electra Townie 21 speed, 21" out of San Diego, Ca.
We mostly went on paved pathways and stayed away from the crushed gravel paths.
I kept them at around 65 psi and felt the ride was smoother than 60 psi as recommended.
The wife liked the look also...so that was a plus.
So.......I say if your on a 21" they should be fine.
Old Mar 23, 2014 | 12:21 PM
DOtheDEW's Avatar
DOtheDEW
they would be 17"..... basically what I'm asking is, would ET38 be safe to run on a mini?
Old Mar 23, 2014 | 03:39 PM
cristo's Avatar
cristo
Alliance Member
Don't those bicycles take 26" tires?
Old Mar 23, 2014 | 04:34 PM
BubbaJCW's Avatar
BubbaJCW
Yes, yes they do.
But I'm into the DUB, LowRider look.
Not so much the feel.
I've got the original "26 in the marketplace, very good price!
Old Mar 23, 2014 | 08:00 PM
JONNYBOY's Avatar
JONNYBOY
I just got a set of 17x7 XXRs ET35. I have a 13' S with stock suspension, they definitely stick out more than the stock rims haha I like the look though, but do I have any fitment issues? no. and with yours being ET38 they wont come out as far. just be careful with the width. im lowering mine with H&R springs soon ill let you know how they fit then
Old Mar 23, 2014 | 08:19 PM
cristo's Avatar
cristo
Alliance Member
I have 16x7 +42 with 205/50 16 tires and although it looks like there's another 4 mm room
to go out further, TireRack lists the BBS RGR in 17x7 +38 for the MINI MCS, but they also state:
"MAY REQUIRE MODIFICATION TO THE REAR PLASTIC FENDER LINER. Use 205/45-17 for best fit."
Old Mar 24, 2014 | 11:52 AM
DOtheDEW's Avatar
DOtheDEW
From what im reading im pretty sure the wheels at 7.5 and the tires on them at 215/40, im lowered on nm springs..would these be too wide? Im not really down to trim the plastic
Old Mar 24, 2014 | 11:57 AM
DOtheDEW's Avatar
DOtheDEW
Can you post a picture ofyour wheels on your mini
Old Mar 24, 2014 | 02:18 PM
v10climber's Avatar
v10climber
You'd probably be OK. 205s would be better. You might rub some on big bumps but eventually the tire will rub through the fender liner where appropriate. The rear would be the concern. If you email NM Engineering they might be able to help you out.
Old Mar 24, 2014 | 04:00 PM
jkruzer2001's Avatar
jkruzer2001
I have a 2008 mini cooper s I'm looking for new wheels My current size is 195/55R16 how do I know what sizes I can run?
Old Mar 25, 2014 | 09:27 AM
DOtheDEW's Avatar
DOtheDEW
thanks! I think I'm going to go with 205s if I pick up these wheels!
thebordella
Aug 31, 2015 01:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
wind715
Aug 11, 2015 07:56 AM
