R56 2 different door/seatbelt chimes?
Old May 27, 2010 | 08:35 AM
fmalgapo's Avatar
fmalgapo
I noticed in my bro's 2009 Mini S with Nav has a deeper sounding Chime than my 2010 S without NAV.
Is this something new in 2010 or is it because I do not have the NAV/i-drive? I kinda like the quirky deeper chime.
Old May 27, 2010 | 09:42 AM
schatzy62's Avatar
schatzy62
Not a 2010 difference.
Depending on the options as to what the chime sounds like and what adjustments you have for it.
From experience not from what MINI says.
Without the NAV but with the HiFi there is an adjustment that adjusts the tone and volume of the chime.
With out the HIFI and NAV there is a volume adjust but it does not adjust the tone.
EDIT: but then again form car to car the adjustment also seems to vary even with the same equipment setups.
Old May 27, 2010 | 10:16 AM
RJKimbell's Avatar
RJKimbell
Door 'Ajar' Warning...
I do not seem to have a Door 'Ajar' Warning??!! My Husband and I have experimented with this, when I am in R and moving Backwards, he opens his door and there is no Door 'Ajar' Tone and no Warning displayed on the Tach...I'm confused...with all of the other Electronic Warning's the MINI gives off, did they simply Forget this one??!!
Old May 27, 2010 | 10:29 AM
fmalgapo's Avatar
fmalgapo
This is the sound mine makes...
http://www.youtube.com/watch?v=WRXCWgO1B4M
Old May 27, 2010 | 10:39 AM
Kirkz24's Avatar
Kirkz24
I know its frustrating for you, but this is one of the funniest video`s I have seen in a long time!
I sure do hope they find out what the problem is!
Old May 27, 2010 | 11:08 AM
krim's Avatar
krim
my tone is different (NAV)
i get that once in a while too, here's what i do that works about 75% of the time.
remove the key, unbuckle the seat belt, open the door, bounce up and down in the seat like an idiot a few times, close the door, insert key, acc on.
if that doesn't work,
remove key, unbuckle, get out, arm alarm twice, unlock, get in, wiggle my butt in the seat, close the door, buckle seat belt, insert key. if the chime stops, start the car. if not, scream and yell.
Old May 27, 2010 | 01:14 PM
Porthos's Avatar
Porthos
That is what mine sounds like. I like the newer one that is quieter. A couple people said that they like mine better then the quieter one.
Old May 27, 2010 | 02:05 PM
schatzy62's Avatar
schatzy62
Disconnect your battery for 30+ minutes and see if that clears the problem.
These cars are fully computer controlled and some times the only way to rest them is to do a hard reboot by disconnecting the battery.
Old May 27, 2010 | 02:39 PM
fmalgapo's Avatar
fmalgapo
Oh man...I posted the link to illustrate the noise mine makes, but I do not have the problem illustrated in the video LOL...I just used it as a reference. I have no issues with a continuous chime, I just wished I had the "cooler" chime as I mentioned in the first post but could not find an example.
So sorry for the confusion, and yes, although tragic, that video is pretty funny.
Old May 27, 2010 | 03:05 PM
MINIxB's Avatar
MINIxB
You can change the volume of the tone if you want to...
Old May 27, 2010 | 04:09 PM
Porthos's Avatar
Porthos
Nope can change the volume I do not have the option to
Old May 27, 2010 | 05:02 PM
fmalgapo's Avatar
fmalgapo
Its not the volume I want to change, its the tone of it...like the Nav cars...which I had a sound clip.
Old May 27, 2010 | 06:37 PM
proximal's Avatar
proximal
This is the other chime, for cars with navigation.
BMW used to use different chimes for cars with and without nav too but now they all use the nav one, which sounds lovely.
Old May 27, 2010 | 07:38 PM
fmalgapo's Avatar
fmalgapo
That's it! So it definitely is a Nav thing...sucks!
And yes...the BMW sound is awesome, my 135i with iDrive makes that noise! Glad to see it in the new 7.
Old May 28, 2010 | 07:37 AM
strobeyprobey's Avatar
strobeyprobey
There was a big thread about some 09 cars missing their door ajar warnings! My 08 is confirmed both doors work. I keep the Gong volume all the way down. Press the musical Note button and roll the top **** to get to the second page. (I just wish it would go lower!)
Old Jun 1, 2010 | 11:07 AM
timfitz63's Avatar
timfitz63
Like "RJKimbell," my MINI doesn't seem to make any "door ajar" noises; and I couldn't find the thread to which "strobeyprobey" referred. Mine just makes the "key-in-ignition" alert when the engine is off, and my 2009 owner's manual doesn't even mention a "door ajar" alert -- but I've also found it to be pretty vague about a lot of things, including warning tones...
Old Jun 1, 2010 | 11:29 AM
schatzy62's Avatar
schatzy62
Not sure if it was a big thread or not but I do remember some folks here talking about the door ajar missing for the passenger door. Not sure if anyone complained about the drivers door though.
Old Jul 24, 2013 | 07:29 PM
Minin's Avatar
Minin
Today i installed a boost cd on my car. The difference that i notice is that the boost cd has a little speaker on the back that is doing the annoying gong sound. To a friend of mine his car makes the softer gond sound from speakers. Can i have the sound like my friends mini? If i program it somehow?
Old Jul 24, 2013 | 08:26 PM
strobeyprobey
Yes you can with NCS expert.
Old Jul 25, 2013 | 03:58 AM
Minin's Avatar
Minin
Thank you strobeyprobey for your quick reply. Is it possible to tell me how i can achive this? U have done it?
Old Jul 25, 2013 | 10:07 AM
Slave to Felines's Avatar
Slave to Felines
Look in the "Electrical" sub-forum for R56es; the first stuck topic is "NCSExpert for beginners". That's a good place to start.
Old Jul 25, 2013 | 11:03 AM
Minin's Avatar
Minin
Perfect! Thank you very much m8!
Old Aug 5, 2013 | 04:18 AM
Minin's Avatar
Minin
I looked in the ncs expert but I couldn't find anything about my problem, can you please help me out a bit?
Old Aug 5, 2013 | 05:07 AM
ASKtheteach's Avatar
ASKtheteach
The chime did change, but in 2011. My 2010 had one type, and my 2012 has the newer one. I noticed when I had a 2011 loaner while I still owned my 2010.
Old Aug 5, 2013 | 05:26 PM
Minin's Avatar
Minin
I see but I don't want to change the.chime I just want.the chime to come out.the radio speakers and not this little speaker in the back of the speedo.
Pker
Apr 11, 2017 12:14 AM
theblackfalcon
Oct 19, 2015 05:22 AM
donniedarko
Sep 25, 2015 09:02 AM
Oilfieldtrash
Sep 21, 2015 09:59 AM
missinmyjeep
Aug 22, 2015 07:13 PM
