R56 New Mini Cooper Intake from AEM
Old Mar 10, 2014 | 12:20 PM
  #401
bratling's Avatar
bratling
Super Moderator
Originally Posted by mikeyb74
I love it but have noticed the BSH OCC is rubbing on the intake pipe. What would be the fix for this that?
Is this a trick question? Move the oil can. Unbolt the OCC's mounting bracket, grab big pair of pliers, stick it in a vise, bend it until you've got some clearance, reinstall.
(Or am I missing something? )
Old Mar 10, 2014 | 12:34 PM
  #402
mikeyb74's Avatar
mikeyb74
No trick question. :P
Old Mar 10, 2014 | 12:39 PM
  #403
madmaxxed's Avatar
madmaxxed
Is this a trick question? Move the oil can. Unbolt the OCC's mounting bracket, grab big pair of pliers, stick it in a vise, bend it until you've got some clearance, reinstall. (Or am I missing something? )
Agreed. Reposition the catch can and reroute new hose if you need to. My occ was hitting the typhoon intake tube but simply turned the can and bought longer hose.
Old Mar 30, 2014 | 06:26 AM
  #404
mikeyb74's Avatar
mikeyb74
Installed the AEM strut bar and relocated the OCC. Strut bar looks really good installed.
Old Mar 30, 2014 | 06:30 AM
  #405
vetsvette's Avatar
vetsvette
Moderator
Could you post a picture of the bar installed? I'm planning on getting one, but am unsure if the OCC will interfere.
Old Mar 30, 2014 | 06:32 AM
  #406
mikeyb74's Avatar
mikeyb74
It will interfere. The bar hits the top of the OCC. I'll have to take a pic or two for you.
Old Mar 30, 2014 | 08:02 AM
  #407
vetsvette's Avatar
vetsvette
Moderator
That would be much appreciated.
Old Mar 30, 2014 | 08:12 AM
  #408
elsenordave's Avatar
elsenordave
what he said
Old Apr 1, 2014 | 03:33 PM
  #409
mikeyb74's Avatar
mikeyb74
Here you guys go.
Attached Thumbnails New Mini Cooper Intake from AEM-image-4207721722.jpg   New Mini Cooper Intake from AEM-image-115331541.jpg   New Mini Cooper Intake from AEM-image-481318301.jpg   New Mini Cooper Intake from AEM-image-1860040275.jpg
Old Apr 1, 2014 | 05:53 PM
  #410
Systemlord's Avatar
Systemlord
Here you guys go.
You need to use some lock washers or loctite on those threads, when I had mine it lost two screws, use a fiber washer if worried about the finish. Nice OCC mounting job! Whoever purchased my AEM system got very expensive chrome screws and chrome washers that cost me $30!
Old Apr 1, 2014 | 06:06 PM
  #411
mikeyb74's Avatar
mikeyb74
I haven't had the chance to see what I have at work for screws. Thanks!
Old May 21, 2014 | 09:03 AM
  #412
dez's Avatar
dez
Read thru this whole thread and think I'm about to pull the trigger on this bad boy... Just to confirm AEM never did get this CARB certified correct?
Old May 21, 2014 | 11:30 AM
  #413
Systemlord's Avatar
Systemlord
They applied but never heard a peep from CARB, I don't see why it's such a big deal, it doesn't change much in the way of emissions. For some reason I ran way lean on the AEM intake, there were times I think fuel just completely stopped flowing at a very short interval like it was coughing!
Old May 21, 2014 | 07:02 PM
  #414
dez's Avatar
dez
So, does that mean you no longer have the AEM CAI?
Can you give me a little more detail on the statement regarding the fuel flow? How is that affected by the CAI?
Old May 22, 2014 | 12:49 AM
  #415
Systemlord's Avatar
Systemlord
I've kind of suspected that at some points in the rpm range I'm running lean, it's a personal problem I plan on shining some light on via testing both pumps and or monitoring air fuel ratios on a dyno. I didn't like my torque dropping off at 3300 rpms, the stock intake torque doesn't drop till 4500 rpms. Another strange thing, it seems I have more power with AC on max! I don't understand why? Turn AC off I lose pulling power.
Old May 28, 2014 | 08:49 AM
  #416
dez's Avatar
dez
can anyone else comment on loss of power/torque at 3300 rpm vs 4500 rpm? Is this a common issue with this CAI or is it isolated to Systemlord's set up?
Old May 28, 2014 | 08:58 AM
  #417
dez's Avatar
dez
Also just to confirm since I have a 2011 JCW with the N14 engine, I need the 21-699C correct? not the 21-721C
Old May 28, 2014 | 10:08 AM
  #418
bratling's Avatar
bratling
Super Moderator
I haven't noticed it. Here's a power-to-speed graph generated by Dynolicious:
(View larger here.)
As you can see, though it doesn't graph to RPM, there are no weird dips compared to stock. It's a little quicker to redline.
Here's the disclaimer: This is not a real dynometer, rather, it uses accelerometer data and known vehicle weight to calculate the numbers. (F=MA, if you know mass and acceleration, you can calculate force; measure these over time and you get power.) Further, these were done on subsequent days, before and after installing the CAI. Weather conditions were the same so air density shouldn't be a factor, but it's still not a rigorous test.
In any case: no dips for me. I have no other changes to the intake or exhaust systems, just the AEM intake and filter.
Correct. That said, you have a factory JCW and your results will necessarily differ from those of us with the standard (smaller) turbo charger and standard ECU.
Old May 28, 2014 | 11:20 AM
  #419
Ovrclck's Avatar
Ovrclck
The intake isn't CARB legal in CA eh?
Old May 28, 2014 | 04:51 PM
  #420
Systemlord's Avatar
Systemlord
It's not isolated to any one car, whenever you change the flow to the engine you end up changing your powerband, just ask ra2fanatic with his AEM CAI and stage 4 Battle/DNA tune. He will tell you that his torque drops off at 3300 rpms. If you look at AEM's dyno sheet it will show the torque dropping off at 3300 rpms, There is a big dip right at 3300 rpms and it starts gaining at 4700 rpms. The stock intake doesn't have a drop off until 4500 rpms and it's pulling strong all the way there!
No, afraid not.
File Type: pdf
Old May 28, 2014 | 05:29 PM
  #421
Evil4130's Avatar
Evil4130
Cai
I'm only posting this because I think I'm the only guy on this site that has actually had the car in a wind tunnel. So having said that, I have a 2013 JCW and I will only say this...the hood scoop on these cars does nothing ! Meaning there's not air going into the scoop at any given speed. The air flow goes right over the scoop and onto the bottom of the windshield which then propels the air over the car. Most companies during their dyno tunes even for their hood scoop ram air ******** leave the hood up for the dyno runs. It's all a gimmick ! Believe me or not. But if the hood scoop was functional trust me the factory would have used it...and the shape of the scoop would be different.
Have fun with all those hood scoop CAI.
Old May 28, 2014 | 05:33 PM
  #422
JCW_Coupe's Avatar
JCW_Coupe
you might want to see when the hood is closed and the aem is breathing how the scoop is pulling fresh air in like crazy
Granted i changed the stock grille on the scoop to the open metal unit, but it does sound wicked when it runs and you can hear it when its on the road and pulling like mad at FT
Old May 28, 2014 | 06:37 PM
  #423
Ovrclck's Avatar
Ovrclck
No, afraid not.
Nm engineering it is then. Thanks
Old May 28, 2014 | 07:49 PM
  #424
Systemlord's Avatar
Systemlord
That's not going to be any different, you'll lose more torque going with an open type filter intake. Restriction (stock CAI) is what gives you that snappy low-end torque, by going with an open type filter intake you going for hp at the expense of losing torque, you'll see. I just wanted you to have all the info before making your purchase. The AEM will lose less torque because it has more restriction than the NM intake, the AEM has the stock CAI piping and the hood scoop which adds some restriction.
Old May 28, 2014 | 08:47 PM
  #425
Ovrclck's Avatar
Ovrclck
Had no clue! Thank man! I guess it's worth the hassle to swap back stock CAI for smog purposes. I would be devastated if I lost that "pep".
