R55 passenger door won't open from the inside - any suggestions?
Old Aug 11, 2008 | 12:31 PM
joebeenimble's Avatar
joebeenimble
I did a search in the forums, but could not find a description on how to fix this problem (my passenger door won't open from the inside)
Do any of you know how I should go about getting into the door assembly... it sounds like a pretty easy fix, but I am 4 hrs. from my dealer.
This sucks.
Old Aug 11, 2008 | 12:38 PM
nelzie's Avatar
nelzie
I would head to the dealership.
If you try taking it apart and break some "innocuous" bit of plastic or what-not and then the door refuses to go back together all fit together properly, you will likely be unhappy with yourself.
A 4 hour drive absolutely sucks though...
Talk to your dealership and see if they would be willing/interested in paying to have the work done locally. It never hurts to ask.
OWG's Avatar
OWG
Please forgive what is going to come across as a stupid question, but are you referring to the front passenger door or the suicide door?
Old Aug 11, 2008 | 12:44 PM
mannie-k's Avatar
mannie-k
Ditto to this question...
I had a problem with opening the suicide door the other week... Finally found what seems to be a "reset" button at the base of the club door... I pressed it, and Bingo! door worked fine again...
FWIW...
Good luck!
Old Aug 12, 2008 | 05:11 AM
joebeenimble
I'm referring to the front passenger door... it will open from the outside, but not from the inside. It is almost like a child lock on a Chevy... I looked for the a child lock button that I thought one of my kids might have hit, but I did not find one.
From the looks of it on other threads, this problem is not uncommon... I just wanted to see if someone knew of a quick/easy way to fix it.
Old Aug 12, 2008 | 06:49 AM
OWG's Avatar
OWG
I think that you are in for a road-trip.
Is the door lock nub popping up from the top rear of the door on the first pull?
Old Aug 12, 2008 | 07:04 AM
wampa's Avatar
wampa
Herbie wouldn't let his passengers out till he was "done" with them either.
Perhaps you need to keep motorin'!
JAT
Old Aug 12, 2008 | 07:30 AM
AutoXCooper.com's Avatar
AutoXCooper.com
I don't know if this will help or not, but it might. https://www.northamericanmotoring.co...d.php?t=138109
Based on this link, looks like it's the same basic setup, http://www.realoem.com/bmw/showparts...79&hg=41&fg=40 in all MINI's. I have fixed mine twice.
Old Aug 12, 2008 | 08:03 AM
joebeenimble
OWG...no.
wampa...lol.
autox...thanks for the links - I'll check those out.
sevin
May 2, 2026 06:11 AM
polotska
Aug 23, 2015 03:03 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
SoCalledFriend
Aug 6, 2015 06:59 AM
