R56 NHSTA MINI 2007- 2011 Recall
Old Feb 13, 2012 | 03:48 PM
  #151
daffodildeb's Avatar
daffodildeb
Originally Posted by amirs4
Question, I had my water pump fail at 55K miles and this recall would have been nice then, do you think there is a chance to recoop money spent on a failed water pump?
I'm no mechanic, but I was told it's the "auxiliary water pump" that is under recall. Is that what you replaced?
Old Feb 13, 2012 | 04:12 PM
  #152
drsimmons's Avatar
drsimmons
I'm still waiting on a recall letter and I'm not sure if their fix actually includes replacement of the entire water pump or just a part of it.
Need to find out exactly what the fix is. I'm sure someone out here has had it done to date. Maybe they can tell us. If it is the entire pump, you may have some recourse but I wouldn't hold my breath.
Old Feb 13, 2012 | 05:14 PM
  #153
Slave to Felines's Avatar
Slave to Felines
This recall is only for the auxiliary (second) water pump for the turbo specifically. And, if I read it correctly, specifically for the electrical part of the pump, though the whole pump gets replaced (?).
So if your aux water pump failed, you can make a case for reimbursement. If the electrical part of it failed, you have a stronger case. If it was your main water pump (or you have a Justa instead of an S or a JCW, or your car is too old or too new for the recall) you are SOL.
Old Feb 13, 2012 | 05:39 PM
  #154
drsimmons's Avatar
drsimmons
Didn't realize there were actually 2 water pumps, aux and main. This explains it. I was under the impression it's only the electrical part that is replaced but not sure.
Old Feb 13, 2012 | 06:52 PM
  #155
daffodildeb
I don't believe the "main" water pump was replaced when I had my recall done. I was told it was just for the auxiliary pump. And that while the only defect is actually a circult board, the board is inside the aux pump, hence the replacement of the entire part.
Again, I'm not a mechanic, just going on what I've heard. Why don't you call the dealer?
Old Feb 13, 2012 | 07:25 PM
  #156
drsimmons's Avatar
drsimmons
I knew someone would step in that had it done and set us straight.
Old Feb 13, 2012 | 07:28 PM
  #157
daffodildeb
Happy to help, just hope I'm accurate.
Hey, did you wave when I passed through your area a couple of weeks ago?
Old Feb 14, 2012 | 05:12 AM
  #158
TNMiniMama's Avatar
TNMiniMama
I haven't gotten my recall yet, but my dealership went ahead and did my recall (and my regular maintenance while I was there). I got a call that afternoon, turns out the aux pump housing had melted, so they had to replace that as well (when they saw that, they gave my car look over with a fine tooth comb). It took them another day as they had to get the parts in (I had a loaner). When I got her back, and headed home, I found the heat was blowing cold air until I got to about 40 mph, when the heat would kick on. Back to MINI. They threw me in another loaner and fixed it. It was, indeed, a bubble in the cooling system, which is a sealed system. So they bled it, tested it to make sure it heated and sent me on my way (it was a little disconcerting having cold air blow on me when it was 22 degrees out).
I mention the last part as I believe someone said they were having heat problems.
All in all, the recall is easy UNLESS you have to have additional parts (like I did) in which case they have to order them. Parts are overnighted, but still... My dealership did a great job, but they always take good care of me, and go the extra mile. Hope y'all have an easy time of it too (just a hint, get other service work done at the same time, make the app't and get a loaner...)
Old Feb 14, 2012 | 07:31 AM
  #159
Tee Tang's Avatar
Tee Tang
Here is the picture of Additional Water Pump with part number.
Old Feb 14, 2012 | 09:56 AM
  #160
daffodildeb
Who's your dealer? I'm expecting to move to Arkansas, and they don't have a dealer. Any info about the Memphis dealer?
Old Feb 14, 2012 | 12:00 PM
  #161
AlbanyRocs's Avatar
AlbanyRocs
sorry that i didn't read all of the 7 pages so this may have been covered already.....does this replacement of the water pump effect your gas mileage? what are the downsides?
Old Feb 14, 2012 | 12:21 PM
  #162
drsimmons's Avatar
drsimmons
If you passed me somewhere down here, I'm sure I would have waved. I do to every Mini I see regardless if they wave back or not. Most do, however.
Old Feb 14, 2012 | 12:22 PM
  #163
drsimmons's Avatar
drsimmons
Shouldn't have any impact on your gas mileage.
It's the aux. water pump to the turbo.
Old Feb 14, 2012 | 03:43 PM
  #164
daffodildeb
You're lucky. Around here I rarely get a wave--too many in the Houston area. I always get waves in Florida, though, and in other states.
You'd recognize my car if you saw it. The photo in my signature was taken before the side graphics were put on--Carerra font "Turbo" in white on the red doors!
Old Feb 14, 2012 | 03:47 PM
  #165
daffodildeb
I've seen no downside--no effects at all, for that matter. If you don't have it done, there's a small (exceedingly small) chance you could have a fire. I don't like fires in my cars.
Old Feb 14, 2012 | 06:21 PM
  #166
cccplus's Avatar
cccplus
In this recall, will the dealer bleed and replace the coolant (coolant flush), too?
Old Feb 14, 2012 | 07:18 PM
  #167
drsimmons's Avatar
drsimmons
They won't do a full flush but top off any lost coolant and probably do a pressure test as well.
Old Feb 15, 2012 | 04:52 AM
  #168
yetti96's Avatar
yetti96
Correct, they top off what ends up on the ground.
Old Feb 15, 2012 | 05:41 AM
  #169
richardsperry's Avatar
richardsperry
Mini of Baltimore just did this for my car. I hadn't gotten the letter yet, but they knew it was coming. About 1.5 hrs, waiting in the showroom, kicking tires... I can think of worse was to spend time.
Black JCW coupe with red roof and stripes is so cool looking, but DAMN! $39K??? For $10K more you could buy a 1M...
Old Feb 15, 2012 | 03:25 PM
  #170
Benibiker's Avatar
Benibiker
Originally Posted by rudeboim3
So if someone has a faulty water pump issue, what symptoms are we looking for?
If you have a faulty aux water pump (subject of the current recall) you'll get a CEL telling you something is amiss, if you have bad luck you'll also see smoke and flames coming from under your hood.
Old Feb 15, 2012 | 03:49 PM
  #171
daffodildeb
Originally Posted by Benibiker
...if you have bad luck you'll also see smoke and flames coming from under your hood.
Old Feb 15, 2012 | 03:50 PM
  #172
drsimmons's Avatar
drsimmons
My understanding is there have only been like 12 fires caused by the issue. That's a pretty low % compared to the amount of Mini's out there.
I saw the other day Toyota is looking at some fire issues as well so we're not the only ones with troubles.
Old Feb 15, 2012 | 07:10 PM
  #173
BEFCo's Avatar
BEFCo
Modern cars seem to have a lot of problems, whatever the maker. For me I simply enjoy the hell out of my MINI, so I take all the negative shtuff in stride (I know right?!?).
Old Feb 15, 2012 | 07:24 PM
  #174
daffodildeb
Remember the Pantera sports car, back in the 70's? A friend of mine bought one, brand new, and was driving it home. He had a brake lock up on him out in the middle of nowhere and start a fire, but he had no fire extinguisher. Er, well, actually, he did have one. One that relies on a previously-ingested supply of Coke or ice tea.
It worked. Really.
Old Feb 16, 2012 | 07:30 AM
  #175
drsimmons's Avatar
drsimmons
Me too. All the negative stuff does make you a little paronoid but also makes me more proactive in my daily/weekly maintenance programs.
My wife has a 2011 Nissan Juke (cool car and turbo) and it's already had a recall on the turbo. Something about a line that could come loose. Fixed it and so far ok.
