R55 Boot doors opening on their own?
Old Feb 6, 2009 | 11:44 AM
tacostrk's Avatar
tacostrk
Anyone have this problem happen to them? Happened to me a few days ago and would not quit till I finally parked the car and locked the doors. Its been covered ever since and I havent checked again. I had just washed the car before it started happening not sure if that had anything to do with it.
Old Feb 6, 2009 | 12:41 PM
TsPoet's Avatar
TsPoet
Where was the key? I've found the doors open a number of times, I can always trace it back to a key left in the pocket, then me sitting down and presumably inadvertently depressing the unlock button.
Old Feb 6, 2009 | 01:46 PM
bentyyc's Avatar
bentyyc
I have also experienced this! Not sure if it's related at all to the "ticking" thread, but here's what happened to me:
  1. Washed car at a touchless car wash (yes, it was cold, and I was lazy)
  2. Drove home and started drying the car
  3. noticed a "rhythmic ticking sound" from the rear of the car; passenger's side
  4. Closed the barn doors
  5. Passenger side barn door pops open on its own
  6. Steps 4 & 5 repeated several times
  7. 8-10 minutes later, the ticking stopped
  8. Closed the barn door, and it stayed shut
Weird, eh?
Old Feb 6, 2009 | 03:20 PM
treedog's Avatar
treedog
My SA says she's had a couple of these. Something in the handle of the rear door? Mine has been a problem twice.
Old Feb 6, 2009 | 03:44 PM
tacostrk's Avatar
tacostrk
The key was in my pocket and I was driving down the road. Forgot to mention that I have Comfort Access and was driving when it happened.
Old Feb 9, 2009 | 05:51 AM
elegantmini's Avatar
elegantmini
I've had this happen too, also just after washing the boot. Heard the same ticking sound from the passenger side rear. Closed the door/popped open again 3-4 more times. The car was not running so started it and took a short drive. I think this might reset the O B computer as I've "cured" a couple of other odd behaviors this way... so far so good.
Old Feb 9, 2009 | 06:00 AM
schatzy62's Avatar
schatzy62
This is actually a common problem reported here. The problem is water getting into the switch of the right door and shorting out the contacts and causing the door to open.
Take it back tot he dealer and have them wrap the wiring with sealing tape and clean out the button on the handle and your problem will go away.
Why they have not corrected this problem yet is beyond me but it is a less than 20 minute job for them so have it done.
Old Feb 9, 2009 | 07:25 AM
tim781996's Avatar
tim781996
Thanks Eric. This happened to me two weeks ago. I took the car to the car wash and then I went to Home Depot. As I was driving away, the door popped open. The next time I'm in for services, I'll get it taken care of. Along with my dipping window, and my busted boot power outlet.
Old Feb 9, 2009 | 04:18 PM
elegantmini
Originally Posted by tim781996
Thanks Eric.
+1.
The dealership is a 3 hour drive away so I think I'll just be extra careful not to douse the boot (man, it gets dirty!!) and haul out the hair dryer if necessary, for now. Kinda reminds me of the times I had to dry the spark plug wires of my old Beetle after a downpour...
Old Feb 10, 2009 | 03:55 AM
treedog's Avatar
treedog
Currently I can not open the boot door unless I use the key fob.
Old Feb 10, 2009 | 09:04 AM
schatzy62's Avatar
schatzy62
It is possible that the switch connector for the switch has come undone. That would be the easy fix. if not the switch itself is probably bad. that means replacement of the hole door handle as they do not come aprt cleanly.
Old Feb 10, 2009 | 09:16 AM
ClubmanS's Avatar
ClubmanS
Sounds like a problem with the electric door lock actuator and/or the wiring. I haven't had this problem.
Old Feb 13, 2009 | 05:02 PM
elegantmini
Not good
It's been raining quite a bit the last few days and yesterday morning I came out to find the right boot door open again. Fortunately, there wasn't much water inside, but the boot light had been on and I was concerned about draining the battery. No problem, but now I'm concerned about being able to lock the car. Does anybody know if the other door handles are affected??
Old Feb 14, 2009 | 11:10 AM
kuba_kuba's Avatar
kuba_kuba
Happened to me a few times when i first picked the car up. A real hard slam seemed to solve the problem - maybe just knocked to moisture off?
Old Nov 6, 2022 | 10:08 AM
r55jose's Avatar
r55jose
What was the solution.
hey Tim I was curious as to what the solution is I have one that is a total lemon.
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Southern Marylander
Sep 3, 2015 05:46 AM
spackletooms
Sep 1, 2015 10:12 PM
