R55 Broken Latch on 09 Clubman (Barn) Door
Old Apr 19, 2009 | 04:34 PM
srahaim's Avatar
srahaim
Any similar experiences out there? Latch on left door just got harder and harder to shut and now the latch has failed. It's the latch on the bottom. I'll make the call to service tomorrow.
Also, any service bulletins outstanding on stuff that I should mention?
Old Aug 10, 2013 | 03:49 PM
Minimal1's Avatar
Minimal1
I have a problem with the right door latch not working.
Old Jan 7, 2014 | 08:45 AM
EAVclubbie's Avatar
EAVclubbie
2008 latch
The left barn door latch just went kaput on my 2008 Clubman. The door wont engage the latch when closing... seems like a spring or busted cam. I used a couple of zip ties around the handles to keep the doors closed. The right door latches to the left one OK.
I'll order one from ECS and try to replace it myself.
Old Jan 7, 2014 | 12:14 PM
Here is the link to the thread about the rear barn doors locks and how to's:
https://www.northamericanmotoring.co...arn-doors.html
Old Jan 11, 2014 | 08:12 AM
Minimal1's Avatar
Minimal1
I purchases the part from Mini and installed it in about 15 minutes it was very easy and I'm no mechanic.
Old Jan 13, 2014 | 07:00 AM
Great. Glad you were able to get it fixed.
Old Jan 14, 2014 | 04:18 AM
Little Bean's Avatar
Little Bean
Yea mine has broken twice. It is a relatively inexpensive part but if you dont have time or incling to do it your self, be prepared to pay a nice 1-2hour rate of labor.
Old Jan 16, 2014 | 11:40 PM
damiencain's Avatar
damiencain
OK having the same issue...maybe. My right side barn door just makes a whirring sound when I try to use the latch to open the door. I have replaced the left side latch in the past as it would not stay closed. For this right side issue, is it the inside latch or some sort of actuating mechanism or are they one in the same? Thanks in advance.
Old Jan 17, 2014 | 08:17 AM
Check out this thread.
The one in the right door makes a little noise when you grab the right side handle and then it opens. Try to press then pull on the door when you grab the handle to open it. You might have a stuck / bad lock on the right door which mounts to the inside jam towards the center of the doors. Right rear door has the lock ( #1 on the linked thread) , and left door on the jam has the sticker ( #5 n the linked thread ) for the right door.
Thanks and hope that helps.
Old Jan 18, 2014 | 05:25 PM
damiencain's Avatar
damiencain
No I have tried all that. Tried opening it with the remote. Locking and unlocking. nothing works. Push, pull, pray. The handle just whirs for a few seconds then stops. Door still closed. Ugh..I wanna get it fixed next week but since I cant get inside the door not totally sure what is wrong
Old Jan 18, 2014 | 05:38 PM
danjreed's Avatar
danjreed
This reminds me to add a manual release from the inside!
Knuckle14
Aug 26, 2015 08:10 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
davavd
Aug 25, 2015 10:08 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
