R50/53 Wing Removal?
Old Jan 26, 2007 | 07:17 AM
AtoZ's Avatar
AtoZ
Wing Removal?
I need to loosen my Cooper wing to get my stop light out. I've removed the plugs and 10mm nuts. I can get one side up slightly but the other is on tight. Looking at the drawing on OEM, it looks like some kind of a hook but I can't tell. I was just able to slide the light out but I would like to know how the wing is fastened.
Any advice?
Old Jan 26, 2007 | 08:23 AM
Eric_Rowland's Avatar
Eric_Rowland
Double sided tape, I believe.
Here is Richards writeup on the removal of his Cooper wing.
Here is another thread that talks about it.
I didn't think you needed to move the spoiler to access the brake light. Kurt, you there? Can you confirm?
Old Jan 26, 2007 | 01:10 PM
MINIMM's Avatar
MINIMM
No, you don't have to remove it.
Old Jan 26, 2007 | 01:23 PM
AtoZ's Avatar
AtoZ
I don't have to remove it, but I need to loosen it up on the bottom side. It needs just a slight tilt up. This is the Cooper not the S.
Old Jan 26, 2007 | 01:26 PM
Xiek's Avatar
Xiek
I just had my 3rd brake light replaced under warranty, contacts corroded.. I don't beleive they removed the wing to replace on my 04 cooper... I didn't see it off, but I did not have a clear view of the bay.
J
Old Jan 26, 2007 | 01:40 PM
mini-rolls's Avatar
mini-rolls
The wing is attached with a 3M type if body tape. The 10mm nuts are just added security. To completely remove the wing you need to use a fine wire to cut the tape. There are no hooks or other things holding the wing.
Old Jan 26, 2007 | 02:58 PM
erickvonzipper's Avatar
erickvonzipper
Thanks, Eric, _that's_ the thread I've been looking for! A plastic squeegee! Whooda thunkit??! =o)
Zip
Old Jan 26, 2007 | 04:09 PM
89AKurt's Avatar
89AKurt
The MC has a spoiler, not a wing. When you can see under it, it's a wing. When you can slice pedestrains with it, it's rice.
Old Jan 26, 2007 | 04:34 PM
Xiek's Avatar
Xiek
actually, isn't the MCS still a "spoiler"... something about a wing being 4 or 6" off the car....
Old Jan 26, 2007 | 04:39 PM
Red's Avatar
Red
I agree. Now you got me thinking...going to send out for some...
regards,
Red
Old Jan 26, 2007 | 07:23 PM
erickvonzipper
It's a thing that sticks out from the back of the car.
So there. =op
Zip
Crimguy
Sep 10, 2015 01:07 PM
NC TRACKRAT
Sep 7, 2015 01:19 PM
Sep 1, 2015 04:02 PM
greekzilla
Aug 23, 2015 03:44 PM
WayMotorWorks
Aug 21, 2015 09:18 PM
